查看: 972|回复: 5
[技术讨论] STM32G070 调用HAL_I2C_Mem_Read_IT测试疑问
发表于 2024-12-3 10:58:51 | 显示全部楼层 |阅读模式
使用两个板子,在例程I2C_TwoBoards_RestartComIT代码上进行修改:
主机调用HAL_I2C_Mem_Read_IT函数,发送内存地址16位后读10个数据;
从机调用HAL_I2C_Slave_Seq_Receive_IT接收内存地址后再调用HAL_I2C_Slave_Seq_Transmit_IT发送10个数据;
现象:
从机正常接收,给主机发送第1个数据正常,到第2~10个数据时每次第八个时钟拉低了500多个ms才拉高,也就是延时了500多ms才回ack。不知道什么原因?
现在把HAL_I2C_Mem_Read_IT替换成查询模式HAL_I2C_Mem_Read,就没有以上时钟被拉低很久的现象。
这说明HAL_I2C_Mem_Read_IT函数封装哪里有问题?求指导
主机调用代码:
HAL_I2C_Mem_Read_IT(&hi2c1, (uint16_t)I2C_ADDRESS,, 0x55aa,2,(uint8_t *)aRxBuffer, 10);
替换
HAL_I2C_Mem_Read(&hi2c1, (uint16_t)I2C_ADDRESS,, 0x55aa,2,(uint8_t *)aRxBuffer, 10,1000);
从机调用代码:
if(HAL_I2C_EnableListen_IT(&hi2c1) != HAL_OK)
   Error_Handler();
while(uwTransferRequested != 1)
if(HAL_I2C_Slave_Seq_Receive_IT(&hi2c1, (uint8_t *)aRxBuffer, 2, I2C_FIRST_FRAME) != HAL_OK)
   Error_Handler();
while (HAL_I2C_GetState(&hi2c1) != HAL_I2C_STATE_LISTEN)
if(HAL_I2C_Slave_Seq_Transmit_IT(&hi2c1, (uint8_t*)aTxBuffer, 10, I2C_LAST_FRAME)!= HAL_OK)
   Error_Handler();
while (HAL_I2C_GetState(&hi2c1) != HAL_I2C_STATE_READY)
从机回调函数:
void HAL_I2C_AddrCallback(I2C_HandleTypeDef *hi2c,uint8_t TransferDirection, uint16_t AddrMatchCode)
   uwTransferRequested  = 1;
void HAL_I2C_SlaveRxCpltCallback(I2C_HandleTypeDef *I2cHandle)
   uwTransferRequested =0;
void HAL_I2C_SlaveTxCpltCallback(I2C_HandleTypeDef *I2cHandle)
发表于 2024-12-3 11:22:36 | 显示全部楼层
官方的例子一直是采用的OD开漏,外置上拉,楼主的是什么方式
 楼主| 发表于 2024-12-3 12:02:14 | 显示全部楼层
GPIO_InitStruct.Pin = GPIO_PIN_6|GPIO_PIN_7;
GPIO_InitStruct.Mode = GPIO_MODE_AF_OD;
GPIO_InitStruct.Pull = GPIO_PULLUP;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
GPIO_InitStruct.Alternate = GPIO_AF6_I2C1;
HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
 楼主| 发表于 2024-12-3 13:21:11 | 显示全部楼层
使用HAL_I2C_Mem_Read查询模式是没有问题的,一用中断就会出现时钟被拉低的现象
 楼主| 发表于 2024-12-3 16:28:18 | 显示全部楼层
已经找到原因,对比更新最新的G0代码时漏了开接收中断。
HAL_I2C_Mem_Read_IT函数最后调用I2C_Enable_IRQ(hi2c, I2C_XFER_TX_IT);
在I2C_Mem_ISR_IT里检测TC标志的地方需调用I2C_Disable_IRQ(hi2c, I2C_XFER_TX_IT);I2C_Enable_IRQ(hi2c, I2C_XFER_RX_IT);
主机没开接收中断,没有读RXDR就会拉低时钟线
发表于 2024-12-4 09:38:24 | 显示全部楼层
HAL_I2C_Mem_Read_IT函数最后调用I2C_Enable_IRQ( ...
谢谢告知最终原因。
GMT+8, 2025-6-10 15:46 , Processed in 0.367508 second(s), 24 queries .
