查看: 3824|回复: 1
uC/OS-III移植FPU问题
发表于 2015-8-22 17:03:46 | 显示全部楼层 |阅读模式
使用STM32F429,按照pdf教程修改fpu部分,下载源码使用的V3.04)
为了验证是否我改错了,再次下载了STM32F7的官网example(其使用的V3.05)
发现在下面加入pdf中的语句,并不正常工作(PDF中相关部分均已修改过)
OS_CPU_PendSVHandler
    CPSID   I                                                   ; Prevent interruption during context switch
    MRS     R0, PSP                                             ; PSP is process stack pointer
    STMFD   R0!, {R4-R11}                                       ; Save remaining regs r4-11 on process stack
    MOV32   R5, OSTCBCurPtr                                     ; OSTCBCurPtr->OSTCBStkPtr = SP;
    LDR     R6, [R5]
    STR     R0, [R6]                                            ; R0 is SP of process being switched out
        ; At this point, entire context of process has been saved
    MOV     R4, LR                                              ; Save LR exc_return value
    BL      OSTaskSwHook                                        ; OSTaskSwHook();
    MOV32   R0, OSPrioCur                                       ; OSPrioCur   = OSPrioHighRdy;
    MOV32   R1, OSPrioHighRdy
    LDRB    R2, [R1]
    STRB    R2, [R0]
    MOV32   R1, OSTCBHighRdyPtr                                 ; OSTCBCurPtr = OSTCBHighRdyPtr;
    LDR     R2, [R1]
    STR     R2, [R5]
    ORR     LR, R4, #0xF4                                       ; Ensure exception return uses process stack
    LDR     R0, [R2]                                            ; R0 is new process SP; SP = OSTCBHighRdyPtr->StkPtr;
    LDMFD   R0!, {R4-R11}                                       ; Restore r4-11 from new process stack
    MSR     PSP, R0                                             ; Load PSP with new process SP
    CPSIE   I
    BX      LR                                                  ; Exception return will restore remaining context
    END
版主可以自己试一试,看看新版本的修改是否正常,谢谢
发表于 2015-8-27 08:54:06 | 显示全部楼层
官网的sstm32f429移植的ucos-iii 貌似没有对fpu进行处理或者处理不当,造成使用硬件fpu不正常,
你可以参考这个
http://www.amobbs.com/forum.php? ... p;extra=#pid8737946
GMT+8, 2025-5-10 06:42 , Processed in 0.422378 second(s), 23 queries .
