查看: 5954|回复: 1
[有问必答] 请问一下有没有STM32 V2开发板的SRAM配置
发表于 2013-8-2 17:03:37 | 显示全部楼层 |阅读模式
我的V2开发板配置测试不通过,读出来都是0xFF,是没配置对吗?有用到SRAM的吗?
* Function Name  : FSMC_SRAM_Init
* Description    : Configures the FSMC and GPIOs to interface with the SRAM memory.
*                  This function must be called before any write/read operation
*                  on the SRAM.
* Input          : None
* Output         : None
* Return         : None
void FSMC_SRAM_Init(void)
    FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;
    FSMC_NORSRAMTimingInitTypeDef  p;
    /*-- FSMC Configuration ------------------------------------------------------*/
    p.FSMC_AddressSetupTime = 1;
    p.FSMC_AddressHoldTime = 0;
    p.FSMC_DataSetupTime = 2;
    p.FSMC_BusTurnAroundDuration = 0;
    p.FSMC_CLKDivision = 0;
    p.FSMC_DataLatency = 0;
    p.FSMC_AccessMode = FSMC_AccessMode_A;
    FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM3;
    FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
    FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_SRAM;
    FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;
    FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
    FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable;
    FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
    FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
    FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
    FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
    FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
    FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
    FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
    FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;
    FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;
    FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
    FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM4;
    /* Enable FSMC Bank1_SRAM Bank */
    FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM3, ENABLE);
    FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM4, ENABLE);
 楼主| 发表于 2013-8-2 17:44:41 | 显示全部楼层
搞定了,原来是GPIO没配置
GMT+8, 2025-7-5 13:27 , Processed in 0.262312 second(s), 23 queries .
