查看: 5600|回复: 6
[求助]SDRAM讀寫時間是否能夠更快速?
发表于 2015-10-28 08:39:49 | 显示全部楼层 |阅读模式
您好~
我想請教有關STM32F426I-DISCO 開發版上所使用的SDRAM資料存取時間是否能夠更快速?
以下是我量測存取時間驗證方式:
使用GPIOG Pin13 驗證寫入時間,將得到的時間除與BUFF_SIZE,驗證每筆資料儲存時間,其中BUFF_SIZE為2048。得到每筆資料寫入時間為1.02s/2048=498.0468us。
GPIOG->ODR = GPIO_Pin_13;
for(adr=0;adr<BUFF_SIZE;adr++){
    *(unsigned int*) (SDRAM_START_ADR + (adr << 2)) = write[adr];
GPIOG->ODR = ~GPIO_Pin_13;
使用GPIOG Pin14 驗證讀取時間,將得到的時間除與BUFF_SIZE,驗證每筆資料儲存時間,其中BUFF_SIZE為2048。得到每筆資料寫入時間為2.5s/2048=1220.7031us。
GPIOG->ODR = GPIO_Pin_14;
    read[adr] = *(unsigned int*)(SDRAM_START_ADR +(adr << 2));
GPIOG->ODR = ~GPIO_Pin_14;
SDRAM FMC設定如下:
void P_SDRAM_InitFMC(void)
  FMC_SDRAMInitTypeDef  FMC_SDRAMInitStructure;
  FMC_SDRAMTimingInitTypeDef  FMC_SDRAMTimingInitStructure;
  RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FMC, ENABLE);
  // FMC auf 180MHz/2 = 90MHz einstellen
  // 90MHz = 11,11 ns
  // Alle Timings laut Datasheet und Speedgrade -7 (=7ns)
  FMC_SDRAMTimingInitStructure.FMC_LoadToActiveDelay = 2;    // tMRD=2CLK
  FMC_SDRAMTimingInitStructure.FMC_ExitSelfRefreshDelay = 7; // tXSR min=70ns
  FMC_SDRAMTimingInitStructure.FMC_SelfRefreshTime = 4;      // tRAS min=42ns
  FMC_SDRAMTimingInitStructure.FMC_RowCycleDelay = 7;        // tRC  min=63ns
  FMC_SDRAMTimingInitStructure.FMC_WriteRecoveryTime = 2;    // tWR =2CLK
  FMC_SDRAMTimingInitStructure.FMC_RPDelay = 2;              // tRP  min=15ns
  FMC_SDRAMTimingInitStructure.FMC_RCDDelay = 2;             // tRCD min=15ns
  FMC_SDRAMInitStructure.FMC_Bank = FMC_Bank2_SDRAM;
  FMC_SDRAMInitStructure.FMC_ColumnBitsNumber = FMC_ColumnBits_Number_8b;
  FMC_SDRAMInitStructure.FMC_RowBitsNumber = FMC_RowBits_Number_12b;
  FMC_SDRAMInitStructure.FMC_SDMemoryDataWidth = SDRAM_MEMORY_WIDTH;
  FMC_SDRAMInitStructure.FMC_InternalBankNumber = FMC_InternalBank_Number_4;
  FMC_SDRAMInitStructure.FMC_CASLatency = SDRAM_CAS_LATENCY;
  FMC_SDRAMInitStructure.FMC_WriteProtection = FMC_Write_Protection_Disable;
  FMC_SDRAMInitStructure.FMC_SDClockPeriod = SDRAM_CLOCK_PERIOD;
  FMC_SDRAMInitStructure.FMC_ReadBurst = SDRAM_READBURST;
  FMC_SDRAMInitStructure.FMC_ReadPipeDelay = FMC_ReadPipe_Delay_1;
  FMC_SDRAMInitStructure.FMC_SDRAMTimingStruct = &FMC_SDRAMTimingInitStructure;
  FMC_SDRAMInit(&FMC_SDRAMInitStructure);
  P_SDRAM_InitSequence();
void P_SDRAM_InitSequence(void)
  FMC_SDRAMCommandTypeDef FMC_SDRAMCommandStructure;
  uint32_t tmpr = 0;
  FMC_SDRAMCommandStructure.FMC_CommandMode = FMC_Command_Mode_CLK_Enabled;
  FMC_SDRAMCommandStructure.FMC_CommandTarget = FMC_Command_Target_bank2;
  FMC_SDRAMCommandStructure.FMC_AutoRefreshNumber = 1;
  FMC_SDRAMCommandStructure.FMC_ModeRegisterDefinition = 0;
  while(FMC_GetFlagStatus(FMC_Bank2_SDRAM, FMC_FLAG_Busy) != RESET);
  FMC_SDRAMCmdConfig(&FMC_SDRAMCommandStructure);
  P_SDRAM_delay(10);
  FMC_SDRAMCommandStructure.FMC_CommandMode = FMC_Command_Mode_PALL;
  FMC_SDRAMCommandStructure.FMC_CommandMode = FMC_Command_Mode_AutoRefresh;
  FMC_SDRAMCommandStructure.FMC_AutoRefreshNumber = 4;
  tmpr = (uint32_t)SDRAM_MODEREG_BURST_LENGTH_2          |
                   SDRAM_MODEREG_BURST_TYPE_SEQUENTIAL   |
                   SDRAM_MODEREG_CAS_LATENCY_3           |
                   SDRAM_MODEREG_OPERATING_MODE_STANDARD |
                   SDRAM_MODEREG_WRITEBURST_MODE_SINGLE;
  FMC_SDRAMCommandStructure.FMC_CommandMode = FMC_Command_Mode_LoadMode;
  FMC_SDRAMCommandStructure.FMC_ModeRegisterDefinition = tmpr;
  // FMC_CLK = 90MHz
  // Refresh_Rate = 7.81us
  // Counter = (FMC_CLK * Refresh_Rate) - 20
  FMC_SetRefreshCount(683);
系統相關時脈設定,如下:
/************************* PLL Parameters *************************************/
/* PLL_VCO = (HSE_VALUE or HSI_VALUE / PLL_M) * PLL_N */
#define PLL_M      8
/* USB OTG FS, SDIO and RNG Clock =  PLL_VCO / PLLQ */
#define PLL_Q      8
#if defined (STM32F40_41xxx)
#define PLL_N      336
/* SYSCLK = PLL_VCO / PLL_P */
#define PLL_P      2
#endif /* STM32F40_41xxx */
#if defined (STM32F427_437xx) || defined (STM32F429_439xx)
#define PLL_N      360 //336
#define PLL_P      2
#endif /* STM32F427_437x || STM32F429_439xx */
#if defined (STM32F401xx)
#define PLL_N      336
#define PLL_P      4
#endif /* STM32F401xx */
SDRAM Datasheet 如下網址:
http://www.issi.com/WW/pdf/42-45S16400J.pdf
发表于 2015-10-28 09:13:25 | 显示全部楼层
楼主测试的写入速度是40MB/S吗,写入速度还行。
楼主的测试方法可以优化下,改成下面这样看看速度如何:
uint16_t *pBuf;
uint32_t i, n;
for (n = 0; n < 80; n++)
     pBuf = (uint16_t *)SDRAM_BANK_ADDR;
     for (i = 0; i < 1024*1024; i++)
          *pBuf++ = 0x55AA;
看看这种测试的话,速度是不是可以提高。
发表于 2015-10-28 14:35:02 | 显示全部楼层
我中午按照这种方式测试下,用的也是探索板子:
每次写入32位数据
测试速度是:320MB/4.401s = 72.7MB/S
    uint32_t i, n;
    uint32_t *pBuf;
    iTime1 = bsp_GetRunTime();    /* 记下开始时间 */
        pBuf = (uint32_t *)SDRAM_BANK_ADDR;
            *pBuf++ = 0x55AA55AA;
    iTime2 = bsp_GetRunTime();    /* 记下结束时间 */
每次写入16位数据
测试速度是:160MB/3.820s = 41.88MB/S
    uint32_t i, n;
    uint16_t *pBuf;
            *pBuf++ = 0x55AA;
每次写入8位数据
测试速度是:80MB/3.298s = 24.32MB/S
    uint32_t i, n;
    uint16_t *pBuf;
            *pBuf++ = 0x55AA;
 楼主| 发表于 2015-10-28 14:47:29 | 显示全部楼层
eric2013 您好 感謝您提供的方法,存取速度有明顯變快許多,目前我測得的情況如下:
SDRAM寫入2048筆unsigned short的資料需花費70us,因此一筆資料為70us/2048=0.03417us,導數為1/(0.03417us)=29.26M。
SDRAM讀取2048筆unsigned short的資料需花費208us,因此一筆資料為208us/2048=0.10156us,導數為1/(0.10156us)=9.84M。
請問以上寫入與讀取速度正常嗎?是否有需要再進行設定的地方?
請問一下,以下設定需使用DISABLE還是ENABLE?
FMC_SDRAMWriteProtectionConfig(FMC_Bank2_SDRAM, DISABLE);
发表于 2015-10-29 08:50:45 | 显示全部楼层
回 bai790902 的帖子
bai790902:eric2013 您好 感謝您提供的方法,存取速度有明顯變快許多,目前我測得的情況如下:
SDRAM讀取2048筆unsigned short的資料需花費208us,因此一筆資料為208us/20 .. (2015-10-28 14:47)
这个设置为禁止就可以了,FMC_SDRAMWriteProtectionConfig(FMC_Bank2_SDRAM, DISABLE);
如果开启了写保护的话,那么就无法再写入数据了。
 楼主| 发表于 2015-10-29 16:26:56 | 显示全部楼层
eric2013:我中午按照这种方式测试下,用的也是探索板子:
每次写入32位数据
    uint32_t i, n;
    uint32_t *pBuf;
....... (2015-10-28 14:35)
eric2013 您好 感謝您用心地回答,那個我想再請教一下,您的Code有使用到以下函式:
bsp_GetRunTime();
想請教您該函式是要如何使用?
您輸出的值是利用UART傳輸到電腦後去觀看嗎?
若是我想請問一下UART傳輸會拖慢SDRAM寫入時間嗎?
发表于 2015-10-30 19:00:17 | 显示全部楼层
回 bai790902 的帖子
bai790902:eric2013 您好 感謝您用心地回答,那個我想再請教一下,您的Code有使用到以下函式:
bsp_GetRunTime();
想請教您該函式是要如何使用?
....... (2015-10-29 16:26)
这个函数是用滴答定时器中断里面加个计数变量,毫秒计数,而函数
bsp_GetRunTime()就是获取下这个变量的值。前后相减就得到了执行时间。
我是把差值显示在了LCD上面,当然用UART也是可以的,UART不会拖慢SDRAM的。
GMT+8, 2025-5-10 03:48 , Processed in 0.418086 second(s), 24 queries .
