查看: 8352|回复: 1
[emWin] 裸机一直STemWin出现如下错误
发表于 2013-10-29 20:43:21 | 显示全部楼层 |阅读模式
发表于 2013-10-29 20:47:36 | 显示全部楼层
是因为你没有提供这些函数,裸机的情况下也要提供的,在这个文件GUI_X.c里面。
#include "GUI.h"
*       Global data
volatile GUI_TIMER_TIME OS_TimeMS;
*      Timing:
*                 GUI_X_GetTime()
*                 GUI_X_Delay(int)
  Some timing dependent routines require a GetTime
  and delay function. Default time unit (tick), normally is
  1 ms.
GUI_TIMER_TIME GUI_X_GetTime(void) {
  return OS_TimeMS;
void GUI_X_Delay(int ms) {
  int tEnd = OS_TimeMS + ms;
  while ((tEnd - OS_TimeMS) > 0);
*       GUI_X_Init()
* Note:
*     GUI_X_Init() is called from GUI_Init is a possibility to init
*     some hardware which needs to be up and running before the GUI.
*     If not required, leave this routine blank.
void GUI_X_Init(void) {}
*       GUI_X_ExecIdle
* Note:
*  Called if WM is in idle state
void GUI_X_ExecIdle(void) {}
*      Logging: OS dependent
Note:
  Logging is used in higher debug levels only. The typical target
  build does not use logging and does therefor not require any of
  the logging routines below. For a release build without logging
  the routines below may be eliminated to save some space.
  (If the linker is not function aware and eliminates unreferenced
  functions automatically)
void GUI_X_Log     (const char *s) { GUI_USE_PARA(s); }
void GUI_X_Warn    (const char *s) { GUI_USE_PARA(s); }
void GUI_X_ErrorOut(const char *s) { GUI_USE_PARA(s); }
GMT+8, 2025-7-6 13:29 , Processed in 0.489222 second(s), 27 queries .
