查看: 5472|回复: 1
[μCOS-III] μCOS-III源码中的错误整理贴
发表于 2014-3-11 15:15:35 | 显示全部楼层 |阅读模式
μCOS-III V3.03.01
1. os_core.c文件函数void  OSSchedUnlock (OS_ERR  *p_err)的注释:
  OS_ERR_NONE
  OS_ERR_OS_NOT_RUNNING         The scheduler has been enabled    这句注释错了,应该是系统还没有开始运行
  OS_ERR_SCHED_LOCKED               The scheduler is still locked, still nested
  OS_ERR_SCHED_NOT_LOCKED     The scheduler was not locked
  OS_ERR_SCHED_UNLOCK_ISR       If you called this function from an ISR.
 楼主| 发表于 2014-3-13 19:37:41 | 显示全部楼层
2. os_core.c文件函数void  OS_RdyListRemove (OS_TCB  *p_tcb)的注释:
Returns    : A pointer to the OS_RDY_LIST where the OS_TCB was    //这个函数没有返回值
GMT+8, 2025-7-7 03:05 , Processed in 0.228267 second(s), 24 queries .
