查看: 3228|回复: 3
[μCOS-III] uCosIII + STM32F429Discovery 开启FPU问题
发表于 2017-4-14 16:50:06 | 显示全部楼层 |阅读模式
1.uCOSIII的版本是V3.04.04,在IAR 下按照手册教程修改了OSTaskStkInit 和 OS_CPU_PendSVHandler两个函数
  CPU_STK  *OSTaskStkInit (OS_TASK_PTR    p_task,
                           void          *p_arg,
                           CPU_STK       *p_stk_base,
                           CPU_STK       *p_stk_limit,
                           CPU_STK_SIZE   stk_size,
                           OS_OPT         opt)
    CPU_STK    *p_stk;
    (void)opt;                                                  /* Prevent compiler warning                               */
    p_stk = &p_stk_base[stk_size];                              /* Load stack pointer                                     */
        /* Align the stack to 8-bytes.                            */
    p_stk = (CPU_STK *)((CPU_STK)(p_stk) & 0xFFFFFFF8);
        /* Registers stacked as if auto-saved on exception        */
    *--p_stk = (CPU_STK)0x01000000u;                            /* xPSR                                                   */
    *--p_stk = (CPU_STK)p_task;                                 /* Entry Point                                            */
    *--p_stk = (CPU_STK)OS_TaskReturn;                          /* R14 (LR)                                               */
    *--p_stk = (CPU_STK)0x12121212u;                            /* R12                                                    */
    *--p_stk = (CPU_STK)0x03030303u;                            /* R3                                                     */
    *--p_stk = (CPU_STK)0x02020202u;                            /* R2                                                     */
    *--p_stk = (CPU_STK)p_stk_limit;                            /* R1                                                     */
    *--p_stk = (CPU_STK)p_arg;                                  /* R0 : argument                                          */
        /* Remaining registers saved on process stack             */
    *--p_stk = (CPU_STK)0x11111111u;                            /* R11                                                    */
    *--p_stk = (CPU_STK)0x10101010u;                            /* R10                                                    */
    *--p_stk = (CPU_STK)0x09090909u;                            /* R9                                                     */
    *--p_stk = (CPU_STK)0x08080808u;                            /* R8                                                     */
    *--p_stk = (CPU_STK)0x07070707u;                            /* R7                                                     */
    *--p_stk = (CPU_STK)0x06060606u;                            /* R6                                                     */
    *--p_stk = (CPU_STK)0x05050505u;                            /* R5                                                     */
    *--p_stk = (CPU_STK)0x04040404u;                            /* R4                                                     */
    #if (OS_CPU_ARM_FP_EN == DEF_ENABLED)
      *--p_stk = (CPU_STK)0xFFFFFFFDUL;
    return (p_stk);
    CPSID   I                                                   ; Prevent interruption during context switch
    MRS     R0, PSP                                             ; PSP is process stack pointer
    CBZ     R0, OS_CPU_PendSVHandler_nosave                     ; Skip register save the first time
    #ifdef __ARMVFP__                                           ; if IDE enable FPU uint ,will define __ARMVFP__
      TST      LR, #0x10
      IT       EQ
      VSTMDBEQ R0!, {S16-S31}
      MOV      R3, LR
      STMDB    R0!,{R3-R11}
    #else
      STMDB    R0!,{R4-R11}
    LDR     R1, =OSTCBCurPtr                                    ; OSTCBCurPtr->OSTCBStkPtr = SP;
    LDR     R1, [R1]
    STR     R0, [R1]                                            ; R0 is SP of process being switched out
        ; At this point, entire context of process has been saved
    PUSH    {R14}                                               ; Save LR exc_return value
    LDR     R0, =OSTaskSwHook                                   ; OSTaskSwHook();
    BLX     R0
    POP     {R14}
    LDR     R0, =OSPrioCur                                      ; OSPrioCur   = OSPrioHighRdy;
    LDR     R1, =OSPrioHighRdy
    LDRB    R2, [R1]
    STRB    R2, [R0]
    LDR     R0, =OSTCBCurPtr                                    ; OSTCBCurPtr = OSTCBHighRdyPtr;
    LDR     R1, =OSTCBHighRdyPtr
    LDR     R2, [R1]
    STR     R2, [R0]
    LDR     R0, [R2]                                            ; R0 is new process SP; SP = OSTCBHighRdyPtr->StkPtr;
    #ifdef __ARMVFP__
      LDMIA    R0!,{R3-R11}
      MOV     LR, R3
      TST      LR, #0x10
      IT       EQ
      VLDMIAEQ R0!, {S16-S31}
    #else
      LDMIA    R0!,{R4-R11}
    MSR     PSP, R0                                             ; Load PSP with new process SP
    CPSIE   I
    BX      LR                                                  ; Exception return will restore remaining context
    END
并将这里注销了
    if ((OSTCBCurPtr->Opt & OS_OPT_TASK_SAVE_FP) != (OS_OPT)0) {
      //OS_CPU_FP_Reg_Push(OSTCBCurPtr->StkPtr);
    if ((OSTCBHighRdyPtr->Opt & OS_OPT_TASK_SAVE_FP) != (OS_OPT)0) {
      //OS_CPU_FP_Reg_Pop(OSTCBHighRdyPtr->StkPtr);
2.建了两个点灯任务,现在问题是关闭FPU后,两个LED正常闪烁;开启FPU后,两个灯都被点亮,任务第一次被调用了,之后就一直运行idle任务,仿真程序没有死机,但是tick_task任务进不去,请问会是什么原因呢?有没有什么建议,谢谢。
发表于 2017-4-15 00:43:31 | 显示全部楼层
参考我们的例子吧,F429板子,下载这个里面任意一个RTOS的例子,是含IAR和MDK两个版本的,你参考下,
是用的3.05.00版本:
 楼主| 发表于 2017-4-15 08:20:29 | 显示全部楼层
谢谢版主
 楼主| 发表于 2017-4-15 08:21:01 | 显示全部楼层
eric2013:参考我们的例子吧,F429板子,下载这个里面任意一个RTOS的例子,是含IAR和MDK两个版本的,你参考下,
是用的3.05.00版本:
http://www.armbbs.cn/forum.php?mod=viewthread&tid=19834 (2017-04-15 00:43)
谢谢版主
GMT+8, 2025-7-6 06:01 , Processed in 0.320974 second(s), 24 queries .
