查看: 5900|回复: 1
[QQ群问题解答] uCOS任务级的调度关中断的问题
发表于 2014-4-1 10:43:05 | 显示全部楼层 |阅读模式
任务级调度使用了如下的函数:
void  OS_Sched (void)
#if OS_CRITICAL_METHOD == 3                            /* Allocate storage for CPU status register     */
    OS_CPU_SR  cpu_sr;
    INT8U      y;
    OS_ENTER_CRITICAL();
    if ((OSIntNesting == 0) && (OSLockNesting == 0)) { /* Sched. only if all ISRs done & not locked    */
        y             = OSUnMapTbl[OSRdyGrp];          /* Get pointer to HPT ready to run              */
        OSPrioHighRdy = (INT8U)((y << 3) + OSUnMapTbl[OSRdyTbl[y]]);
        if (OSPrioHighRdy != OSPrioCur) {              /* No Ctx Sw if current task is highest rdy     */
            OSTCBHighRdy = OSTCBPrioTbl[OSPrioHighRdy];
            OSCtxSwCtr++;                              /* Increment context switch counter             */
            OS_TASK_SW();                              /* Perform a context switch                     */
    OS_EXIT_CRITICAL();
我有一个问题,这个函数开始使用OS_ENTER_CRITICAL();关闭了全局中断使能,如果优先级更高的任务进入了使能状态,这个开中断的操作
发表于 2014-4-2 10:30:32 | 显示全部楼层
问题表示不清
GMT+8, 2025-5-16 05:07 , Processed in 0.660957 second(s), 24 queries .
