查看: 2560|回复: 2
[其它] 发现一款售价35$的i.MX7核心板,设计还不错
发表于 2017-6-29 00:28:19 | 显示全部楼层 |阅读模式
链接
CPU
CPU NameNXP/Freescale i.MX7
CPU TypeCortex™-A7
CPU Cores2
CPU Clock (Max)1 GHz
Real-time processor200MHz ARM Cortex™-M4
Memory
RAM256 - 2048 MB DDR3L
SLC NAND128 - 512 MB
eMMC8 - 32 GB
Multimedia
2D Graphics Acceleration2D pixel acceleration engine (PxP)
Camera Interfaces1x 24bit CPI, Dual lane MIPI
Display
Parallel RGB1920 x 1080 24-bit
E-inkEPDC
DSI1400 x 1050 24-bit
Resistive touch4-wire
Networking
Ethernet2x 10/100/1000 Mbps Ethernet
Wi-Fi802.11 b/g/n
Bluetooth4.1 / BLE
Audio
Headphone driverYes
MicrophoneAnalog
Digital audio serial interfaceSAI, MQS
Line In/OutYes
Connectivity
SD / MMCx1
USB Host / DeviceUSB 2.0 : 1x Host, 1x OTG
UARTx7, up to 3.6 Mbps
I2Cx4
SPIx4
RTCOn carrier
ADC2 x 4 channel 12-bit
OS Support
LinuxYocto
AndroidN/A
Windows Embedded CompactN/A
Mechanical Specifications
Dimensions (W x L x H)38.6 mm x 67.8 mm x 4.0 mm
Electronic Specifications
Supply voltage3.3 V
Digital I/O voltage3.3 V
Environmental Specifications
Commercial temperature (0 to 70°C)Yes
Industrial temperature (-20 to 85°C)Yes
发表于 2017-6-29 08:49:22 | 显示全部楼层
是用Linux的吗?
 楼主| 发表于 2017-6-29 09:15:54 | 显示全部楼层
回 shampoo 的帖子
shampoo:是用Linux的吗? (2017-06-29 08:49)
是的。
GMT+8, 2024-5-30 01:14 , Processed in 0.232290 second(s), 28 queries .
