楼主 |
发表于 2014-5-2 20:22:21
显示全部楼层
eric2013:估计是的程序问题,把你的这部分程序贴出来,我看下 (2014-05-02 20:11)  /*********************************************************************
* SEGGER Microcontroller GmbH & Co. KG *
* Solutions for real time microcontroller applications *
* C-file generated by: *
* GUI_Builder for emWin version 5.20 *
* Compiled Mar 19 2013, 15:01:00 *
* (c) 2013 Segger Microcontroller GmbH & Co. KG *
* Internet: www.segger.com Support: support@segger.com *
// USER START (Optionally insert additional includes)
// USER END
#include "DIALOG.h"
* Defines
#define ID_FRAMEWIN_0 (GUI_ID_USER + 0x00)
#define ID_BUTTON_0 (GUI_ID_USER + 0x01)
// USER START (Optionally insert additional defines)
// USER END
* Static data
// USER START (Optionally insert additional static data)
// USER END
* _aDialogCreate
{ FRAMEWIN_CreateIndirect, "Framewin", ID_FRAMEWIN_0, 114, 39, 423, 291, 0, 0x0, 0 },
{ BUTTON_CreateIndirect, "Button", ID_BUTTON_0, 143, 107, 80, 20, 0, 0x0, 0 },
// USER START (Optionally insert additional widgets)
// USER END
* Static code
// USER START (Optionally insert additional static code)
// USER END
* _cbDialog
int NCode;
int Id;
// USER END
switch (pMsg->MsgId) {
case WM_NOTIFY_PARENT:
Id = WM_GetId(pMsg->hWinSrc);
NCode = pMsg->Data.v;
switch(Id) {
case ID_BUTTON_0: // Notifications sent by 'Button'
switch(NCode) {
case WM_NOTIFICATION_CLICKED:
// USER START (Optionally insert code for reacting on notification message)
// USER END
GUI_EndDialog(pMsg->hWin,0);
// USER END
// USER START (Optionally insert additional code for further notification handling)
// USER END
// USER START (Optionally insert additional code for further Ids)
// USER END
// USER END
default:
WM_DefaultProc(pMsg);
* Public code
* CreateFramewin
WM_HWIN CreateFramewin(void);
WM_HWIN CreateFramewin(void) {
WM_HWIN hWin;
FRAMEWIN_AddCloseButton( hWin ,0,0);
return hWin;
// USER START (Optionally insert additional public code)
// USER END
void MainTaskD(void) {
GUI_Init();
CreateFramewin();
while(1) {
GUI_Delay(100);
/*************************** End of file ****************************/ |
