查看: 6757|回复: 3
[emWin] 窗口切换几次后出现死机
发表于 2014-6-6 10:43:40 | 显示全部楼层 |阅读模式
使用按键切换窗口,但是切换几次后,发现程序会跑飞,按键显示不出来,调试发现死机是执行了一下 GUIDEMO_main()中的GUI_Exec()函数之后程序运行不正常,不显示按键并且不执行while(1)中语句
附上代码如下
void GUIDEMO_main()
    ahButton = BUTTON_Create(450, 240,  25,  10,    ID_BUTTON_1,  BUTTON_CF_SHOW );
    BUTTON_SetBitmap(ahButton, BUTTON_BI_UNPRESSED, &bm1);
    GUI_Exec();
    while(1)
    Current_Btn = GUI_WaitKey();
    switch(Current_Btn)
         case ID_BUTTON_1:
        BUTTON_Delete(ahButton);
        GUI_Clear();
         CreateAWin();
         default:
    GUI_Delay(100);
void CreateAssistantWin()
    hWinAant = GUI_CreateDialogBox(_aDgCreateAant,  GUI_COUNTOF(_aDgCreateAant),  _cbAant, 0, 0, 0);
void _cbAant(WM_MESSAGE * pMsg)
  int NCode;
  int Id;
  switch (pMsg->MsgId)
    case WM_NOTIFY_PARENT:
        NCode = pMsg->Data.v;
        switch(Id)
            case ID_BUTTON_CANCAL:
                switch(NCode)
                    case WM_NOTIFICATION_CLICKED:
                           WM_DeleteWindow(hWinAtant);
                        GUI_Clear();
                        GUIDEMO_main();
 楼主| 发表于 2014-6-6 11:17:42 | 显示全部楼层
简单代码如下
#include "includes.h"
#include "MainTask.h"
#include "GUI.h"
#include "BUTTON.h"
#include "DIALOG.h"
#define ID_WINDOW                 0x01
#define ID_BUTTON_ENSURE     0x02
#define ID_BUTTON_CANCAL     0x03
#define ID_System                    0x04
WM_HWIN hWinAant;
const GUI_WIDGET_CREATE_INFO _aDgCreateAant[3] =
  { WINDOW_CreateIndirect, "Window", ID_WINDOW,                0,   0,   480, 272,     0, 0x0, 0 },
    { BUTTON_CreateIndirect, "OK",     ID_BUTTON_ENSURE,        160, 210,  64,  33,  0, 0x0, 0 },
    { BUTTON_CreateIndirect, "Cancal", ID_BUTTON_CANCAL,         254, 210,  64,  33,  0, 0x0, 0 },
  int NCode;
  int Id;
    WM_HWIN hWin = pMsg->hWin;
        case WM_INIT_DIALOG:
            WINDOW_SetBkColor(hWin, 0x00000000);
            switch(Id)
                case ID_BUTTON_ENSURE:
                    switch(NCode)
                    switch(NCode)
                            WM_DeleteWindow(hWinAant);
                            GUI_Clear();
                            GUIDEMO_main();
        default:
            WM_DefaultProc(pMsg);
void CreateAantWin()
void GUIDEMO_main(void)
        int Current_Btn;
        uint8_t i;
        BUTTON_Handle ahButton;
        GUI_Clear();
    ahButton = BUTTON_Create(150,  100,  SYSTEM_X_SIZE,  SYSTEM_Y_SIZE,    ID_System,  BUTTON_CF_SHOW );
        BUTTON_SetText(ahButton, "SYSTEM");
    //    BUTTON_SetBitmap(ahButton, BUTTON_BI_UNPRESSED, &bm5);
        GUI_Exec();
        while(1)
            switch(Current_Btn)
                case     ID_System:
                        CreateAantWin();
                default:
            GUI_Delay(100);
*       MainTask
void Draw_Wave(void);
void MainTask(void)
    GUI_Init();
    GUI_SetBkColor(GUI_BLACK);
    GUIDEMO_main();
发表于 2014-6-6 19:33:17 | 显示全部楼层
你的程序死在这个里面,你的GUIDEMO_main是死循环:
                            GUI_Clear();
                            GUIDEMO_main();
回调函数无法退出。
 楼主| 发表于 2014-6-9 14:01:02 | 显示全部楼层
eric2013:你的程序死在这个里面,你的GUIDEMO_main是死循环:
                           .. (2014-06-06 19:33)
谢谢,问题解决了, 使能窗口使用内存设备,直接使用GUI_EndDialog(hWin, 0),返回上级界面。
现在还遇到一个问题:
通过一个按键进入下一界面,在这个界面里边要一直刷新界面,更新显示的内容,不知道这个函数应该加在什么地方能一直刷新界面。
代码就是在上述代码的基础上添加,在hWinAant窗口中做刷新界面。能否解决呢
GMT+8, 2025-7-6 13:41 , Processed in 0.224466 second(s), 24 queries .
