查看: 3746|回复: 1
CPLD570实验三:数码管
发表于 2013-2-3 12:12:16 | 显示全部楼层 |阅读模式
说明: 这里的数码管驱动比较简单,以后的程序尽量采用模块的形式进行设计
提供时钟分频的部分
module clkdiv
    nSYSCLK_50MHz,
    nADCCLK_100KHz,
    nCLK_1KHz
input nSYSCLK_50MHz;
output nADCCLK_100KHz;
output nCLK_1KHz;
reg nADCCLK_100KHz, nCLK_1KHz;
reg[7:0] rCount;
reg[14:0] rCount1ms;
  generate 100ksps for adc
always@(negedge nSYSCLK_50MHz)
    begin
        if(rCount <= 8'd250)
            rCount <= rCount + 1'b1;
            begin
                rCount <= 8'd0;
                nADCCLK_100KHz <= ~nADCCLK_100KHz;
            end
    end
  generate 100Hz  for 7SEG
always@(posedge nSYSCLK_50MHz)
  begin
    if(rCount1ms > 15'd25000)
      begin
      nCLK_1KHz <= ~nCLK_1KHz;
      rCount1ms <= 15'd0;
      end
      rCount1ms <= rCount1ms + 1'b1;
  end
endmodule
数码管扫描
module seg7
nCLK_1KHz,         //scan clk
SegCs,             //seg cs
SegData             //seg data
input nCLK_1KHz;
output[7:0] SegCs;
output[7:0] SegData;
/* used for seg */
reg[7:0] SegCs;
reg[7:0] SegData;
reg[3:0] number;
reg[9:0] counter;
reg[7:0] segdata;
  Data convert to 7SEG
function[7:0] leddata;    //返回一个8位的数字
input[3:0]    datain;
begin
  case(datain)
    4'd0: leddata=8'b11000000;//0
    4'd1: leddata=8'b11111001;//1
    4'd2: leddata=8'b10100100;//2
    4'd3: leddata=8'b10110000;//3
    4'd4: leddata=8'b10011001;//4
    4'd5: leddata=8'b10010010;//5
    4'd6: leddata=8'b10000010;//6
    4'd7: leddata=8'b11111000;//7
    4'd8: leddata=8'b10000000;//8
    4'd9: leddata=8'b10010000;//9
     4'ha: leddata = 8'h88;
     4'hb: leddata = 8'h83;
     4'hc: leddata = 8'hc6;
     4'hd: leddata = 8'ha1;
     4'he: leddata = 8'h86;
     4'hf: leddata = 8'h8e;
    default:leddata=8'bzzzz_zzzz;
   endcase
end
endfunction
  7SEG SACN
always@(posedge nCLK_1KHz)
    begin
        if(number == 4'd9)
            begin
                number <= 4'd0;
            end
            begin
            number <= number + 1'b1;
            case(number)
                4'd0:   /*adc low 4bit*/
                    begin
                        SegData <= leddata(segdata[3:0]);
                        SegCs <= 8'b11111110;
                    end
                4'd1:  /*adc high 4bit*/
                    begin
                        SegData <= leddata(segdata[7:4]);
                        SegCs <= 8'b11111101;
                    end
                4'd2:
                    begin
                        SegData <= leddata(4'd5);
                        SegCs <= 8'b11111011;
                    end
                4'd3:
                    begin
                        SegData <= leddata(4'd4);
                        SegCs <= 8'b11110111;
                    end
                4'd4:
                    begin
                        SegData <= leddata(4'd3);
                        SegCs <= 8'b11101111;
                    end
                4'd5:
                    begin
                        SegData <= leddata(4'd2);
                        SegCs <= 8'b11011111;
                    end
                4'd6:
                    begin
                        SegData <= leddata(4'd1);
                        SegCs <= 8'b10111111;
                    end
                4'd7:
                    begin
                        SegCs <= 8'b01111111;
                    end
            endcase
        end
    end
    begin
    counter <= counter + 1'b1;
    if(counter == 10'd1000)
        begin
            counter <= 10'd0;
            if(segdata[3:0] == 9)
                begin
                    segdata[3:0] <= 0;
                    if (segdata[7:4] == 5)
                        begin
                            segdata[7:4] <= 0;
                        end
                        begin
                            segdata[7:4] <= segdata[7:4] + 1'b1;
                        end
                end
                begin
                    segdata[3:0] <= segdata[3:0] + 1'b1;
                end
        end
    end
endmodule
 楼主| 发表于 2013-2-3 12:12:56 | 显示全部楼层
顶层原理图
GMT+8, 2024-5-30 10:23 , Processed in 0.162451 second(s), 28 queries .
