查看: 5211|回复: 3
[DSP] 【安富莱DSP教程】第8章 BasicMathFunctions的使用(一)
春暖花开
发表于 2015-3-18 10:55:41 | 显示全部楼层 |阅读模式
    本期教程开始学习ARM官方的DSP库,这里我们先从基本数学函数开始。本期教程主要讲绝对值,加法,点乘和乘法四种运算。
    8.1 绝对值(Vector Absolute Value)
    8.2 求和(Vector Addition)
    8.3 点乘(Vector Dot Product)
    8.4 乘法(Vector Multiplication)
    这部分函数主要用于求绝对值,公式描述如下:
    pDst[n] = abs(pSrc[n]),   0 <= n < blockSize.
    特别注意,这部分函数支持目标指针和源指针指向相同的缓冲区。
8.1.1 arm_abs_f32
    这个函数用于求32位浮点数的绝对值,源代码分析如下:
  1. /**
  2. * @brief Floating-point vector absolute value.                                                    (1)
  3. * @param[in]       *pSrc points to the input buffer
  4. * @param[out]      *pDst points to the output buffer
  5. * @param[in]       blockSize number of samples in each vector
  6. * @return none.
  7. */
  8. void arm_abs_f32(        (2)
  9.   float32_t * pSrc,
  10.   float32_t * pDst,
  11.   uint32_t blockSize)
  12. {
  13.   uint32_t blkCnt;                               /* loop counter */
  14. #ifndef ARM_MATH_CM0_FAMILY        (3)
  15.   /* Run the below code for Cortex-M4 and Cortex-M3 */
  16.   float32_t in1, in2, in3, in4;                  /* temporary variables */
  17.   /*loop Unrolling */
  18.   blkCnt = blockSize >> 2u;        (4)
  19.   /* First part of the processing with loop unrolling.  Compute 4 outputs at a time.
  20.    ** a second loop below computes the remaining 1 to 3 samples. */
  21.   while(blkCnt > 0u)
  22.   {
  23.     /* C = |A| */
  24.     /* Calculate absolute and then store the results in the destination buffer. */
  25.     /* read sample from source */
  26.     in1 = *pSrc;
  27.     in2 = *(pSrc + 1);
  28.     in3 = *(pSrc + 2);
  29.     /* find absolute value */
  30.     in1 = fabsf(in1);        (5)
  31.     /* read sample from source */
  32.     in4 = *(pSrc + 3);
  33.     /* find absolute value */
  34.     in2 = fabsf(in2);
  35.     /* read sample from source */
  36.     *pDst = in1;
  37.     /* find absolute value */
  38.     in3 = fabsf(in3);
  39.     /* find absolute value */
  40.     in4 = fabsf(in4);
  41.     /* store result to destination */
  42.     *(pDst + 1) = in2;
  43.     /* store result to destination */
  44.     *(pDst + 2) = in3;
  45.     /* store result to destination */
  46.     *(pDst + 3) = in4;
  47.     /* Update source pointer to process next sampels */                                            (6)
  48.     pSrc += 4u;
  49.     /* Update destination pointer to process next sampels */
  50.     pDst += 4u;
  51.     /* Decrement the loop counter */
  52.     blkCnt--;
  53.   }
  54.   /* If the blockSize is not a multiple of 4, compute any remaining output samples here.
  55.    ** No loop unrolling is used. */
  56.   blkCnt = blockSize % 0x4u;
  57. #else        (7)
  58.   /* Run the below code for Cortex-M0 */
  59.   /* Initialize blkCnt with number of samples */
  60.   blkCnt = blockSize;
  61. #endif /*   #ifndef ARM_MATH_CM0_FAMILY   */
  62.   while(blkCnt > 0u)        (8)
  63.   {
  64.     /* C = |A| */
  65.     /* Calculate absolute and then store the results in the destination buffer. */
  66.     *pDst++ = fabsf(*pSrc++);
  67.     /* Decrement the loop counter */
  68.     blkCnt--;
  69.   }
  70. }
1. 在这里简单的跟大家介绍一下DSP库中函数的通用格式,后面就不再赘述了。
    (1) 基本所有的函数都是可重入的。
    (2) 大部分函数都支持一组数的计算,比如这个函数arm_abs_f32就可以计算一组数的绝对值。所以如果只是就几个数的绝对值,用这个库函数就没有什么优势了。
    (3) 库函数基本是CM0,CM3和CM4都支持的(最新的DSP库已经添加CM7的支持)。
    (4) 每组数据基本上都是以4个数为一个单位进行计算,不够四个再单独计算。
    (5) 大部分函数都是配有f32,Q31,Q15和Q7四种格式。
2. 函数参数,支持输入一个数组进行计算绝对值。
3. 这部分代码是用于CM3和CM4内核。
4. 左移两位从而实现每4个数据为一组进行计算。
5. fabsf:这个函数不是用Cortex-M4F支持的DSP指令实现的,而是用C语言实现的,这个函数是被MDK封装起来的。
6. 切换到下一组数据。
7. 这部分代码用于CM0.
8. 用于不够4个数据的计算或者CM0内核。
8.1.2 arm_abs_q31
    这个函数用于求32位定点数的绝对值,源代码分析如下:
  1. /**
  2. * @brief Q31 vector absolute value.
  6. * @return none.
  7. *
  8. * <b>Scaling and Overflow Behavior:</b>                                                              (1)
  9. * \par
  10. * The function uses saturating arithmetic.
  11. * The Q31 value -1 (0x80000000) will be saturated to the maximum allowable positive value 0x7FFFFFFF.
  12. */
  13. void arm_abs_q31(
  14.   q31_t * pSrc,
  15.   q31_t * pDst,
  16.   uint32_t blockSize)
  17. {
  18.   uint32_t blkCnt;                               /* loop counter */
  19.   q31_t in;                                      /* Input value */
  20. #ifndef ARM_MATH_CM0_FAMILY
  21.   /* Run the below code for Cortex-M4 and Cortex-M3 */
  22.   q31_t in1, in2, in3, in4;
  23.   /*loop Unrolling */
  24.   blkCnt = blockSize >> 2u;
  25.   /* First part of the processing with loop unrolling.  Compute 4 outputs at a time.
  26.    ** a second loop below computes the remaining 1 to 3 samples. */
  27.   while(blkCnt > 0u)
  28.   {
  29.     /* C = |A| */
  30.     /* Calculate absolute of input (if -1 then saturated to 0x7fffffff) and then store the results in the destination buffer. */
  31.     in1 = *pSrc++;
  32.     in2 = *pSrc++;
  33.     in3 = *pSrc++;
  34.     in4 = *pSrc++;
  35.     *pDst++ = (in1 > 0) ? in1 : (q31_t)__QSUB(0, in1);                                              (2)
  36.     *pDst++ = (in2 > 0) ? in2 : (q31_t)__QSUB(0, in2);
  37.     *pDst++ = (in3 > 0) ? in3 : (q31_t)__QSUB(0, in3);
  38.     *pDst++ = (in4 > 0) ? in4 : (q31_t)__QSUB(0, in4);
  39.     /* Decrement the loop counter */
  40.     blkCnt--;
  41.   }
  42.   /* If the blockSize is not a multiple of 4, compute any remaining output samples here.
  43.    ** No loop unrolling is used. */
  44.   blkCnt = blockSize % 0x4u;
  45. #else
  46.   /* Run the below code for Cortex-M0 */
  47.   /* Initialize blkCnt with number of samples */
  48.   blkCnt = blockSize;
  49. #endif /*   #ifndef ARM_MATH_CM0_FAMILY   */
  50.   while(blkCnt > 0u)
  51.   {
  52.     /* C = |A| */
  53.     /* Calculate absolute value of the input (if -1 then saturated to 0x7fffffff) and then store the results in the destination buffer. */
  54.     in = *pSrc++;
  55.     *pDst++ = (in > 0) ? in : ((in == INT32_MIN) ? INT32_MAX : -in);
  56.     /* Decrement the loop counter */
  57.     blkCnt--;
  58.   }
  59. }
1. 这个函数使用了饱和运算,其实不光这个函数,后面很多函数都是使用了饱和运算的,关于什么是饱和运算,大家看Cortex-M3权威指南中文版的4.3.6 小节:汇编语言:饱和运算即可。
    对于Q31格式的数据,饱和运算会使得数据0x80000000变成0x7fffffff这个数比较特殊,算是特殊处理,记住即可)。
2. 这里重点说一下函数__QSUB,其实这个函数算是Cortex-M4/M3的一个指令,用于实现饱和减法。
    比如函数:__QSUB(0, in1) 的作用就是实现0 in1并返回结果。这里__QSUB实现的是32位数的饱和减法。还有__QSUB16和__QSUB8实现的是16位和8位数的减法。
8.1.3 arm_abs_q15
    这个函数用于求15位定点数的绝对值,源代码分析如下:
  1. /**
  2. * @brief Q15 vector absolute value.
  6. * @return none.
  7. *
  9. * \par
  11. * The Q15 value -1 (0x8000) will be saturated to the maximum allowable positive value 0x7FFF.       (1)
  12. */
  13. void arm_abs_q15(
  14.   q15_t * pSrc,
  15.   q15_t * pDst,
  17. {
  19. #ifndef ARM_MATH_CM0_FAMILY
  20.   __SIMD32_TYPE *simd;        (2)
  22.   q15_t in1;                                     /* Input value1 */
  23.   q15_t in2;                                     /* Input value2 */
  24.   /*loop Unrolling */
  25.   blkCnt = blockSize >> 2u;
  26.   /* First part of the processing with loop unrolling.  Compute 4 outputs at a time.
  27.    ** a second loop below computes the remaining 1 to 3 samples. */
  28.   simd = __SIMD32_CONST(pDst);        (3)
  29.   while(blkCnt > 0u)
  30.   {
  31.     /* C = |A| */
  32.     /* Read two inputs */
  33.     in1 = *pSrc++;
  34.     in2 = *pSrc++;
  35.     /* Store the Absolute result in the destination buffer by packing the two values, in a single cycle */
  36. #ifndef  ARM_MATH_BIG_ENDIAN
  37.     *simd++ =
  38.       __PKHBT(((in1 > 0) ? in1 : (q15_t)__QSUB16(0, in1)),                                           (4)
  39.               ((in2 > 0) ? in2 : (q15_t)__QSUB16(0, in2)), 16);
  40. #else
  41.     *simd++ =
  42.       __PKHBT(((in2 > 0) ? in2 : (q15_t)__QSUB16(0, in2)),
  43.               ((in1 > 0) ? in1 : (q15_t)__QSUB16(0, in1)), 16);
  44. #endif /* #ifndef  ARM_MATH_BIG_ENDIAN    */
  45.     in1 = *pSrc++;
  46.     in2 = *pSrc++;
  47. #ifndef  ARM_MATH_BIG_ENDIAN
  48.     *simd++ =
  49.       __PKHBT(((in1 > 0) ? in1 : (q15_t)__QSUB16(0, in1)),
  50.               ((in2 > 0) ? in2 : (q15_t)__QSUB16(0, in2)), 16);
  51. #else
  52.     *simd++ =
  53.       __PKHBT(((in2 > 0) ? in2 : (q15_t)__QSUB16(0, in2)),
  54.               ((in1 > 0) ? in1 : (q15_t)__QSUB16(0, in1)), 16);
  55. #endif /* #ifndef  ARM_MATH_BIG_ENDIAN    */
  57.     blkCnt--;
  58.   }
  59.   pDst = (q15_t *)simd;
  60.   /* If the blockSize is not a multiple of 4, compute any remaining output samples here.
  61.    ** No loop unrolling is used. */
  62.   blkCnt = blockSize % 0x4u;
  63.   while(blkCnt > 0u)
  64.   {
  65.     /* C = |A| */
  66.     /* Read the input */
  67.     in1 = *pSrc++;
  68.     /* Calculate absolute value of input and then store the result in the destination buffer. */
  69.     *pDst++ = (in1 > 0) ? in1 : (q15_t)__QSUB16(0, in1);
  70.     /* Decrement the loop counter */
  71.     blkCnt--;
  72.   }
  73. #else
  74.   /* Run the below code for Cortex-M0 */
  75.   q15_t in;                                      /* Temporary input variable */
  76.   /* Initialize blkCnt with number of samples */
  77.   blkCnt = blockSize;
  78.   while(blkCnt > 0u)
  79.   {
  80.     /* C = |A| */
  81.     /* Read the input */
  82.     in = *pSrc++;
  83.     /* Calculate absolute value of input and then store the result in the destination buffer. */
  84.     *pDst++ = (in > 0) ? in : ((in == (q15_t) 0x8000) ? 0x7fff : -in);
  85.     /* Decrement the loop counter */
  86.     blkCnt--;
  87.   }
  88. #endif /* #ifndef ARM_MATH_CM0_FAMILY */
  89. }
1. 对于Q15格式的数据,饱和运算会使得数据0x8000变成0x7fff
2. __SIMD32_TYPE的定义在文件arm_math.h中,具体定义如下:
    #define __SIMD32_TYPE int32_t __packed
    SIMD就是咱们上期教程所将的单指令多数据流简单的理解就是__SIMD32_TYPE就是定义了一个int32_t类型的数据,__packed的含义就是实现字节的对齐功能,方便两个16位数据的都存入到这个数据类型中。
3. 函数__SIMD32_CONST的定义如下:
    #define __SIMD32_CONST(addr)  ((__SIMD32_TYPE *)(addr))
4. 函数__PKHBT的定义在文件core_cm4_simd.h,定义如下:
    #define __PKHBT(ARG1,ARG2,ARG3)   ( ((((uint32_t)(ARG1)) ) & 0x0000FFFFUL) |  \
        ((((uint32_t)(ARG2)) << (ARG3)) & 0xFFFF0000UL) )
    这个宏定义的作用就是将将两个16位的数据合并成32位数据。但是有一点要特别说明__PKHBT也是CM4内核支持的SIMD指令,上面的宏定义的C函数会被MDK自动识别并调用相应的PKHBT指令。__QSUB16用于实现16位数据的饱和减法。
8.1.4 arm_abs_q7
    这个函数用于求8位定点数的绝对值,源代码分析如下:
  1. /**
  2. * @brief Q7 vector absolute value.
  6. * @return none.
  7. *
  8. * \par Conditions for optimum performance
  9. *  Input and output buffers should be aligned by 32-bit
  10. *
  11. *
  12. * <b>Scaling and Overflow Behavior:</b>                                                             (1)
  13. * \par
  14. * The function uses saturating arithmetic.
  15. * The Q7 value -1 (0x80) will be saturated to the maximum allowable positive value 0x7F.
  16. */
  17. void arm_abs_q7(
  18.   q7_t * pSrc,
  19.   q7_t * pDst,
  20.   uint32_t blockSize)
  21. {
  22.   uint32_t blkCnt;                               /* loop counter */
  23.   q7_t in;                                       /* Input value1 */
  24. #ifndef ARM_MATH_CM0_FAMILY
  25.   /* Run the below code for Cortex-M4 and Cortex-M3 */
  26.   q31_t in1, in2, in3, in4;                      /* temporary input variables */
  27.   q31_t out1, out2, out3, out4;                  /* temporary output variables */
  28.   /*loop Unrolling */
  29.   blkCnt = blockSize >> 2u;
  30.   /* First part of the processing with loop unrolling.  Compute 4 outputs at a time.
  31.    ** a second loop below computes the remaining 1 to 3 samples. */
  32.   while(blkCnt > 0u)
  33.   {
  34.     /* C = |A| */
  35.     /* Read inputs */
  36.     in1 = (q31_t) * pSrc;
  37.     in2 = (q31_t) * (pSrc + 1);
  38.     in3 = (q31_t) * (pSrc + 2);
  40.     out1 = (in1 > 0) ? in1 : (q31_t)__QSUB8(0, in1);                                                  (2)
  41.     /* read input */
  42.     in4 = (q31_t) * (pSrc + 3);
  43.     /* find absolute value */
  44.     out2 = (in2 > 0) ? in2 : (q31_t)__QSUB8(0, in2);
  46.     *pDst = (q7_t) out1;
  47.     /* find absolute value */
  48.     out3 = (in3 > 0) ? in3 : (q31_t)__QSUB8(0, in3);
  49.     /* find absolute value */
  50.     out4 = (in4 > 0) ? in4 : (q31_t)__QSUB8(0, in4);
  51.     /* store result to destination */
  52.     *(pDst + 1) = (q7_t) out2;
  53.     /* store result to destination */
  54.     *(pDst + 2) = (q7_t) out3;
  55.     /* store result to destination */
  56.     *(pDst + 3) = (q7_t) out4;
  57.     /* update pointers to process next samples */
  58.     pSrc += 4u;
  59.     pDst += 4u;
  60.     /* Decrement the loop counter */
  61.     blkCnt--;
  62.   }
  63.   /* If the blockSize is not a multiple of 4, compute any remaining output samples here.
  64.    ** No loop unrolling is used. */
  65.   blkCnt = blockSize % 0x4u;
  66. #else
  67.   /* Run the below code for Cortex-M0 */
  68.   blkCnt = blockSize;
  69. #endif //      #define ARM_MATH_CM0_FAMILY
  70.   while(blkCnt > 0u)
  71.   {
  72.     /* C = |A| */
  73.     /* Read the input */
  74.     in = *pSrc++;
  75.     /* Store the Absolute result in the destination buffer */
  76.     *pDst++ = (in > 0) ? in : ((in == (q7_t) 0x80) ? 0x7f : -in);
  77.     /* Decrement the loop counter */
  78.     blkCnt--;
  79.   }
  80. }
1. 由于饱和运算,0x80求绝对值将变成数据0x7F。
2. __QSUB8用以实现8位数的饱和减法运算。
8.1.5 实例讲解
实验目的:
    1. 四种数据类型数据绝对值求解
实验内容:
    1. 按下按键K1, 串口打印输出结果
实验现象:
    通过窗口上位机软件SecureCRT(V5光盘里面有此软件)查看打印信息现象如下:
程序设计:
  1. /*
  3. *    函 数 名: DSP_ABS
  4. *    功能说明: 求绝对值
  5. *    形    参:无
  6. *    返 回 值: 无
  8. */
  9. static void DSP_ABS(void)
  10. {
  11. static float32_t pSrc;
  12.     static float32_t pDst;
  13. static q31_t pSrc1;
  14. static q31_t pDst1;
  15. static q15_t pSrc2;
  16. static q15_t pDst2;
  17. static q7_t pSrc3 = 127; /* 为了说明问题,在这里设置初始值为127,然后查看0x80是否饱和为0x7F */
  18. static q7_t pDst3;
  19. pSrc -= 1.23f;
  20. arm_abs_f32(&pSrc, &pDst, 1);        (1)
  21. printf("arm_abs_f32 = %f\r\n", pDst);
  22. pSrc1 -= 1;
  23. arm_abs_q31(&pSrc1, &pDst1, 1);        (2)
  24. printf("arm_abs_q31 = %d\r\n", pDst1);
  25. pSrc2 -= 1;
  26. arm_abs_q15(&pSrc2, &pDst2, 1);        (3)
  27. printf("arm_abs_q15 = %d\r\n", pDst2);
  28. pSrc3 += 1;
  29. printf("pSrc3 = %d\r\n", pSrc3);
  30. arm_abs_q7(&pSrc3, &pDst3, 1);        (4)
  31. printf("arm_abs_q7 = %d\r\n", pDst3);
  32. printf("***********************************\r\n");
  33. }
(1)到(4)实现相应格式下绝对值的求解。这里只求了一个数,大家可以尝试求解一个数组的绝对值。
努力打造安富莱高质量微信公众号:点击扫描图片关注
春暖花开
 楼主| 发表于 2015-3-18 10:59:20 | 显示全部楼层
    这部分函数主要用于求和,公式描述如下:
    pDst[n] = pSrcA[n] + pSrcB[n],   0 <= n < blockSize.
8.2.1 arm_add_f32
    这个函数用于求32位浮点数的和,源代码分析如下:
  1. /**
  2. * @brief Floating-point vector addition.
  3. * @param[in] *pSrcA points to the first input vector
  4. * @param[in] *pSrcB points to the second input vector
  5. * @param[out] *pDst points to the output vector
  6. * @param[in] blockSize number of samples in each vector
  7. * @return none.
  8. */
  9. void arm_add_f32(
  10. float32_t * pSrcA,
  11. float32_t * pSrcB,
  12. float32_t * pDst,
  13. uint32_t blockSize)
  14. {
  15. uint32_t blkCnt; /* loop counter */
  16. #ifndef ARM_MATH_CM0_FAMILY
  17. /* Run the below code for Cortex-M4 and Cortex-M3 */
  18. float32_t inA1, inA2, inA3, inA4; /* temporary input variabels */
  19. float32_t inB1, inB2, inB3, inB4; /* temporary input variables */
  20. /*loop Unrolling */
  21. blkCnt = blockSize >> 2u;
  22. /* First part of the processing with loop unrolling. Compute 4 outputs at a time.
  23. ** a second loop below computes the remaining 1 to 3 samples. */
  24. while(blkCnt > 0u)
  25. {
  26. /* C = A + B */
  27. /* Add and then store the results in the destination buffer. */
  28. /* read four inputs from sourceA and four inputs from sourceB */
  29. inA1 = *pSrcA;
  30. inB1 = *pSrcB;
  31. inA2 = *(pSrcA + 1);
  32. inB2 = *(pSrcB + 1);
  33. inA3 = *(pSrcA + 2);
  34. inB3 = *(pSrcB + 2);
  35. inA4 = *(pSrcA + 3);
  36. inB4 = *(pSrcB + 3);
  37. /* C = A + B */ (1)
  38. /* add and store result to destination */
  39. *pDst = inA1 + inB1;
  40. *(pDst + 1) = inA2 + inB2;
  41. *(pDst + 2) = inA3 + inB3;
  42. *(pDst + 3) = inA4 + inB4;
  43. /* update pointers to process next samples */
  44. pSrcA += 4u;
  45. pSrcB += 4u;
  46. pDst += 4u;
  47. /* Decrement the loop counter */
  48. blkCnt--;
  49. }
  50. /* If the blockSize is not a multiple of 4, compute any remaining output samples here.
  51. ** No loop unrolling is used. */
  52. blkCnt = blockSize % 0x4u;
  53. #else
  54. /* Run the below code for Cortex-M0 */
  55. /* Initialize blkCnt with number of samples */
  56. blkCnt = blockSize;
  57. #endif /* #ifndef ARM_MATH_CM0_FAMILY */
  58. while(blkCnt > 0u)
  59. {
  60. /* C = A + B */
  61. /* Add and then store the results in the destination buffer. */
  62. *pDst++ = (*pSrcA++) + (*pSrcB++);
  63. /* Decrement the loop counter */
  64. blkCnt--;
  65. }
  66. }
1. 这部分的代码比较简单,只是求解两个数的和。
8.2.2 arm_add_q31
    这个函数用于求32位定点数的和,源代码分析如下:
  1. /**
  2. * @brief Q31 vector addition.
  7. * @return none.
  8. *
  9. * <b>Scaling and Overflow Behavior:</b> (1)
  10. * \\par
  11. * The function uses saturating arithmetic.
  12. * Results outside of the allowable Q31 range[0x80000000 0x7FFFFFFF] will be saturated.
  13. */
  14. void arm_add_q31(
  15. q31_t * pSrcA,
  16. q31_t * pSrcB,
  17. q31_t * pDst,
  18. uint32_t blockSize)
  19. {
  20. uint32_t blkCnt; /* loop counter */
  21. #ifndef ARM_MATH_CM0_FAMILY
  22. /* Run the below code for Cortex-M4 and Cortex-M3 */
  23. q31_t inA1, inA2, inA3, inA4;
  24. q31_t inB1, inB2, inB3, inB4;
  25. /*loop Unrolling */
  26. blkCnt = blockSize >> 2u;
  27. /* First part of the processing with loop unrolling. Compute 4 outputs at a time.
  28. ** a second loop below computes the remaining 1 to 3 samples. */
  30. {
  31. /* C = A + B */
  32. /* Add and then store the results in the destination buffer. */
  33. inA1 = *pSrcA++;
  34. inA2 = *pSrcA++;
  35. inB1 = *pSrcB++;
  36. inB2 = *pSrcB++;
  37. inA3 = *pSrcA++;
  38. inA4 = *pSrcA++;
  39. inB3 = *pSrcB++;
  40. inB4 = *pSrcB++;
  41. *pDst++ = __QADD(inA1, inB1); (2)
  42. *pDst++ = __QADD(inA2, inB2);
  43. *pDst++ = __QADD(inA3, inB3);
  44. *pDst++ = __QADD(inA4, inB4);
  45. /* Decrement the loop counter */
  46. blkCnt--;
  47. }
  48. /* If the blockSize is not a multiple of 4, compute any remaining output samples here.
  49. ** No loop unrolling is used. */
  50. blkCnt = blockSize % 0x4u;
  51. while(blkCnt > 0u)
  52. {
  53. /* C = A + B */
  54. /* Add and then store the results in the destination buffer. */
  55. *pDst++ = __QADD(*pSrcA++, *pSrcB++);
  57. blkCnt--;
  58. }
  59. #else
  60. /* Run the below code for Cortex-M0 */
  61. /* Initialize blkCnt with number of samples */
  62. blkCnt = blockSize;
  64. {
  65. /* C = A + B */
  66. /* Add and then store the results in the destination buffer. */
  67. *pDst++ = (q31_t) clip_q63_to_q31((q63_t) * pSrcA++ + *pSrcB++); (3)
  68. /* Decrement the loop counter */
  69. blkCnt--;
  70. }
  71. #endif /* #ifndef ARM_MATH_CM0_FAMILY */
  72. }
1. 这个函数也是饱和运算,输出结果的范[0x80000000 0x7FFFFFFF],超出这个结果将产生饱和结果。
2. __QADD实现32位数的加法。
3. 函数clip_q63_to_q31的定义在文件arm_math.h里面
      static __INLINE q31_t clip_q63_to_q31(
      q63_t x)
          return ((q31_t) (x >> 32) != ((q31_t) x >> 31)) ?
            ((0x7FFFFFFF ^ ((q31_t) (x >> 63)))) : (q31_t) x;
    这个函数的作用是实现饱和结果。
8.2.3 arm_add_q15
    这个函数用于求16位定点数的和,源代码分析如下:
  1. /**
  2. * @brief Q15 vector addition.
  7. * @return none.
  8. *
  10. * \\par
  12. * Results outside of the allowable Q15 range [0x8000 0x7FFF] will be saturated.
  13. */
  14. void arm_add_q15(
  15. q15_t * pSrcA,
  16. q15_t * pSrcB,
  17. q15_t * pDst,
  19. {
  23. q31_t inA1, inA2, inB1, inB2;
  28. while(blkCnt > 0u)
  29. {
  30. /* C = A + B */ (2)
  31. /* Add and then store the results in the destination buffer. */
  32. inA1 = *__SIMD32(pSrcA)++;
  33. inA2 = *__SIMD32(pSrcA)++;
  34. inB1 = *__SIMD32(pSrcB)++;
  35. inB2 = *__SIMD32(pSrcB)++;
  36. *__SIMD32(pDst)++ = __QADD16(inA1, inB1);
  37. *__SIMD32(pDst)++ = __QADD16(inA2, inB2);
  38. /* Decrement the loop counter */
  39. blkCnt--;
  40. }
  41. /* If the blockSize is not a multiple of 4, compute any remaining output samples here.
  42. ** No loop unrolling is used. */
  43. blkCnt = blockSize % 0x4u;
  44. while(blkCnt > 0u)
  45. {
  46. /* C = A + B */
  47. /* Add and then store the results in the destination buffer. */
  48. *pDst++ = (q15_t) __QADD16(*pSrcA++, *pSrcB++);
  49. /* Decrement the loop counter */
  50. blkCnt--;
  51. }
  52. #else
  53. /* Run the below code for Cortex-M0 */
  54. /* Initialize blkCnt with number of samples */
  55. blkCnt = blockSize;
  56. while(blkCnt > 0u)
  57. {
  58. /* C = A + B */
  59. /* Add and then store the results in the destination buffer. */
  60. *pDst++ = (q15_t) __SSAT(((q31_t) * pSrcA++ + *pSrcB++), 16); (3)
  61. /* Decrement the loop counter */
  62. blkCnt--;
  63. }
  64. #endif /* #ifndef ARM_MATH_CM0_FAMILY */
  65. }
1. 这个函数也是饱和运算,输出结果的范[0x8000 0x7FFF],超出这个结果将产生饱和结果。
2. 函数inA1 = *__SIMD32(pSrcA)++仅需要一条SIMD指令即可完成将两个16位数存到32位的变量inA1中。
3. __SSAT也是SIMD指令,这里是将结果饱和到16位精度。
8.2.4 arm_add_q7
  1. /**
  2. * @brief Q7 vector addition.
  7. * @return none.
  8. *
  10. * \\par
  12. * Results outside of the allowable Q7 range [0x80 0x7F] will be saturated.
  13. */
  14. void arm_add_q7(
  15. q7_t * pSrcA,
  16. q7_t * pSrcB,
  17. q7_t * pDst,
  19. {
  28. {
  29. /* C = A + B */
  30. /* Add and then store the results in the destination buffer. */ (2)
  31. *__SIMD32(pDst)++ = __QADD8(*__SIMD32(pSrcA)++, *__SIMD32(pSrcB)++);
  32. /* Decrement the loop counter */
  33. blkCnt--;
  34. }
  35. /* If the blockSize is not a multiple of 4, compute any remaining output samples here.
  36. ** No loop unrolling is used. */
  37. blkCnt = blockSize % 0x4u;
  38. while(blkCnt > 0u)
  39. {
  40. /* C = A + B */
  41. /* Add and then store the results in the destination buffer. */
  42. *pDst++ = (q7_t) __SSAT(*pSrcA++ + *pSrcB++, 8);
  43. /* Decrement the loop counter */
  44. blkCnt--;
  45. }
  46. #else
  47. /* Run the below code for Cortex-M0 */
  48. /* Initialize blkCnt with number of samples */
  49. blkCnt = blockSize;
  51. {
  52. /* C = A + B */
  53. /* Add and then store the results in the destination buffer. */
  54. *pDst++ = (q7_t) __SSAT((q15_t) * pSrcA++ + *pSrcB++, 8);
  55. /* Decrement the loop counter */
  56. blkCnt--;
  57. }
  58. #endif /* #ifndef ARM_MATH_CM0_FAMILY */
  59. }
1. 这个函数也是饱和运算,输出结果的范[0x80 0x7F],超出这个结果将产生饱和。
2. 这里通过SIMD指令实现4组8位数的加法。
8.2.5 实例讲解
实验目的:
    1. 四种类似数据的求和
实验内容:
    1. 按下按键K2, 串口打印输出结果
实验现象:
程序设计:
  1. /*
  3. *    函 数 名: DSP_ABS
  4. *    功能说明: 加法
  5. *    形 参:无
  6. *    返 回 值: 无
  8. */
  9. static void DSP_Add(void)
  10. {
  11. static float32_t pSrcA;
  12. static float32_t pSrcB;
  13. static float32_t pDst;
  14. static q31_t pSrcA1;
  15. static q31_t pSrcB1;
  16. static q31_t pDst1;
  17. static q15_t pSrcA2;
  18. static q15_t pSrcB2;
  19. static q15_t pDst2;
  20. static q7_t pSrcA3;
  21. static q7_t pSrcB3;
  22. static q7_t pDst3;
  23. pSrcA--;
  24. arm_add_f32(&pSrcA, &pSrcB, &pDst, 1);
  25. printf("arm_add_f32 = %f\\r\\n", pDst);
  26. pSrcA1--;
  27. arm_add_q31(&pSrcA1, &pSrcB1, &pDst1, 1);
  28. printf("arm_add_q31 = %d\\r\\n", pDst1);
  29. pSrcA2--;
  30. arm_add_q15(&pSrcA2, &pSrcB2, &pDst2, 1);
  31. printf("arm_add_q15 = %d\\r\\n", pDst2);
  32. pSrcA3--;
  33. arm_add_q7(&pSrcA3, &pSrcB3, &pDst3, 1);
  34. printf("arm_add_q7 = %d\\r\\n", pDst3);
  35. printf("***********************************\\r\\n");
  36. }
春暖花开
 楼主| 发表于 2015-3-18 11:02:20 | 显示全部楼层
    这部分函数主要用于点乘,公式描述如下:
sum = pSrcA[0]*pSrcB[0] + pSrcA[1]*pSrcB[1] + ... + pSrcA[blockSize-1]*pSrcB[blockSize-1]
8.3.1 arm_dot_prod_f32
    这个函数用于求32位浮点数的点乘,源代码分析如下:
  1. /**
  2. * @defgroup dot_prod Vector Dot Product
  3. *
  4. * Computes the dot product of two vectors.
  5. * The vectors are multiplied element-by-element and then summed.
  6. *
  7. * <pre>
  8. * sum = pSrcA[0]*pSrcB[0] + pSrcA[1]*pSrcB[1] + ... + pSrcA[blockSize-1]*pSrcB[blockSize-1]
  9. * </pre>
  10. *
  11. * There are separate functions for floating-point, Q7, Q15, and Q31 data types.
  12. */
  13. /**
  14. * @addtogroup dot_prod
  15. * @{
  16. */
  17. /**
  18. * @brief Dot product of floating-point vectors.
  19. * @param[in] *pSrcA points to the first input vector
  20. * @param[in] *pSrcB points to the second input vector
  21. * @param[in] blockSize number of samples in each vector
  22. * @param[out] *result output result returned here
  23. * @return none.
  24. */
  25. void arm_dot_prod_f32(
  26. float32_t * pSrcA,
  27. float32_t * pSrcB,
  28. uint32_t blockSize,
  29. float32_t * result)
  30. {
  31. float32_t sum = 0.0f; /* Temporary result storage */ (1)
  32. uint32_t blkCnt; /* loop counter */
  33. #ifndef ARM_MATH_CM0_FAMILY
  34. /* Run the below code for Cortex-M4 and Cortex-M3 */
  35. /*loop Unrolling */
  36. blkCnt = blockSize >> 2u;
  37. /* First part of the processing with loop unrolling. Compute 4 outputs at a time.
  38. ** a second loop below computes the remaining 1 to 3 samples. */
  39. while(blkCnt > 0u)
  40. {
  41. /* C = A[0]* B[0] + A[1]* B[1] + A[2]* B[2] + .....+ A[blockSize-1]* B[blockSize-1] */
  42. /* Calculate dot product and then store the result in a temporary buffer */
  43. sum += (*pSrcA++) * (*pSrcB++); (2)
  44. sum += (*pSrcA++) * (*pSrcB++);
  45. sum += (*pSrcA++) * (*pSrcB++);
  46. sum += (*pSrcA++) * (*pSrcB++);
  48. blkCnt--;
  49. }
  53. #else
  59. {
  60. /* C = A[0]* B[0] + A[1]* B[1] + A[2]* B[2] + .....+ A[blockSize-1]* B[blockSize-1] */
  61. /* Calculate dot product and then store the result in a temporary buffer. */
  62. sum += (*pSrcA++) * (*pSrcB++);
  64. blkCnt--;
  65. }
  66. /* Store the result back in the destination buffer */
  67. *result = sum;
  68. }
1. 由于CM4上带的FPU是单精度的,所以初始化float32_t类型的浮点数时需要在数据的末尾加上f。
2. 类似函数sum += (*pSrcA++) * (*pSrcB++)最终会通过浮点的MAC(乘累加)实现,从而加快执行时间。
8.3.2 arm_dot_prod_q31
    这个函数用于求32位定点数的点乘,源代码分析如下:
  1. /**
  2. * @brief Dot product of Q31 vectors.
  6. * @param[out] *result output result returned here
  7. * @return none.
  8. *
  10. * \\par
  11. * The intermediate multiplications are in 1.31 x 1.31 = 2.62 format and these
  12. * are truncated to 2.48 format by discarding the lower 14 bits.
  13. * The 2.48 result is then added without saturation to a 64-bit accumulator in 16.48 format.
  14. * There are 15 guard bits in the accumulator and there is no risk of overflow as long as
  15. * the length of the vectors is less than 2^16 elements.
  16. * The return result is in 16.48 format.
  17. */
  18. void arm_dot_prod_q31(
  19. q31_t * pSrcA,
  20. q31_t * pSrcB,
  21. uint32_t blockSize,
  22. q63_t * result)
  23. {
  24. q63_t sum = 0; /* Temporary result storage */
  25. uint32_t blkCnt; /* loop counter */
  26. #ifndef ARM_MATH_CM0_FAMILY
  27. /* Run the below code for Cortex-M4 and Cortex-M3 */
  28. q31_t inA1, inA2, inA3, inA4;
  29. q31_t inB1, inB2, inB3, inB4;
  30. /*loop Unrolling */
  31. blkCnt = blockSize >> 2u;
  32. /* First part of the processing with loop unrolling. Compute 4 outputs at a time.
  33. ** a second loop below computes the remaining 1 to 3 samples. */
  34. while(blkCnt > 0u)
  35. {
  36. /* C = A[0]* B[0] + A[1]* B[1] + A[2]* B[2] + .....+ A[blockSize-1]* B[blockSize-1] */
  37. /* Calculate dot product and then store the result in a temporary buffer. */
  38. inA1 = *pSrcA++;
  39. inA2 = *pSrcA++;
  40. inA3 = *pSrcA++;
  41. inA4 = *pSrcA++;
  42. inB1 = *pSrcB++;
  43. inB2 = *pSrcB++;
  44. inB3 = *pSrcB++;
  45. inB4 = *pSrcB++;
  46. sum += ((q63_t) inA1 * inB1) >> 14u; (2)
  47. sum += ((q63_t) inA2 * inB2) >> 14u;
  48. sum += ((q63_t) inA3 * inB3) >> 14u;
  49. sum += ((q63_t) inA4 * inB4) >> 14u;
  50. /* Decrement the loop counter */
  51. blkCnt--;
  52. }
  53. /* If the blockSize is not a multiple of 4, compute any remaining output samples here.
  54. ** No loop unrolling is used. */
  55. blkCnt = blockSize % 0x4u;
  56. #else
  57. /* Run the below code for Cortex-M0 */
  58. /* Initialize blkCnt with number of samples */
  59. blkCnt = blockSize;
  60. #endif /* #ifndef ARM_MATH_CM0_FAMILY */
  61. while(blkCnt > 0u)
  62. {
  63. /* C = A[0]* B[0] + A[1]* B[1] + A[2]* B[2] + .....+ A[blockSize-1]* B[blockSize-1] */
  64. /* Calculate dot product and then store the result in a temporary buffer. */
  65. sum += ((q63_t) * pSrcA++ * *pSrcB++) >> 14u;
  66. /* Decrement the loop counter */
  67. blkCnt--;
  68. }
  69. /* Store the result in the destination buffer in 16.48 format */
  70. *result = sum;
  71. }
1. 两个Q31格式的32位数相乘,那么输出结果的格式是1.31*1.31 = 2.62。实际应用中基本不需要这么高的精度,这个函数将低14位的数据截取掉,反应在函数中就是两个数的乘积左移14位,也就是定点数的小数点也左移14位,那么最终的结果的格式是16.48。所以只要乘累加的个数小于2^16就没有输出结果溢出的危险(不知道这里为什么不是2^14,留作以后解决)。
2. 将获取的结果左移14位。
8.3.3 arm_dot_prod_q15
    这个函数用于求16位定点数的点乘,源代码分析如下:
  1. /**
  2. * @brief Dot product of Q15 vectors.
  7. * @return none.
  8. *
  10. * \\par
  11. * The intermediate multiplications are in 1.15 x 1.15 = 2.30 format and these
  12. * results are added to a 64-bit accumulator in 34.30 format.
  13. * Nonsaturating additions are used and given that there are 33 guard bits in the accumulator
  14. * there is no risk of overflow.
  15. * The return result is in 34.30 format.
  16. */
  17. void arm_dot_prod_q15(
  18. q15_t * pSrcA,
  19. q15_t * pSrcB,
  20. uint32_t blockSize,
  21. q63_t * result)
  22. {
  23. q63_t sum = 0; /* Temporary result storage */
  24. uint32_t blkCnt; /* loop counter */
  25. #ifndef ARM_MATH_CM0_FAMILY
  26. /* Run the below code for Cortex-M4 and Cortex-M3 */
  27. /*loop Unrolling */
  28. blkCnt = blockSize >> 2u;
  29. /* First part of the processing with loop unrolling. Compute 4 outputs at a time.
  30. ** a second loop below computes the remaining 1 to 3 samples. */
  31. while(blkCnt > 0u)
  32. {
  33. /* C = A[0]* B[0] + A[1]* B[1] + A[2]* B[2] + .....+ A[blockSize-1]* B[blockSize-1] */ (2)
  34. /* Calculate dot product and then store the result in a temporary buffer. */
  35. sum = __SMLALD(*__SIMD32(pSrcA)++, *__SIMD32(pSrcB)++, sum);
  36. sum = __SMLALD(*__SIMD32(pSrcA)++, *__SIMD32(pSrcB)++, sum);
  37. /* Decrement the loop counter */
  38. blkCnt--;
  39. }
  40. /* If the blockSize is not a multiple of 4, compute any remaining output samples here.
  41. ** No loop unrolling is used. */
  42. blkCnt = blockSize % 0x4u;
  43. while(blkCnt > 0u)
  44. {
  45. /* C = A[0]* B[0] + A[1]* B[1] + A[2]* B[2] + .....+ A[blockSize-1]* B[blockSize-1] */
  46. /* Calculate dot product and then store the results in a temporary buffer. */
  47. sum = __SMLALD(*pSrcA++, *pSrcB++, sum);
  48. /* Decrement the loop counter */
  49. blkCnt--;
  50. }
  51. #else
  52. /* Run the below code for Cortex-M0 */
  53. /* Initialize blkCnt with number of samples */
  54. blkCnt = blockSize;
  55. while(blkCnt > 0u)
  56. {
  57. /* C = A[0]* B[0] + A[1]* B[1] + A[2]* B[2] + .....+ A[blockSize-1]* B[blockSize-1] */
  58. /* Calculate dot product and then store the results in a temporary buffer. */
  59. sum += (q63_t) ((q31_t) * pSrcA++ * *pSrcB++);
  61. blkCnt--;
  62. }
  63. #endif /* #ifndef ARM_MATH_CM0_FAMILY */
  64. /* Store the result in the destination buffer in 34.30 format */
  65. *result = sum;
  66. }
1. 两个Q15格式的数据相乘,那么输出结果的格式是1.15*1.15 = 2.30,这个函数将输出结果赋值给了64位变量,那么输出结果就是34.30格式。所以基本没有溢出的危险。
2. __SMLALD也是SIMD指令,实现两个16位数相乘,并把结果累加给64位变量。
8.3.4 arm_dot_prod_q7
    这个函数用于求8位定点数的点乘,源代码分析如下:
  1. /**
  2. * @brief Dot product of Q7 vectors.
  7. * @return none.
  8. *
  10. * \\par
  11. * The intermediate multiplications are in 1.7 x 1.7 = 2.14 format and these
  12. * results are added to an accumulator in 18.14 format.
  13. * Nonsaturating additions are used and there is no danger of wrap around as long as
  14. * the vectors are less than 2^18 elements long.
  15. * The return result is in 18.14 format.
  16. */
  17. void arm_dot_prod_q7(
  18. q7_t * pSrcA,
  19. q7_t * pSrcB,
  21. q31_t * result)
  22. {
  23. uint32_t blkCnt; /* loop counter */
  24. q31_t sum = 0; /* Temporary variables to store output */
  27. q31_t input1, input2; /* Temporary variables to store input */
  28. q31_t inA1, inA2, inB1, inB2; /* Temporary variables to store input */
  29. /*loop Unrolling */
  30. blkCnt = blockSize >> 2u;
  31. /* First part of the processing with loop unrolling. Compute 4 outputs at a time.
  32. ** a second loop below computes the remaining 1 to 3 samples. */
  33. while(blkCnt > 0u)
  34. {
  35. /* read 4 samples at a time from sourceA */ (2)
  36. input1 = *__SIMD32(pSrcA)++;
  37. /* read 4 samples at a time from sourceB */
  38. input2 = *__SIMD32(pSrcB)++;
  39. /* extract two q7_t samples to q15_t samples */
  40. inA1 = __SXTB16(__ROR(input1, 8)); (3)
  41. /* extract reminaing two samples */
  42. inA2 = __SXTB16(input1);
  43. /* extract two q7_t samples to q15_t samples */
  44. inB1 = __SXTB16(__ROR(input2, 8));
  45. /* extract reminaing two samples */
  46. inB2 = __SXTB16(input2);
  47. /* multiply and accumulate two samples at a time */
  48. sum = __SMLAD(inA1, inB1, sum); (4)
  49. sum = __SMLAD(inA2, inB2, sum);
  51. blkCnt--;
  52. }
  57. {
  58. /* C = A[0]* B[0] + A[1]* B[1] + A[2]* B[2] + .....+ A[blockSize-1]* B[blockSize-1] */
  59. /* Dot product and then store the results in a temporary buffer. */
  60. sum = __SMLAD(*pSrcA++, *pSrcB++, sum);
  62. blkCnt--;
  63. }
  64. #else
  65. /* Run the below code for Cortex-M0 */
  66. /* Initialize blkCnt with number of samples */
  67. blkCnt = blockSize;
  68. while(blkCnt > 0u)
  69. {
  70. /* C = A[0]* B[0] + A[1]* B[1] + A[2]* B[2] + .....+ A[blockSize-1]* B[blockSize-1] */
  71. /* Dot product and then store the results in a temporary buffer. */
  72. sum += (q31_t) ((q15_t) * pSrcA++ * *pSrcB++);
  73. /* Decrement the loop counter */
  74. blkCnt--;
  75. }
  76. #endif /* #ifndef ARM_MATH_CM0_FAMILY */
  77. /* Store the result in the destination buffer in 18.14 format */
  78. *result = sum;
  79. }
1. 两个Q8格式的数据相乘,那么输出结果就是1.7*1.7 = 2.14格式。这里将最终结果赋值给了32位的变量,那么最终的格式就是18.14。如果乘累加的个数小于2^18那么就不会有溢出的危险(感觉这里应该是2^16)。
2. 一次读取4个8位的数据。
3. __SXTB16也是SIMD指令,用于将两个8位的有符号数扩展成16位。__ROR用于实现数据的循环右移。
4. __SMLAD也是SIMD指令,用于实现如下功能:
    sum = __SMLAD(x, y, z)
    sum = z + ((short)(x>>16) * (short)(y>>16)) + ((short)x * (short)y)
8.3.5 实例讲解
实验目的:
    1. 四种类型数据的点乘。
实验内容:
    1. 按下按键K3, 串口打印输出结果
实验现象:
程序设计:
  1. /*
  3. *    函 数 名: DSP_DotProduct
  4. *    功能说明: 乘积
  5. *    形 参:无
  6. *    返 回 值: 无
  8. */
  9. static void DSP_DotProduct(void)
  10. {
  11. static float32_t pSrcA[5] = {1.0f,1.0f,1.0f,1.0f,1.0f};
  12. static float32_t pSrcB[5] = {1.0f,1.0f,1.0f,1.0f,1.0f};
  13. static float32_t result;
  14. static q31_t pSrcA1[5] = {0x7ffffff0,1,1,1,1};
  15. static q31_t pSrcB1[5] = {1,1,1,1,1};
  16. static q63_t result1;
  17. static q15_t pSrcA2[5] = {1,1,1,1,1};
  18. static q15_t pSrcB2[5] = {1,1,1,1,1};
  19. static q63_t result2;
  20. static q7_t pSrcA3[5] = {1,1,1,1,1};
  21. static q7_t pSrcB3[5] = {1,1,1,1,1};
  22. static q31_t result3;
  23. pSrcA[0] -= 1.1f;
  24. arm_dot_prod_f32(pSrcA, pSrcB, 5, &result);
  25. printf("arm_dot_prod_f32 = %f\\r\\n", result);
  26. pSrcA1[0] -= 0xffff;
  27. arm_dot_prod_q31(pSrcA1, pSrcB1, 5, &result1);
  28. printf("arm_dot_prod_q31 = %lld\\r\\n", result1);
  29. pSrcA2[0] -= 1;
  30. arm_dot_prod_q15(pSrcA2, pSrcB2, 5, &result2);
  31. printf("arm_dot_prod_q15 = %lld\\r\\n", result2);
  32. pSrcA3[0] -= 1;
  33. arm_dot_prod_q7(pSrcA3, pSrcB3, 5, &result3);
  34. printf("arm_dot_prod_q7 = %d\\r\\n", result3);
  36. }
春暖花开
 楼主| 发表于 2015-3-18 11:04:55 | 显示全部楼层
    这部分函数主要用于乘法,公式描述如下:
    pDst[n] = pSrcA[n] * pSrcB[n],   0 <= n < blockSize.
8.4.1 arm_mult_f32
      这个函数用于求32位浮点数的乘法,源代码分析如下:
  1. /**
  2. * @brief Floating-point vector multiplication.
  7. * @return none.
  8. */
  9. void arm_mult_f32(
  14. {
  15. uint32_t blkCnt; /* loop counters */
  18. float32_t inA1, inA2, inA3, inA4; /* temporary input variables */
  20. float32_t out1, out2, out3, out4; /* temporary output variables */
  21. /* loop Unrolling */
  22. blkCnt = blockSize >> 2u;
  23. /* First part of the processing with loop unrolling. Compute 4 outputs at a time.
  24. ** a second loop below computes the remaining 1 to 3 samples. */
  25. while(blkCnt > 0u)
  26. {
  27. /* C = A * B */
  28. /* Multiply the inputs and store the results in output buffer */ (1)
  29. /* read sample from sourceA */
  30. inA1 = *pSrcA;
  31. /* read sample from sourceB */
  32. inB1 = *pSrcB;
  33. /* read sample from sourceA */
  34. inA2 = *(pSrcA + 1);
  35. /* read sample from sourceB */
  36. inB2 = *(pSrcB + 1);
  37. /* out = sourceA * sourceB */
  38. out1 = inA1 * inB1;
  39. /* read sample from sourceA */
  40. inA3 = *(pSrcA + 2);
  41. /* read sample from sourceB */
  42. inB3 = *(pSrcB + 2);
  43. /* out = sourceA * sourceB */
  44. out2 = inA2 * inB2;
  45. /* read sample from sourceA */
  46. inA4 = *(pSrcA + 3);
  47. /* store result to destination buffer */
  48. *pDst = out1;
  49. /* read sample from sourceB */
  50. inB4 = *(pSrcB + 3);
  51. /* out = sourceA * sourceB */
  52. out3 = inA3 * inB3;
  53. /* store result to destination buffer */
  54. *(pDst + 1) = out2;
  55. /* out = sourceA * sourceB */
  56. out4 = inA4 * inB4;
  57. /* store result to destination buffer */
  58. *(pDst + 2) = out3;
  59. /* store result to destination buffer */
  60. *(pDst + 3) = out4;
  61. /* update pointers to process next samples */
  62. pSrcA += 4u;
  63. pSrcB += 4u;
  64. pDst += 4u;
  65. /* Decrement the blockSize loop counter */
  66. blkCnt--;
  67. }
  68. /* If the blockSize is not a multiple of 4, compute any remaining output samples here.
  69. ** No loop unrolling is used. */
  70. blkCnt = blockSize % 0x4u;
  71. #else
  72. /* Run the below code for Cortex-M0 */
  73. /* Initialize blkCnt with number of samples */
  74. blkCnt = blockSize;
  75. #endif /* #ifndef ARM_MATH_CM0_FAMILY */
  76. while(blkCnt > 0u)
  77. {
  78. /* C = A * B */
  79. /* Multiply the inputs and store the results in output buffer */
  80. *pDst++ = (*pSrcA++) * (*pSrcB++);
  81. /* Decrement the blockSize loop counter */
  82. blkCnt--;
  83. }
  84. }
1. 浮点的32位乘法比较简单,这里依然是以4次的计算为一组。
8.4.2 arm_mult_q31
    这个函数用于求32位定点数的乘法,源代码分析如下:
  1. /**
  2. * @brief Q31 vector multiplication.
  7. * @return none.
  8. *
  10. * \\par
  13. */
  14. void arm_mult_q31(
  15. q31_t * pSrcA,
  16. q31_t * pSrcB,
  17. q31_t * pDst,
  19. {
  20. uint32_t blkCnt; /* loop counters */
  23. q31_t inA1, inA2, inA3, inA4; /* temporary input variables */
  24. q31_t inB1, inB2, inB3, inB4; /* temporary input variables */
  25. q31_t out1, out2, out3, out4; /* temporary output variables */
  26. /* loop Unrolling */
  27. blkCnt = blockSize >> 2u;
  28. /* First part of the processing with loop unrolling. Compute 4 outputs at a time.
  29. ** a second loop below computes the remaining 1 to 3 samples. */
  30. while(blkCnt > 0u)
  31. {
  32. /* C = A * B */
  33. /* Multiply the inputs and then store the results in the destination buffer. */
  34. inA1 = *pSrcA++;
  35. inA2 = *pSrcA++;
  36. inA3 = *pSrcA++;
  37. inA4 = *pSrcA++;
  38. inB1 = *pSrcB++;
  39. inB2 = *pSrcB++;
  40. inB3 = *pSrcB++;
  41. inB4 = *pSrcB++;
  42. out1 = ((q63_t) inA1 * inB1) >> 32; (2)
  43. out2 = ((q63_t) inA2 * inB2) >> 32;
  44. out3 = ((q63_t) inA3 * inB3) >> 32;
  45. out4 = ((q63_t) inA4 * inB4) >> 32;
  46. out1 = __SSAT(out1, 31); (3)
  47. out2 = __SSAT(out2, 31);
  48. out3 = __SSAT(out3, 31);
  49. out4 = __SSAT(out4, 31);
  50. *pDst++ = out1 << 1u; (4)
  51. *pDst++ = out2 << 1u;
  52. *pDst++ = out3 << 1u;
  53. *pDst++ = out4 << 1u;
  54. /* Decrement the blockSize loop counter */
  55. blkCnt--;
  56. }
  57. /* If the blockSize is not a multiple of 4, compute any remaining output samples here.
  58. ** No loop unrolling is used. */
  59. blkCnt = blockSize % 0x4u;
  60. #else
  61. /* Run the below code for Cortex-M0 */
  62. /* Initialize blkCnt with number of samples */
  63. blkCnt = blockSize;
  65. while(blkCnt > 0u)
  66. {
  67. /* C = A * B */
  68. /* Multiply the inputs and then store the results in the destination buffer. */
  69. *pDst++ =
  70. (q31_t) clip_q63_to_q31(((q63_t) (*pSrcA++) * (*pSrcB++)) >> 31);
  71. /* Decrement the blockSize loop counter */
  72. blkCnt--;
  73. }
  74. }
1. 这个函数使用了饱和算法。
    所得结果是Q31格式,范围Q31 range[0x80000000 0x7FFFFFFF]
2. 所得乘积左移32位。
3. 实现31位精度的饱和运算。
4. 右移一位,保证所得结果是Q31格式。
8.4.3 arm_mult_q15
    这个函数用于求16位定点数的乘法,源代码分析如下:
  1. /**
  2. * @brief Q15 vector multiplication
  7. * @return none.
  8. *
  10. * \\par
  13. */
  14. void arm_mult_q15(
  15. q15_t * pSrcA,
  16. q15_t * pSrcB,
  17. q15_t * pDst,
  19. {
  23. q31_t inA1, inA2, inB1, inB2; /* temporary input variables */
  24. q15_t out1, out2, out3, out4; /* temporary output variables */
  25. q31_t mul1, mul2, mul3, mul4; /* temporary variables */
  31. {
  32. /* read two samples at a time from sourceA */
  33. inA1 = *__SIMD32(pSrcA)++; (2)
  34. /* read two samples at a time from sourceB */
  35. inB1 = *__SIMD32(pSrcB)++;
  36. /* read two samples at a time from sourceA */
  37. inA2 = *__SIMD32(pSrcA)++;
  38. /* read two samples at a time from sourceB */
  39. inB2 = *__SIMD32(pSrcB)++;
  40. /* multiply mul = sourceA * sourceB */
  41. mul1 = (q31_t) ((q15_t) (inA1 >> 16) * (q15_t) (inB1 >> 16)); (3)
  42. mul2 = (q31_t) ((q15_t) inA1 * (q15_t) inB1);
  43. mul3 = (q31_t) ((q15_t) (inA2 >> 16) * (q15_t) (inB2 >> 16));
  44. mul4 = (q31_t) ((q15_t) inA2 * (q15_t) inB2);
  45. /* saturate result to 16 bit */
  46. out1 = (q15_t) __SSAT(mul1 >> 15, 16); (4)
  47. out2 = (q15_t) __SSAT(mul2 >> 15, 16);
  48. out3 = (q15_t) __SSAT(mul3 >> 15, 16);
  49. out4 = (q15_t) __SSAT(mul4 >> 15, 16);
  50. /* store the result */
  51. #ifndef ARM_MATH_BIG_ENDIAN
  52. *__SIMD32(pDst)++ = __PKHBT(out2, out1, 16); (5)
  53. *__SIMD32(pDst)++ = __PKHBT(out4, out3, 16);
  54. #else
  55. *__SIMD32(pDst)++ = __PKHBT(out2, out1, 16);
  56. *__SIMD32(pDst)++ = __PKHBT(out4, out3, 16);
  57. #endif // #ifndef ARM_MATH_BIG_ENDIAN
  58. /* Decrement the blockSize loop counter */
  59. blkCnt--;
  60. }
  61. /* If the blockSize is not a multiple of 4, compute any remaining output samples here.
  62. ** No loop unrolling is used. */
  63. blkCnt = blockSize % 0x4u;
  64. #else
  68. #endif /* #ifndef ARM_MATH_CM0_FAMILY */
  69. while(blkCnt > 0u)
  70. {
  71. /* C = A * B */
  72. /* Multiply the inputs and store the result in the destination buffer */
  73. *pDst++ = (q15_t) __SSAT((((q31_t) (*pSrcA++) * (*pSrcB++)) >> 15), 16);
  74. /* Decrement the blockSize loop counter */
  75. blkCnt--;
  76. }
  77. }
1. 这个函数使用了饱和算法。
    所得结果是Q15格式,范围 [0x8000 0x7FFF]
2. 一次读取两个Q15格式的数据。
3. 将四组数的乘积保存到Q31格式的变量mul1,mul2,mul3,mul4。
4. 丢弃32位数据的低15位,并把最终结果饱和到16位精度。
5. 通过SIMD指令__PKHBT将两个Q15格式的数据保存的结果数组中,从而一个指令周期就能完成两个数据的存储。
8.4.4 arm_mult_q7
    这个函数用于求8位定点数的乘法,源代码分析如下:
  1. /**
  2. * @brief Q7 vector multiplication
  7. * @return none.
  8. *
  10. * \\par
  13. */
  14. void arm_mult_q7(
  15. q7_t * pSrcA,
  16. q7_t * pSrcB,
  17. q7_t * pDst,
  19. {
  23. q7_t out1, out2, out3, out4; /* Temporary variables to store the product */
  24. /* loop Unrolling */
  29. {
  30. /* C = A * B */
  31. /* Multiply the inputs and store the results in temporary variables */ (2)
  32. out1 = (q7_t) __SSAT((((q15_t) (*pSrcA++) * (*pSrcB++)) >> 7), 8);
  33. out2 = (q7_t) __SSAT((((q15_t) (*pSrcA++) * (*pSrcB++)) >> 7), 8);
  34. out3 = (q7_t) __SSAT((((q15_t) (*pSrcA++) * (*pSrcB++)) >> 7), 8);
  35. out4 = (q7_t) __SSAT((((q15_t) (*pSrcA++) * (*pSrcB++)) >> 7), 8);
  36. /* Store the results of 4 inputs in the destination buffer in single cycle by packing */
  37. *__SIMD32(pDst)++ = __PACKq7(out1, out2, out3, out4); (3)
  38. /* Decrement the blockSize loop counter */
  39. blkCnt--;
  40. }
  44. #else
  45. /* Run the below code for Cortex-M0 */
  46. /* Initialize blkCnt with number of samples */
  47. blkCnt = blockSize;
  48. #endif /* #ifndef ARM_MATH_CM0_FAMILY */
  49. while(blkCnt > 0u)
  50. {
  51. /* C = A * B */
  52. /* Multiply the inputs and store the result in the destination buffer */
  53. *pDst++ = (q7_t) __SSAT((((q15_t) (*pSrcA++) * (*pSrcB++)) >> 7), 8);
  55. blkCnt--;
  56. }
  57. }
1. 这个函数使用了饱和算法。
    所得结果是Q7格式,范围 [0x80 0x7F]
2. 将两个Q7格式的数据乘积左移7位,也就是丢掉低7位的数据,并将所得结果饱和到8位精度。
3. __PACKq7函数可以在一个时钟周期就能完成相应操作。
8.4.5 实例讲解
实验目的:
    1. 四种类型数据的乘法。
实验内容:
    1. 按下摇杆的UP键, 串口打印输出结果
实验现象:
程序设计:
  1. /*
  3. *    函 数 名: DSP_Multiplication
  4. *    功能说明: 乘法
  5. *    形 参:无
  6. *    返 回 值: 无
  8. */
  9. static void DSP_Multiplication(void)
  10. {
  13. static float32_t pDst[5];
  14. static q31_t pSrcA1[5] = {1,1,1,1,1};
  16. static q31_t pDst1[5];
  19. static q15_t pDst2[5];
  20. static q7_t pSrcA3[5] = {0x70,1,1,1,1};
  21. static q7_t pSrcB3[5] = {0x7f,1,1,1,1};
  22. static q7_t pDst3[5];
  23. pSrcA[0] += 1.1f;
  24. arm_mult_f32(pSrcA, pSrcB, pDst, 5);
  25. printf("arm_mult_f32 = %f\\r\\n", pDst[0]);
  26. pSrcA1[0] += 1;
  27. arm_mult_q31(pSrcA1, pSrcB1, pDst1, 5);
  28. printf("arm_mult_q31 = %d\\r\\n", pDst1[0]);
  29. pSrcA2[0] += 1;
  30. arm_mult_q15(pSrcA2, pSrcB2, pDst2, 5);
  31. printf("arm_mult_q15 = %d\\r\\n", pDst2[0]);
  32. pSrcA3[0] += 1;
  33. arm_mult_q7(pSrcA3, pSrcB3, pDst3, 5);
  34. printf("arm_mult_q7 = %d\\r\\n", pDst3[0]);
  36. }
8.5 总结
     本期教程就跟大家讲这么多,还是那句话,可以自己写些代码调用本期教程中讲的这几个函数,如果可以的话,可以自己尝试直接调用这些DSP指令。
GMT+8, 2024-6-18 10:01 , Processed in 0.196934 second(s), 28 queries .
