模仿kfifo实现的环形缓冲区
转载来源:模仿kfifo实现的环形缓冲区
GitHub仓库:https://github.com/XinLiGitHub/RingBuffer
PS:博文不再更新,后续更新会在GitHub仓库进行。
模仿kfifo实现的环形缓冲区。程序中涉及到环形缓冲区的概念,详细介绍见维基百科[Circular buffer](https://en.wikipedia.org/wiki/Circular_buffer)。
1,开发环境
1,操作系统:Windows 10 专业版
2,IDE:Visual Studio 2015 专业版
2,程序源码
RingBuffer.h文件
RingBuffer.c文件
- * @file RingBuffer.c
- * @author XinLi
- * @version v1.0
- * @date 15-January-2018
- * @brief Ring buffer module source file.
- * @attention
- * <h2><center>Copyright © 2018 XinLi</center></h2>
- * This program is free software: you can redistribute it and/or modify
- * it under the terms of the GNU General Public License as published by
- * the Free Software Foundation, either version 3 of the License, or
- * (at your option) any later version.
- * This program is distributed in the hope that it will be useful,
- * but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- * GNU General Public License for more details.
- * You should have received a copy of the GNU General Public License
- * along with this program. If not, see <https://www.gnu.org/licenses/>.
- /* Header includes -----------------------------------------------------------*/
- #include "RingBuffer.h"
- #include <stdlib.h>
- #include <string.h>
- /* Macro definitions ---------------------------------------------------------*/
- /* Type definitions ----------------------------------------------------------*/
- /* Variable declarations -----------------------------------------------------*/
- /* Variable definitions ------------------------------------------------------*/
- /* Function declarations -----------------------------------------------------*/
- static bool is_power_of_2(uint32_t x);
- static uint32_t roundup_pow_of_two(uint32_t x);
- /* Function definitions ------------------------------------------------------*/
- * @brief Allocates a new FIFO and its internal buffer.
- * @param [in] size: The size of the internal buffer to be allocated.
- * @note The size will be rounded-up to a power of 2.
- * @return RingBuffer pointer.
- RingBuffer *RingBuffer_Malloc(uint32_t size)
- RingBuffer *fifo = RING_BUFFER_MALLOC(sizeof(RingBuffer));
- if(fifo != NULL)
- if(is_power_of_2(size) != true)
- if(size > 0x80000000UL)
- RING_BUFFER_FREE(fifo);
- fifo = NULL;
- return fifo;
- size = roundup_pow_of_two(size);
- fifo->size = size;
- fifo->in = 0;
- fifo->out = 0;
- fifo->buffer = RING_BUFFER_MALLOC(fifo->size);
- if(fifo->buffer == NULL)
- fifo = NULL;
- return fifo;
- return fifo;
- * @brief Frees the FIFO.
- * @param [in] fifo: The fifo to be freed.
- * @return None.
- void RingBuffer_Free(RingBuffer *fifo)
- RING_BUFFER_FREE(fifo->buffer);
- fifo = NULL;
- * @brief Puts some data into the FIFO.
- * @param [in] fifo: The fifo to be used.
- * @param [in] in: The data to be added.
- * @param [in] len: The length of the data to be added.
- * @return The number of bytes copied.
- * @note This function copies at most @len bytes from the @in into
- * the FIFO depending on the free space, and returns the number
- * of bytes copied.
- uint32_t RingBuffer_In(RingBuffer *fifo, void *in, uint32_t len)
- len = min(len, RingBuffer_Avail(fifo));
- /* First put the data starting from fifo->in to buffer end. */
- uint32_t l = min(len, fifo->size - (fifo->in & (fifo->size - 1)));
- memcpy(fifo->buffer + (fifo->in & (fifo->size - 1)), in, l);
- /* Then put the rest (if any) at the beginning of the buffer. */
- memcpy(fifo->buffer, (uint8_t *)in + l, len - l);
- fifo->in += len;
- return len;
- * @brief Gets some data from the FIFO.
- * @param [in] out: Where the data must be copied.
- * @param [in] len: The size of the destination buffer.
- * @return The number of copied bytes.
- * @note This function copies at most @len bytes from the FIFO into
- * the @out and returns the number of copied bytes.
- uint32_t RingBuffer_Out(RingBuffer *fifo, void *out, uint32_t len)
- len = min(len, RingBuffer_Len(fifo));
- /* First get the data from fifo->out until the end of the buffer. */
- uint32_t l = min(len, fifo->size - (fifo->out & (fifo->size - 1)));
- memcpy(out, fifo->buffer + (fifo->out & (fifo->size - 1)), l);
- /* Then get the rest (if any) from the beginning of the buffer. */
- memcpy((uint8_t *)out + l, fifo->buffer, len - l);
- fifo->out += len;
- return len;
- * @brief Determine whether some value is a power of two.
- * @param [in] x: The number to be confirmed.
- * @retval true: Yes.
- * @retval false: No.
- * @note Where zero is not considered a power of two.
- return (x != 0) && ((x & (x - 1)) == 0);
- * @brief Round the given value up to nearest power of two.
- * @param [in] x: The number to be converted.
- * @return The power of two.
- uint32_t b = 0;
- for(int i = 0; i < 32; i++)
- b = 1UL << i;
- if(x <= b)
- break;
- return b;
main.c文件
- * @file main.c
- * @author XinLi
- * @version v1.0
- * @brief Main program body.
- * @attention
- #include <stdio.h>
- #include <windows.h>
- * @brief Main program.
- * @param None.
- * @return None.
- int main(void)
- uint8_t data[256] = {0};
- for(int i = 0; i < sizeof(data); i++)
- data[i] = i;
- RingBuffer *fifo = RingBuffer_Malloc(sizeof(data));
- if(fifo != NULL)
- printf("FIFO创建成功,FIFO大小:%d,使用大小:%d,剩余大小:%d\n",
- RingBuffer_Size(fifo), RingBuffer_Len(fifo), RingBuffer_Avail(fifo));
- if(RingBuffer_IsFull(fifo) == true)
- printf("FIFO满了!!!\n");
- else
- printf("FIFO没满!!!\n");
- if(RingBuffer_IsEmpty(fifo) == true)
- printf("FIFO空了!!!\n");
- else
- printf("FIFO没空!!!\n");
- printf("\n");
- for(;;)
- if(RingBuffer_In(fifo, data, sizeof(data) / 2) > 0)
- printf("FIFO写入成功,FIFO大小:%d,使用大小:%d,剩余大小:%d\n",
- else
- printf("FIFO写入失败,FIFO大小:%d,使用大小:%d,剩余大小:%d\n",
- else
- else
- printf("\n");
- uint8_t rdata[64] = {0};
- uint8_t len = RingBuffer_Out(fifo, rdata, sizeof(rdata));
- if(len > 0)
- printf("从FIFO中读出的数据,长度:%d\n", len);
- for(int i = 0; i < len; i++)
- printf("%d ", rdata[i]);
- printf("\n");
- printf("FIFO读取成功,FIFO大小:%d,使用大小:%d,剩余大小:%d\n",
- else
- printf("FIFO读取失败,FIFO大小:%d,使用大小:%d,剩余大小:%d\n",
- else
- else
- printf("\n");
- RingBuffer_Reset(fifo);
- printf("FIFO清空成功,FIFO大小:%d,使用大小:%d,剩余大小:%d\n",
- else
- else
- printf("\n");
- if(RingBuffer_In(fifo, data, sizeof(data)) > 0)
- else
- else
- else
- printf("\n");
- else
- else
- else
- printf("\n");
- uint8_t rdata[256] = {0};
- uint16_t len = RingBuffer_Out(fifo, rdata, sizeof(rdata));
- if(len > 0)
- printf("\n");
- else
- else
- else
- printf("\n");
- if(len > 0)
- printf("\n");
- else
- else
- else
- printf("\n\n\n");
- Sleep(5000);
- else
- printf("FIFO创建失败\n");
- for(;;)
3,运行效果
