查看: 3871|回复: 3
[μCGUI] ucgui 定时器仿真不成功
发表于 2015-4-21 17:07:10 | 显示全部楼层 |阅读模式
在学习ucgui时,看到了定时器,于是学习硬汉哥的教程36章,仿造写但是没有成功,这是为啥????求各位提示一下:
static const GUI_WIDGET_CREATE_INFO _aDialogCreate5[] = {
    { FRAMEWIN_CreateIndirect,  "Caption",           0,                       0,  0,  800,600,0,0},
    { BUTTON_CreateIndirect,    "BUTTON0",           GUI_ID_BUTTON0,          174,265,354,82, 0,0},
    { TEXT_CreateIndirect,      "0000",              GUI_ID_TEXT0,            174,95, 365,98, 0,0}
**      FunctionName:void PaintDialog(WM_MESSAGE * pMsg)
**      Function: to initialize the Dialog items
**      call this function in _cbCallback --> WM_PAINT
void PaintDialog5(WM_MESSAGE * pMsg)
    WM_HWIN hWin = pMsg->hWin;
void InitDialog5(WM_MESSAGE * pMsg)
    //FRAMEWIN
    FRAMEWIN_SetClientColor(hWin,0xffffff);
    FRAMEWIN_SetTitleVis(hWin,0);
    //GUI_ID_BUTTON0
    BUTTON_SetBkColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON0),BUTTON_CI_UNPRESSED,0xffffc0);
    BUTTON_SetFont(WM_GetDialogItem(hWin,GUI_ID_BUTTON0),&GUI_Font32B_ASCII);
    //GUI_ID_TEXT0
    TEXT_SetBkColor(WM_GetDialogItem(hWin,GUI_ID_TEXT0),0x808080);
    TEXT_SetFont(WM_GetDialogItem(hWin,GUI_ID_TEXT0),&GUI_FontD48);
    TEXT_SetTextAlign(WM_GetDialogItem(hWin,GUI_ID_TEXT0),GUI_TA_VCENTER|GUI_TA_CENTER);
static void _cbCallback5(WM_MESSAGE * pMsg)
    int NCode, Id;
char buf1[10],buf2[10],buf3[10],buf4[10];
    switch (pMsg->MsgId)
  case WM_TIMER:
     count1++;
     sprintf(buf1,"%04d",count1);
     TEXT_SetText(WM_GetDialogItem(hWin,GUI_ID_TEXT0),(const char *)buf1);
     WM_RestartTimer(pMsg->Data.v, 100);
  case WM_DELETE:
    DisplayState=0; //窗体已经关闭
        case WM_PAINT:
            PaintDialog5(pMsg);
        case WM_INIT_DIALOG:
            InitDialog5(pMsg);
        case WM_KEY:
            switch (((WM_KEY_INFO*)(pMsg->Data.p))->Key)
                case GUI_KEY_ESCAPE:
                    GUI_EndDialog(hWin, 1);
                case GUI_KEY_ENTER:
                    GUI_EndDialog(hWin, 0);
        case WM_NOTIFY_PARENT:
            Id = WM_GetId(pMsg->hWinSrc);
            NCode = pMsg->Data.v;
            switch (Id)
                case GUI_ID_OK:
                    if(NCode==WM_NOTIFICATION_RELEASED)
                case GUI_ID_CANCEL:
    case GUI_ID_BUTTON0:
     switch(NCode)
      case WM_NOTIFICATION_CLICKED:
      case WM_NOTIFICATION_MOVED_OUT:
        default:
            WM_DefaultProc(pMsg);
void OPenDisplay(void)
WM_HWIN display;
DisplayState=1;
   display= GUI_ExecDialogBox(_aDialogCreate5, GUI_COUNTOF(_aDialogCreate5), &_cbCallback5, 0, 0, 0);
   WM_CreateTimer(WM_GetClientWindow(display),  /*接收信息的窗口句柄 */
                   0,                          /*用户定义的ID*/
            500,                         /* 周期*/
          0);                         /*0 */
   while(DisplayState)
     GUI_Delay(50);
运行结果:一直是0
发表于 2015-4-21 17:14:29 | 显示全部楼层
这里有问题,不能用这个阻塞对话框。因为你不关闭对话框,后面的语句根本执行不了!!也就是说,定时器还没有创建呢。。。
 楼主| 发表于 2015-4-21 17:34:56 | 显示全部楼层
谢谢你了。。。。完美解决问题了。。。。
 楼主| 发表于 2015-4-21 17:35:35 | 显示全部楼层
回 caicaptain2 的帖子
caicaptain2:display= GUI_ExecDialogBox(_aDialogCreate5, GUI_COUNTOF(_aDialogCreate5), &_cbCallback5, 0, 0, 0);
(2015-04-21 17:14)
完美解决。。。。谢谢指点。。。
GMT+8, 2025-5-15 07:49 , Processed in 0.234308 second(s), 26 queries .
