查看: 2463|回复: 3
[RTOS] Micrium为飞思卡尔的K21F120开发板做的最新版uC/OS-II v2.92.14和uC/OS-III v3.06.02移植,很方便可升级到RT105
发表于 2018-3-12 01:47:02 | 显示全部楼层 |阅读模式
1、对于老版本的uCOS-II和uCOS-III,建议大家不要再去搞了,特别是uCOS-III,升级到3.06版本后删除了很多臃肿的东西,比如删除中断延迟提交,删除多事件等待等,也增加了新特性,修改原有一些组件的特性。
2、对于RT1052,新的芯片,新的开始。
Micrium_TWR-K21F120MA_Blinky.zip (1.27 MB, 下载次数: 108)
版本信息如下:
BLINKY EXAMPLE FOR THE NXP TWR-K21F120MA, REVISION X1
This example project demonstrates how to create a kernel task which blinks an LED.
MICRIUM PRODUCT VERSIONS
- uC/OS-II  v2.92.14
- uC/OS-III v3.06.02
- uC/CPU    v1.31.02
- uC/LIB    v1.38.02
IDE/COMPILER VERSIONS
- IAR/EWARM v8.20.1
HARDWARE SETUP
- Connect USB Micro-B cable to DBG/USB (J2) to provide power.
- Connect a J-Link probe to the JTAG header (J1).
WORKSPACE LOCATIONS
- NXP/TWR-K21F120MA/Blinky/<OS2|OS3>/IAR/Blinky.eww
USAGE INSTRUCTIONS
- Open the workspace in IAR.
- Press F7 to build the project and Ctrl+D to start the debug session.
- Once the debug session has started, press F5 to run the example.
- The project creates a task which blinks the green LED every 200 milliseconds.
- Now modify the call to OSTimeDlyHMSM() in StartupTask() to increase or decrease the frequency at which the green LED blinks.
- Build and run again to see the change.
 楼主| 发表于 2018-3-12 01:48:08 | 显示全部楼层
发表于 2018-3-12 14:15:34 | 显示全部楼层
ucos-iii 还没有完全搞明白啊,现在又出的新的东东了,完全跟不上节奏啊
 楼主| 发表于 2018-3-12 15:20:48 | 显示全部楼层
就是uCOS-III,就是升级的有点勤快。
GMT+8, 2025-5-12 22:58 , Processed in 0.378015 second(s), 27 queries .
