查看: 2498|回复: 5
[客户分享] STM32F4 C++ 封装库 之 GPIO
发表于 2018-4-1 16:59:09 | 显示全部楼层 |阅读模式
       一直有一个想法就是用 C++ 去做 STM32 的开发,但是很少有这方面的资料。经过一段时间的思考,决定在官方的 ll 库的基础上做一层 C++ 的简单封装。因为官方的库基本实现了全系列的 MCU 都是相同的 API 接口,所以 C++ 封装后的库也有很好的移植性。原理性的东西就不讲理了,直接上代码。
stm32f4xx_xgpio.h 文件
  1. /**
  2.   ******************************************************************************
  3.   * \file    stm32f4xx_xgpio.h
  4.   * \author  XinLi
  5.   * \version v1.0
  6.   * \date    20-March-2018
  7.   * \brief   Header file for general purpose I/O module.
  8.   ******************************************************************************
  9.   * \attention
  10.   *
  11.   * <h2><center>Copyright &#169; 2018 XinLi</center></h2>
  12.   *
  13.   * This program is free software: you can redistribute it and/or modify
  14.   * it under the terms of the GNU General Public License as published by
  15.   * the Free Software Foundation, either version 3 of the License, or
  16.   * (at your option) any later version.
  17.   *
  18.   * This program is distributed in the hope that it will be useful,
  19.   * but WITHOUT ANY WARRANTY; without even the implied warranty of
  20.   * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
  21.   * GNU General Public License for more details.
  22.   *
  23.   * You should have received a copy of the GNU General Public License
  24.   * along with this program.  If not, see <https://www.gnu.org/licenses/>.
  25.   *
  26.   ******************************************************************************
  27.   */
  28. #ifndef STM32F4XX_XGPIO_H
  29. #define STM32F4XX_XGPIO_H
  30. #include <stdint.h>
  31. #include "stm32f4xx_ll_gpio.h"
  32. /*! General purpose I/O module. */
  33. class XGpio
  34. {
  35. public:
  36.   /*! Enumerate GPIO ports. */
  37.   enum GpioPort
  38.   {
  39.     PortA = (uint32_t)GPIOA, /*!< GPIO port A. */
  40.     PortB = (uint32_t)GPIOB, /*!< GPIO port B. */
  41.     PortC = (uint32_t)GPIOC, /*!< GPIO port C. */
  42.   #ifdef GPIOD
  43.     PortD = (uint32_t)GPIOD, /*!< GPIO port D. */
  44.   #endif // GPIOD
  45.   #ifdef GPIOE
  46.     PortE = (uint32_t)GPIOE, /*!< GPIO port E. */
  47.   #endif // GPIOE
  48.   #ifdef GPIOF
  49.     PortF = (uint32_t)GPIOF, /*!< GPIO port F. */
  50.   #endif // GPIOF
  51.   #ifdef GPIOG
  52.     PortG = (uint32_t)GPIOG, /*!< GPIO port G. */
  53.   #endif // GPIOG
  54.   #ifdef GPIOH
  55.     PortH = (uint32_t)GPIOH, /*!< GPIO port H. */
  56.   #endif // GPIOH
  57.   #ifdef GPIOI
  58.     PortI = (uint32_t)GPIOI, /*!< GPIO port I. */
  59.   #endif // GPIOI
  60.   #ifdef GPIOJ
  61.     PortJ = (uint32_t)GPIOJ, /*!< GPIO port J. */
  62.   #endif // GPIOJ
  63.   #ifdef GPIOK
  64.     PortK = (uint32_t)GPIOK, /*!< GPIO port K. */
  65.   #endif // GPIOK
  66.   };
  67.
  68.   /*! Enumeration of GPIO pins. */
  69.   enum GpioPin
  70.   {
  71.     Pin0  = LL_GPIO_PIN_0,  /*!< GPIO pin 0. */
  72.     Pin1  = LL_GPIO_PIN_1,  /*!< GPIO pin 1. */
  73.     Pin2  = LL_GPIO_PIN_2,  /*!< GPIO pin 2. */
  74.     Pin3  = LL_GPIO_PIN_3,  /*!< GPIO pin 3. */
  75.     Pin4  = LL_GPIO_PIN_4,  /*!< GPIO pin 4. */
  76.     Pin5  = LL_GPIO_PIN_5,  /*!< GPIO pin 5. */
  77.     Pin6  = LL_GPIO_PIN_6,  /*!< GPIO pin 6. */
  78.     Pin7  = LL_GPIO_PIN_7,  /*!< GPIO pin 7. */
  79.     Pin8  = LL_GPIO_PIN_8,  /*!< GPIO pin 8. */
  80.     Pin9  = LL_GPIO_PIN_9,  /*!< GPIO pin 9. */
  81.     Pin10 = LL_GPIO_PIN_10, /*!< GPIO pin 10. */
  82.     Pin11 = LL_GPIO_PIN_11, /*!< GPIO pin 11. */
  83.     Pin12 = LL_GPIO_PIN_12, /*!< GPIO pin 12. */
  84.     Pin13 = LL_GPIO_PIN_13, /*!< GPIO pin 13. */
  85.     Pin14 = LL_GPIO_PIN_14, /*!< GPIO pin 14. */
  86.     Pin15 = LL_GPIO_PIN_15, /*!< GPIO pin 15. */
  87.   };
  88.
  89.   /*! Enumeration of GPIO modes. */
  90.   enum GpioMode
  91.   {
  92.     ModeInput     = LL_GPIO_MODE_INPUT,     /*!< GPIO input mode. */
  93.     ModeOutput    = LL_GPIO_MODE_OUTPUT,    /*!< GPIO output mode. */
  94.     ModeAlternate = LL_GPIO_MODE_ALTERNATE, /*!< GPIO alternate function mode. */
  95.     ModeAnalog    = LL_GPIO_MODE_ANALOG,    /*!< GPIO analog mode. */
  96.   };
  97.
  98.   /*! Enumeration of GPIO output types. */
  99.   enum GpioOutput
  100.   {
  101.     OutputPushPull  = LL_GPIO_OUTPUT_PUSHPULL,  /*!< GPIO push-pull output. */
  102.     OutputOpenDrain = LL_GPIO_OUTPUT_OPENDRAIN, /*!< GPIO open-drain output. */
  103.   };
  104.
  105.   /*! Enumeration of GPIO output speeds. */
  106.   enum GpioSpeed
  107.   {
  108.     SpeedLow      = LL_GPIO_SPEED_FREQ_LOW,       /*!< GPIO low output speed. */
  109.     SpeedMedium   = LL_GPIO_SPEED_FREQ_MEDIUM,    /*!< GPIO medium output speed. */
  110.     SpeedHigh     = LL_GPIO_SPEED_FREQ_HIGH,      /*!< GPIO high output speed. */
  111.     SpeedVeryHigh = LL_GPIO_SPEED_FREQ_VERY_HIGH, /*!< GPIO very high output speed. */
  112.   };
  113.
  114.   /*! Enumeration of GPIO pull-up/pull-down. */
  115.   enum GpioPull
  116.   {
  117.     PullNo   = LL_GPIO_PULL_NO,   /*!< GPIO no pull. */
  118.     PullUp   = LL_GPIO_PULL_UP,   /*!< GPIO pull-up. */
  119.     PullDown = LL_GPIO_PULL_DOWN, /*!< GPIO pull-down. */
  120.   };
  121.
  122.   /*! Enumeration of GPIO alternate functions. */
  123.   enum GpioAlternate
  124.   {
  125.     Alternate0  = LL_GPIO_AF_0,  /*!< GPIO alternate function 0. */
  126.     Alternate1  = LL_GPIO_AF_1,  /*!< GPIO alternate function 1. */
  127.     Alternate2  = LL_GPIO_AF_2,  /*!< GPIO alternate function 2. */
  128.     Alternate3  = LL_GPIO_AF_3,  /*!< GPIO alternate function 3. */
  129.     Alternate4  = LL_GPIO_AF_4,  /*!< GPIO alternate function 4. */
  130.     Alternate5  = LL_GPIO_AF_5,  /*!< GPIO alternate function 5. */
  131.     Alternate6  = LL_GPIO_AF_6,  /*!< GPIO alternate function 6. */
  132.     Alternate7  = LL_GPIO_AF_7,  /*!< GPIO alternate function 7. */
  133.     Alternate8  = LL_GPIO_AF_8,  /*!< GPIO alternate function 8. */
  134.     Alternate9  = LL_GPIO_AF_9,  /*!< GPIO alternate function 9. */
  135.     Alternate10 = LL_GPIO_AF_10, /*!< GPIO alternate function 10. */
  136.     Alternate11 = LL_GPIO_AF_11, /*!< GPIO alternate function 11. */
  137.     Alternate12 = LL_GPIO_AF_12, /*!< GPIO alternate function 12. */
  138.     Alternate13 = LL_GPIO_AF_13, /*!< GPIO alternate function 13. */
  139.     Alternate14 = LL_GPIO_AF_14, /*!< GPIO alternate function 14. */
  140.     Alternate15 = LL_GPIO_AF_15, /*!< GPIO alternate function 15. */
  141.   };
  142.
  143.   /*! Enumeration of GPIO levels. */
  144.   enum GpioLevel
  145.   {
  146.     LevelLow  = 0, /*!< GPIO low level. */
  147.     LevelHigh = 1, /*!< GPIO high level. */
  148.   };
  149.
  150.   XGpio(GpioPort port, GpioPin pin, GpioMode mode = ModeInput);
  151.   virtual ~XGpio();
  152.
  153.   void setPort(GpioPort port);
  154.   GpioPort getPort() const;
  155.
  156.   void setPin(GpioPin pin);
  157.   GpioPin getPin() const;
  158.
  159.   void setMode(GpioMode mode);
  160.   GpioMode getMode() const;
  161.
  162.   void setOutput(GpioOutput output);
  163.   GpioOutput getOutput() const;
  164.
  165.   void setSpeed(GpioSpeed speed);
  166.   GpioSpeed getSpeed() const;
  167.
  168.   void setPull(GpioPull pull);
  169.   GpioPull getPull() const;
  170.
  171.   void setAlternate(GpioAlternate alternate);
  172.   GpioAlternate getAlternate() const;
  173.
  174.   void setLevel(GpioLevel level);
  175.   GpioLevel getLevel();
  176.
  177.   void toggle();
  178.
  179.   bool open();
  180.   void close();
  181.
  182.   bool isOpen() const;
  183.
  184. private:
  185.   GpioPort      port;
  186.   GpioPin       pin;
  187.   GpioMode      mode;
  188.   GpioOutput    output;
  189.   GpioSpeed     speed;
  190.   GpioPull      pull;
  191.   GpioAlternate alternate;
  192.   GpioLevel     level;
  193.   bool          openFlag;
  194.
  195.   XGpio(const XGpio &) = delete;
  196.   XGpio & operator = (const XGpio &) = delete;
  197. };
  198. #endif // STM32F4XX_XGPIO_H
stm32f4xx_xgpio.cpp 文件
  1. /**
  3.   * \file    stm32f4xx_xgpio.cpp
  4.   * \author  XinLi
  5.   * \version v1.0
  7.   * \brief   General purpose I/O module driver.
  9.   * \attention
  10.   *
  12.   *
  17.   *
  22.   *
  25.   *
  27.   */
  28. #include "stm32f4xx_xgpio.h"
  29. #include "stm32f4xx_ll_bus.h"
  30. static __IO uint16_t openFlagPortA = 0;
  31. static __IO uint16_t openFlagPortB = 0;
  32. static __IO uint16_t openFlagPortC = 0;
  33. #ifdef GPIOD
  34. static __IO uint16_t openFlagPortD = 0;
  35. #endif // GPIOD
  36. #ifdef GPIOE
  37. static __IO uint16_t openFlagPortE = 0;
  38. #endif // GPIOE
  39. #ifdef GPIOF
  40. static __IO uint16_t openFlagPortF = 0;
  41. #endif // GPIOF
  42. #ifdef GPIOG
  43. static __IO uint16_t openFlagPortG = 0;
  44. #endif // GPIOG
  45. #ifdef GPIOH
  46. static __IO uint16_t openFlagPortH = 0;
  47. #endif // GPIOH
  48. #ifdef GPIOI
  49. static __IO uint16_t openFlagPortI = 0;
  50. #endif // GPIOI
  51. #ifdef GPIOJ
  52. static __IO uint16_t openFlagPortJ = 0;
  53. #endif // GPIOJ
  54. #ifdef GPIOK
  55. static __IO uint16_t openFlagPortK = 0;
  56. #endif // GPIOK
  57. /*!
  58.    \brief Open the general purpose I/O clock.
  59.    \param port: GPIO port.
  60. */
  61. static void OpenGpioClock(XGpio::GpioPort port)
  62. {
  63.   if(port == XGpio::PortA)
  64.   {
  65.     LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOA);
  66.   }
  67.   else if(port == XGpio::PortB)
  68.   {
  69.     LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOB);
  70.   }
  71.   else if(port == XGpio::PortC)
  72.   {
  73.     LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOC);
  74.   }
  75. #ifdef GPIOD
  76.   else if(port == XGpio::PortD)
  77.   {
  78.     LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOD);
  79.   }
  80. #endif // GPIOD
  81. #ifdef GPIOE
  82.   else if(port == XGpio::PortE)
  83.   {
  84.     LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOE);
  85.   }
  86. #endif // GPIOE
  87. #ifdef GPIOF
  88.   else if(port == XGpio::PortF)
  89.   {
  90.     LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOF);
  91.   }
  92. #endif // GPIOF
  93. #ifdef GPIOG
  94.   else if(port == XGpio::PortG)
  95.   {
  96.     LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOG);
  97.   }
  98. #endif // GPIOG
  99. #ifdef GPIOH
  100.   else if(port == XGpio::PortH)
  101.   {
  102.     LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOH);
  103.   }
  104. #endif // GPIOH
  105. #ifdef GPIOI
  106.   else if(port == XGpio::PortI)
  107.   {
  108.     LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOI);
  109.   }
  110. #endif // GPIOI
  111. #ifdef GPIOJ
  112.   else if(port == XGpio::PortJ)
  113.   {
  114.     LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOJ);
  115.   }
  116. #endif // GPIOJ
  117. #ifdef GPIOK
  118.   else if(port == XGpio::PortK)
  119.   {
  120.     LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOK);
  121.   }
  122. #endif // GPIOK
  123. }
  124. /*!
  125.    \brief Close the general purpose I/O clock.
  126.    \param port: GPIO port.
  127. */
  128. static void CloseGpioClock(XGpio::GpioPort port)
  129. {
  130.   if(port == XGpio::PortA)
  131.   {
  132.     LL_AHB1_GRP1_DisableClock(LL_AHB1_GRP1_PERIPH_GPIOA);
  133.   }
  134.   else if(port == XGpio::PortB)
  135.   {
  136.     LL_AHB1_GRP1_DisableClock(LL_AHB1_GRP1_PERIPH_GPIOB);
  137.   }
  138.   else if(port == XGpio::PortC)
  139.   {
  140.     LL_AHB1_GRP1_DisableClock(LL_AHB1_GRP1_PERIPH_GPIOC);
  141.   }
  142. #ifdef GPIOD
  143.   else if(port == XGpio::PortD)
  144.   {
  145.     LL_AHB1_GRP1_DisableClock(LL_AHB1_GRP1_PERIPH_GPIOD);
  146.   }
  147. #endif // GPIOD
  148. #ifdef GPIOE
  149.   else if(port == XGpio::PortE)
  150.   {
  151.     LL_AHB1_GRP1_DisableClock(LL_AHB1_GRP1_PERIPH_GPIOE);
  152.   }
  153. #endif // GPIOE
  154. #ifdef GPIOF
  155.   else if(port == XGpio::PortF)
  156.   {
  157.     LL_AHB1_GRP1_DisableClock(LL_AHB1_GRP1_PERIPH_GPIOF);
  158.   }
  159. #endif // GPIOF
  160. #ifdef GPIOG
  161.   else if(port == XGpio::PortG)
  162.   {
  163.     LL_AHB1_GRP1_DisableClock(LL_AHB1_GRP1_PERIPH_GPIOG);
  164.   }
  165. #endif // GPIOG
  166. #ifdef GPIOH
  167.   else if(port == XGpio::PortH)
  168.   {
  169.     LL_AHB1_GRP1_DisableClock(LL_AHB1_GRP1_PERIPH_GPIOH);
  170.   }
  171. #endif // GPIOH
  172. #ifdef GPIOI
  173.   else if(port == XGpio::PortI)
  174.   {
  175.     LL_AHB1_GRP1_DisableClock(LL_AHB1_GRP1_PERIPH_GPIOI);
  176.   }
  177. #endif // GPIOI
  178. #ifdef GPIOJ
  179.   else if(port == XGpio::PortJ)
  180.   {
  181.     LL_AHB1_GRP1_DisableClock(LL_AHB1_GRP1_PERIPH_GPIOJ);
  182.   }
  183. #endif // GPIOJ
  184. #ifdef GPIOK
  185.   else if(port == XGpio::PortK)
  186.   {
  187.     LL_AHB1_GRP1_DisableClock(LL_AHB1_GRP1_PERIPH_GPIOK);
  188.   }
  189. #endif // GPIOK
  190. }
  191. /*!
  192.    \brief Set the general purpose I/O pin flag.
  193.    \param port: GPIO port.
  194.    \param pin:  GPIO pin.
  195. */
  196. static void SetGpioPinFlag(XGpio::GpioPort port, XGpio::GpioPin pin)
  197. {
  198.   if(port == XGpio::PortA)
  199.   {
  200.     openFlagPortA |= pin;
  201.   }
  202.   else if(port == XGpio::PortB)
  203.   {
  204.     openFlagPortB |= pin;
  205.   }
  206.   else if(port == XGpio::PortC)
  207.   {
  208.     openFlagPortC |= pin;
  209.   }
  210. #ifdef GPIOD
  211.   else if(port == XGpio::PortD)
  212.   {
  213.     openFlagPortD |= pin;
  214.   }
  215. #endif // GPIOD
  216. #ifdef GPIOE
  217.   else if(port == XGpio::PortE)
  218.   {
  219.     openFlagPortE |= pin;
  220.   }
  221. #endif // GPIOE
  222. #ifdef GPIOF
  223.   else if(port == XGpio::PortF)
  224.   {
  225.     openFlagPortF |= pin;
  226.   }
  227. #endif // GPIOF
  228. #ifdef GPIOG
  229.   else if(port == XGpio::PortG)
  230.   {
  231.     openFlagPortG |= pin;
  232.   }
  233. #endif // GPIOG
  234. #ifdef GPIOH
  235.   else if(port == XGpio::PortH)
  236.   {
  237.     openFlagPortH |= pin;
  238.   }
  239. #endif // GPIOH
  240. #ifdef GPIOI
  241.   else if(port == XGpio::PortI)
  242.   {
  243.     openFlagPortI |= pin;
  244.   }
  245. #endif // GPIOI
  246. #ifdef GPIOJ
  247.   else if(port == XGpio::PortJ)
  248.   {
  249.     openFlagPortJ |= pin;
  250.   }
  251. #endif // GPIOJ
  252. #ifdef GPIOK
  253.   else if(port == XGpio::PortK)
  254.   {
  255.     openFlagPortK |= pin;
  256.   }
  257. #endif // GPIOK
  258. }
  259. /*!
  260.    \brief Reset the general purpose I/O pin flag.
  261.    \param port: GPIO port.
  262.    \param pin:  GPIO pin.
  263. */
  264. static void ResetGpioPinFlag(XGpio::GpioPort port, XGpio::GpioPin pin)
  265. {
  266.   if(port == XGpio::PortA)
  267.   {
  268.     openFlagPortA &= ~pin;
  269.   }
  270.   else if(port == XGpio::PortB)
  271.   {
  272.     openFlagPortB &= ~pin;
  273.   }
  274.   else if(port == XGpio::PortC)
  275.   {
  276.     openFlagPortC &= ~pin;
  277.   }
  278. #ifdef GPIOD
  279.   else if(port == XGpio::PortD)
  280.   {
  281.     openFlagPortD &= ~pin;
  282.   }
  283. #endif // GPIOD
  284. #ifdef GPIOE
  285.   else if(port == XGpio::PortE)
  286.   {
  287.     openFlagPortE &= ~pin;
  288.   }
  289. #endif // GPIOE
  290. #ifdef GPIOF
  291.   else if(port == XGpio::PortF)
  292.   {
  293.     openFlagPortF &= ~pin;
  294.   }
  295. #endif // GPIOF
  296. #ifdef GPIOG
  297.   else if(port == XGpio::PortG)
  298.   {
  299.     openFlagPortG &= ~pin;
  300.   }
  301. #endif // GPIOG
  302. #ifdef GPIOH
  303.   else if(port == XGpio::PortH)
  304.   {
  305.     openFlagPortH &= ~pin;
  306.   }
  307. #endif // GPIOH
  308. #ifdef GPIOI
  309.   else if(port == XGpio::PortI)
  310.   {
  311.     openFlagPortI &= ~pin;
  312.   }
  313. #endif // GPIOI
  314. #ifdef GPIOJ
  315.   else if(port == XGpio::PortJ)
  316.   {
  317.     openFlagPortJ &= ~pin;
  318.   }
  319. #endif // GPIOJ
  320. #ifdef GPIOK
  321.   else if(port == XGpio::PortK)
  322.   {
  323.     openFlagPortK &= ~pin;
  324.   }
  325. #endif // GPIOK
  326. }
  327. /*!
  328.    \brief  Is a general purpose I/O pin flag set?
  329.    \param  port:  GPIO port.
  330.    \param  pin:   GPIO pin.
  331.    \retval true:  General purpose I/O pin flag are set.
  332.    \retval false: General purpose I/O pin flag is not set.
  333. */
  334. static bool IsSetGpioPinFlag(XGpio::GpioPort port, XGpio::GpioPin pin)
  335. {
  336.   if(port == XGpio::PortA)
  337.   {
  338.     return ((openFlagPortA & pin) == pin);
  339.   }
  340.   else if(port == XGpio::PortB)
  341.   {
  342.     return ((openFlagPortB & pin) == pin);
  343.   }
  344.   else if(port == XGpio::PortC)
  345.   {
  346.     return ((openFlagPortC & pin) == pin);
  347.   }
  348. #ifdef GPIOD
  349.   else if(port == XGpio::PortD)
  350.   {
  351.     return ((openFlagPortD & pin) == pin);
  352.   }
  353. #endif // GPIOD
  354. #ifdef GPIOE
  355.   else if(port == XGpio::PortE)
  356.   {
  357.     return ((openFlagPortE & pin) == pin);
  358.   }
  359. #endif // GPIOE
  360. #ifdef GPIOF
  361.   else if(port == XGpio::PortF)
  362.   {
  363.     return ((openFlagPortF & pin) == pin);
  364.   }
  365. #endif // GPIOF
  366. #ifdef GPIOG
  367.   else if(port == XGpio::PortG)
  368.   {
  369.     return ((openFlagPortG & pin) == pin);
  370.   }
  371. #endif // GPIOG
  372. #ifdef GPIOH
  373.   else if(port == XGpio::PortH)
  374.   {
  375.     return ((openFlagPortH & pin) == pin);
  376.   }
  377. #endif // GPIOH
  378. #ifdef GPIOI
  379.   else if(port == XGpio::PortI)
  380.   {
  381.     return ((openFlagPortI & pin) == pin);
  382.   }
  383. #endif // GPIOI
  384. #ifdef GPIOJ
  385.   else if(port == XGpio::PortJ)
  386.   {
  387.     return ((openFlagPortJ & pin) == pin);
  388.   }
  389. #endif // GPIOJ
  390. #ifdef GPIOK
  391.   else if(port == XGpio::PortK)
  392.   {
  393.     return ((openFlagPortK & pin) == pin);
  394.   }
  395. #endif // GPIOK
  396.   else
  397.   {
  398.     return true;
  399.   }
  400. }
  401. /*!
  402.    \brief  Is there a general purpose I/O pin set flag?
  403.    \param  port:  GPIO port.
  404.    \retval true:  There is a general purpose I/O pin set flag.
  405.    \retval false: There is no general purpose I/O pin set flag.
  406. */
  407. static bool IsHaveSetGpioPinFlag(XGpio::GpioPort port)
  408. {
  409.   if(port == XGpio::PortA)
  410.   {
  411.     return (openFlagPortA != 0);
  412.   }
  413.   else if(port == XGpio::PortB)
  414.   {
  415.     return (openFlagPortB != 0);
  416.   }
  417.   else if(port == XGpio::PortC)
  418.   {
  419.     return (openFlagPortC != 0);
  420.   }
  421. #ifdef GPIOD
  422.   else if(port == XGpio::PortD)
  423.   {
  424.     return (openFlagPortD != 0);
  425.   }
  426. #endif // GPIOD
  427. #ifdef GPIOE
  428.   else if(port == XGpio::PortE)
  429.   {
  430.     return (openFlagPortE != 0);
  431.   }
  432. #endif // GPIOE
  433. #ifdef GPIOF
  434.   else if(port == XGpio::PortF)
  435.   {
  436.     return (openFlagPortF != 0);
  437.   }
  438. #endif // GPIOF
  439. #ifdef GPIOG
  440.   else if(port == XGpio::PortG)
  441.   {
  442.     return (openFlagPortG != 0);
  443.   }
  444. #endif // GPIOG
  445. #ifdef GPIOH
  446.   else if(port == XGpio::PortH)
  447.   {
  448.     return (openFlagPortH != 0);
  449.   }
  450. #endif // GPIOH
  451. #ifdef GPIOI
  452.   else if(port == XGpio::PortI)
  453.   {
  454.     return (openFlagPortI != 0);
  455.   }
  456. #endif // GPIOI
  457. #ifdef GPIOJ
  458.   else if(port == XGpio::PortJ)
  459.   {
  460.     return (openFlagPortJ != 0);
  461.   }
  462. #endif // GPIOJ
  463. #ifdef GPIOK
  464.   else if(port == XGpio::PortK)
  465.   {
  466.     return (openFlagPortK != 0);
  467.   }
  468. #endif // GPIOK
  469.   else
  470.   {
  471.     return true;
  472.   }
  473. }
  474. /*!
  475.    \brief General purpose I/O module constructor.
  476.    \param port: GPIO port.
  477.    \param pin:  GPIO pin.
  478.    \param mode: GPIO mode.
  479. */
  480. XGpio::XGpio(GpioPort port, GpioPin pin, GpioMode mode)
  481. {
  482.   this->port      = port;
  483.   this->pin       = pin;
  484.   this->mode      = mode;
  485.   this->output    = OutputPushPull;
  486.   this->speed     = SpeedLow;
  487.   this->pull      = PullNo;
  488.   this->alternate = Alternate0;
  489.   this->level     = LevelLow;
  490.   this->openFlag  = false;
  491. }
  492. /*!
  493.    \brief   General purpose I / O module destructor.
  494.    \details Restore generic I/O to its default state(input mode, push-pull output,
  495.             low output speed, no pull, alternate function 0, low level).
  496. */
  497. XGpio::~XGpio()
  498. {
  499.   close();
  500. }
  501. /*!
  502.    \brief Set general purpose I/O port.
  503.    \param port: GPIO port.
  504. */
  505. void XGpio::setPort(GpioPort port)
  506. {
  507.   if(openFlag != true)
  508.   {
  509.     this->port = port;
  510.   }
  511. }
  512. /*!
  513.    \brief  Get general purpose I/O port.
  514.    \return GPIO port.
  515. */
  516. XGpio::GpioPort XGpio::getPort() const
  517. {
  518.   return port;
  519. }
  520. /*!
  521.    \brief Set general purpose I/O pin.
  522.    \param pin: GPIO pin.
  523. */
  524. void XGpio::setPin(GpioPin pin)
  525. {
  526.   if(openFlag != true)
  527.   {
  528.     this->pin = pin;
  529.   }
  530. }
  531. /*!
  532.    \brief  Get general purpose I/O pin.
  533.    \return GPIO pin.
  534. */
  535. XGpio::GpioPin XGpio::getPin() const
  536. {
  537.   return pin;
  538. }
  539. /*!
  540.    \brief Set general purpose I/O mode.
  541.    \param mode: GPIO mode.
  542. */
  543. void XGpio::setMode(GpioMode mode)
  544. {
  545.   this->mode = mode;
  546.
  547.   if(openFlag == true)
  548.   {
  549.     LL_GPIO_SetPinMode((GPIO_TypeDef *)port, pin, mode);
  550.   }
  551. }
  552. /*!
  553.    \brief  Get general purpose I/O mode.
  554.    \return GPIO mode.
  555. */
  556. XGpio::GpioMode XGpio::getMode() const
  557. {
  558.   return mode;
  559. }
  560. /*!
  561.    \brief Set general purpose I/O output type.
  562.    \param output: GPIO output type.
  563. */
  564. void XGpio::setOutput(GpioOutput output)
  565. {
  566.   this->output = output;
  567.
  568.   if(openFlag == true)
  569.   {
  570.     LL_GPIO_SetPinOutputType((GPIO_TypeDef *)port, pin, output);
  571.   }
  572. }
  573. /*!
  574.    \brief  Get general purpose I/O output type.
  575.    \return GPIO output type.
  576. */
  577. XGpio::GpioOutput XGpio::getOutput() const
  578. {
  579.   return output;
  580. }
  581. /*!
  582.    \brief Set general purpose I/O output speed.
  583.    \param speed: GPIO output speed.
  584. */
  585. void XGpio::setSpeed(GpioSpeed speed)
  586. {
  587.   this->speed = speed;
  588.
  589.   if(openFlag == true)
  590.   {
  591.     LL_GPIO_SetPinSpeed((GPIO_TypeDef *)port, pin, speed);
  592.   }
  593. }
  594. /*!
  595.    \brief  Get general purpose I/O output speed.
  596.    \return GPIO output speed.
  597. */
  598. XGpio::GpioSpeed XGpio::getSpeed() const
  599. {
  600.   return speed;
  601. }
  602. /*!
  603.    \brief Set general purpose I/O pull-up/pull-down.
  604.    \param pull: GPIO pull-up/pull-down.
  605. */
  606. void XGpio::setPull(GpioPull pull)
  607. {
  608.   this->pull = pull;
  609.
  610.   if(openFlag == true)
  611.   {
  612.     LL_GPIO_SetPinPull((GPIO_TypeDef *)port, pin, pull);
  613.   }
  614. }
  615. /*!
  616.    \brief  Get general purpose I/O pull-up/pull-down.
  617.    \return GPIO pull-up/pull-down.
  618. */
  619. XGpio::GpioPull XGpio::getPull() const
  620. {
  621.   return pull;
  622. }
  623. /*!
  624.    \brief Set general purpose I/O alternate function.
  625.    \param alternate: GPIO alternate function.
  626. */
  627. void XGpio::setAlternate(GpioAlternate alternate)
  628. {
  629.   this->alternate = alternate;
  630.
  631.   if(openFlag == true)
  632.   {
  633.     if(pin < Pin8)
  634.     {
  635.       LL_GPIO_SetAFPin_0_7((GPIO_TypeDef *)port, pin, alternate);
  636.     }
  637.     else
  638.     {
  639.       LL_GPIO_SetAFPin_8_15((GPIO_TypeDef *)port, pin, alternate);
  640.     }
  641.   }
  642. }
  643. /*!
  644.    \brief  Get general purpose I/O alternate function.
  645.    \return GPIO alternate function.
  646. */
  647. XGpio::GpioAlternate XGpio::getAlternate() const
  648. {
  649.   return alternate;
  650. }
  651. /*!
  652.    \brief Set general purpose I/O level status.
  653.    \param level: GPIO level status.
  654. */
  655. void XGpio::setLevel(GpioLevel level)
  656. {
  657.   this->level = level;
  658.
  659.   if(openFlag == true)
  660.   {
  661.     if(level != LevelLow)
  662.     {
  663.       LL_GPIO_SetOutputPin((GPIO_TypeDef *)port, pin);
  664.     }
  665.     else
  666.     {
  667.       LL_GPIO_ResetOutputPin((GPIO_TypeDef *)port, pin);
  668.     }
  669.   }
  670. }
  671. /*!
  672.    \brief  Get general purpose I/O level status.
  673.    \return GPIO level status.
  674. */
  675. XGpio::GpioLevel XGpio::getLevel()
  676. {
  677.   if(openFlag == true)
  678.   {
  679.     level = (GpioLevel)LL_GPIO_IsInputPinSet((GPIO_TypeDef *)port, pin);
  680.   }
  681.
  682.   return level;
  683. }
  684. /*!
  685.    \brief Toggle general purpose I/O level status.
  686. */
  687. void XGpio::toggle()
  688. {
  689.   level = level != LevelLow ? LevelLow : LevelHigh;
  690.
  691.   if(openFlag == true)
  692.   {
  693.     LL_GPIO_TogglePin((GPIO_TypeDef *)port, pin);
  694.   }
  695. }
  696. /*!
  697.    \brief  Open general purpose I/O pin.
  698.    \retval true:  General purpose I/O pin open success.
  699.    \retval false: General purpose I/O pin open failure.
  700. */
  701. bool XGpio::open()
  702. {
  703.   if(IsSetGpioPinFlag(port, pin) != true)
  704.   {
  705.     if(IsHaveSetGpioPinFlag(port) != true)
  706.     {
  707.       OpenGpioClock(port);
  708.     }
  709.
  710.     SetGpioPinFlag(port, pin);
  711.
  712.     LL_GPIO_SetPinMode((GPIO_TypeDef *)port, pin, mode);
  713.     LL_GPIO_SetPinOutputType((GPIO_TypeDef *)port, pin, output);
  714.     LL_GPIO_SetPinSpeed((GPIO_TypeDef *)port, pin, speed);
  715.     LL_GPIO_SetPinPull((GPIO_TypeDef *)port, pin, pull);
  716.
  717.     if(pin < Pin8)
  718.     {
  719.       LL_GPIO_SetAFPin_0_7((GPIO_TypeDef *)port, pin, alternate);
  720.     }
  721.     else
  722.     {
  723.       LL_GPIO_SetAFPin_8_15((GPIO_TypeDef *)port, pin, alternate);
  724.     }
  725.
  726.     if(level != LevelLow)
  727.     {
  728.       LL_GPIO_SetOutputPin((GPIO_TypeDef *)port, pin);
  729.     }
  730.     else
  731.     {
  732.       LL_GPIO_ResetOutputPin((GPIO_TypeDef *)port, pin);
  733.     }
  734.
  735.     openFlag = true;
  736.
  737.     return true;
  738.   }
  739.   else
  740.   {
  741.     return false;
  742.   }
  743. }
  744. /*!
  745.    \brief   Close general purpose I/O pin.
  746.    \details Restore generic I/O to its default state(input mode, push-pull output,
  747.             low output speed, no pull, alternate function 0, low level).
  748. */
  749. void XGpio::close()
  750. {
  751.   if(openFlag == true)
  752.   {
  753.     LL_GPIO_SetPinMode((GPIO_TypeDef *)port, pin, ModeInput);
  754.     LL_GPIO_SetPinOutputType((GPIO_TypeDef *)port, pin, OutputPushPull);
  755.     LL_GPIO_SetPinSpeed((GPIO_TypeDef *)port, pin, SpeedLow);
  756.     LL_GPIO_SetPinPull((GPIO_TypeDef *)port, pin, PullNo);
  757.
  758.     if(pin < Pin8)
  759.     {
  760.       LL_GPIO_SetAFPin_0_7((GPIO_TypeDef *)port, pin, Alternate0);
  761.     }
  762.     else
  763.     {
  764.       LL_GPIO_SetAFPin_8_15((GPIO_TypeDef *)port, pin, Alternate0);
  765.     }
  766.
  767.     LL_GPIO_ResetOutputPin((GPIO_TypeDef *)port, pin);
  768.
  769.     ResetGpioPinFlag(port, pin);
  770.
  771.     if(IsHaveSetGpioPinFlag(port) != true)
  772.     {
  773.       CloseGpioClock(port);
  774.     }
  775.
  776.     openFlag = false;
  777.   }
  778. }
  779. /*!
  780.    \brief  Is the general purpose I/O pin open?
  781.    \retval true:  General purpose I/O pin open.
  782.    \retval false: General purpose I/O pin not open.
  783. */
  784. bool XGpio::isOpen() const
  785. {
  786.   return openFlag;
  787. }
例程
  1. /**
  3.   * @file    main.cpp
  4.   * @author  XinLi
  5.   * @version v1.0
  6.   * @date    20-March-2018
  7.   * @brief   Main program body.
  9.   * @attention
  10.   *
  12.   *
  17.   *
  22.   *
  25.   *
  27.   */
  28. /* Header includes -----------------------------------------------------------*/
  29. #include "main.h"
  30. #include "stm32f4xx_xgpio.h"
  31. /* Macro definitions ---------------------------------------------------------*/
  32. /* Type definitions ----------------------------------------------------------*/
  33. /* Variable declarations -----------------------------------------------------*/
  34. /* Variable definitions ------------------------------------------------------*/
  35. /* Function declarations -----------------------------------------------------*/
  36. static void SystemClock_Config(void);
  37. /* Function definitions ------------------------------------------------------*/
  38. /**
  39.   * @brief  Main program.
  40.   * @param  None.
  41.   * @return None.
  42.   */
  43. int main(void)
  44. {
  45.   /* STM32F4xx HAL library initialization:
  46.        - Configure the Flash prefetch, instruction and Data caches
  47.        - Configure the Systick to generate an interrupt each 1 msec
  48.        - Set NVIC Group Priority to 4
  49.        - Global MSP (MCU Support Package) initialization
  50.      */
  51.   HAL_Init();
  52.
  53.   /* Configure the system clock to 168 MHz */
  54.   SystemClock_Config();
  55.
  56.   XGpio led0(XGpio::PortF, XGpio::Pin9,  XGpio::ModeOutput);
  57.   XGpio led1(XGpio::PortF, XGpio::Pin10, XGpio::ModeOutput);
  58.
  59.   led0.open();
  60.   led1.open();
  61.
  62.   for(;;)
  63.   {
  64.     HAL_Delay(250);
  65.     led0.toggle();
  66.     HAL_Delay(250);
  67.     led1.toggle();
  68.   }
  69. }
  70. /**
  71.   * @brief  System Clock Configuration
  72.   *         The system Clock is configured as follow :
  73.   *            System Clock source            = PLL (HSE)
  74.   *            SYSCLK(Hz)                     = 168000000
  75.   *            HCLK(Hz)                       = 168000000
  76.   *            AHB Prescaler                  = 1
  77.   *            APB1 Prescaler                 = 4
  78.   *            APB2 Prescaler                 = 2
  79.   *            HSE Frequency(Hz)              = 8000000
  80.   *            PLL_M                          = 8
  81.   *            PLL_N                          = 336
  82.   *            PLL_P                          = 2
  83.   *            PLL_Q                          = 7
  84.   *            VDD(V)                         = 3.3
  85.   *            Main regulator output voltage  = Scale1 mode
  86.   *            Flash Latency(WS)              = 5
  87.   * @param  None
  88.   * @retval None
  89.   */
  90. static void SystemClock_Config(void)
  91. {
  92.   RCC_ClkInitTypeDef RCC_ClkInitStruct;
  93.   RCC_OscInitTypeDef RCC_OscInitStruct;
  94.   /* Enable Power Control clock */
  95.   __HAL_RCC_PWR_CLK_ENABLE();
  96.   /* The voltage scaling allows optimizing the power consumption when the device is
  97.      clocked below the maximum system frequency, to update the voltage scaling value
  98.      regarding system frequency refer to product datasheet.  */
  99.   __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  100.   /* Enable HSE Oscillator and activate PLL with HSE as source */
  101.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  102.   RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  103.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  104.   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  105.   RCC_OscInitStruct.PLL.PLLM = 8;
  106.   RCC_OscInitStruct.PLL.PLLN = 336;
  107.   RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  108.   RCC_OscInitStruct.PLL.PLLQ = 7;
  109.   HAL_RCC_OscConfig(&RCC_OscInitStruct);
  110.
  111.   /* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2
  112.      clocks dividers */
  113.   RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
  114.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  115.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  116.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  117.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  118.   HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5);
  119.   /* STM32F405x/407x/415x/417x Revision Z devices: prefetch is supported  */
  120.   if (HAL_GetREVID() == 0x1001)
  121.   {
  122.     /* Enable the Flash prefetch */
  123.     __HAL_FLASH_PREFETCH_BUFFER_ENABLE();
  124.   }
  125. }
归档链接
STM32F4 C++ 封装库 之 EXTI
参与人数 1金币 +20 收起 理由
eric2013 + 20 赞一个!
发表于 2018-4-1 17:44:39 | 显示全部楼层
对于单片机来说,你这种封装太过“重”了。
发表于 2018-4-2 01:45:33 | 显示全部楼层
谢谢楼主分享
发表于 2018-4-3 08:51:53 | 显示全部楼层
用C++的优势体现在哪些方面?
 楼主| 发表于 2018-4-4 08:51:51 | 显示全部楼层
cjunrong 发表于 2018-4-3 08:51
用C++的优势体现在哪些方面?
可以看一下 mbed 就就知道优势在哪了。
发表于 2018-4-6 12:52:07 | 显示全部楼层
为什么要自己封装呢、mbed都帮你做好了。而且比你的更好。
GMT+8, 2024-6-11 19:25 , Processed in 0.167733 second(s), 26 queries .
