查看: 3375|回复: 0
[STM32H7] RTX5针对HAL库使用滴答定时器的处理方法
发表于 2018-4-5 12:09:37 | 显示全部楼层 |阅读模式
  1. /**
  2.   * Override default HAL_GetTick function
  3.   */
  4. uint32_t HAL_GetTick (void) {
  5.   static uint32_t ticks = 0U;
  6.          uint32_t i;
  7.   if (osKernelGetState () == osKernelRunning) {
  8.     return ((uint32_t)osKernelGetTickCount ());
  9.   }
  10.   /* If Kernel is not running wait approximately 1 ms then increment
  11.      and return auxiliary tick counter value */
  12.   for (i = (SystemCoreClock >> 14U); i > 0U; i--) {
  13.     __NOP(); __NOP(); __NOP(); __NOP(); __NOP(); __NOP();
  14.     __NOP(); __NOP(); __NOP(); __NOP(); __NOP(); __NOP();
  15.   }
  16.   return ++ticks;
  17. }
GMT+8, 2025-7-6 03:25 , Processed in 0.205581 second(s), 24 queries .
