查看: 2331|回复: 1
[Boot Flash] 新版JLINK驱动V6.32b解决了特定条件下无法正常启动HyperFlash进行调试的问题
发表于 2018-5-12 01:41:54 | 显示全部楼层 |阅读模式
官方下载地址:https://www.segger.com/downloads ... ndDocumentationPack
这个问题好像偶尔有那么一次,不过大部分都是调试正常的,遇到不正常时,重新启动调试即可。
RT1052使用JLINK的调试方法在这个帖子里面有贴出:
http://www.armbbs.cn/forum.php?mod=viewthread&tid=86488&extra=page%3D1
 楼主| 发表于 2018-5-12 02:29:19 | 显示全部楼层
We are pleased to announce the availability of a new version of the J-Link software and
documentation pack V6.32b with the following changes:
- DLL (SDK): Callback functions where not invalidated on JLINK_Close(). Fixed.
- DLL: Infineon TLE986x/TLE987x: Added support for data flash and fixed two bugs in the algorithm.
- DLL: NXP LPC54018: The J-Link flashloader did not restore some clock register. Fixed.
- DLL: NXP LPC802 / LPC804 / LPC845: Under special circumstances (empty was empty before programming), debug session could not be started properly. Fixed.
- DLL: NXP LPC804: Erase of the last sector did not work. Fixed.
- DLL: NXP LPC845: Reset did not work properly. Fixed.
- DLL: NXP iMXRT105x (HyperFlash): Under special circumstances, a debug session could not be started successfully. Fixed.
- DLL: Under special circumstances, Keil MDKs could crash when using TCP/IP as host interface. Fixed.
- DLL: Under special circumstances, it could happen that a SYS_Sleep() in a J-Link script file could lead to an endless loop. Fixed.
- GDBServer: GUI version was not correctly updated on target state change (halted -> executing). Fixed.
- J-Flash: NXP iMX7D: J-Flash did not support the entire 256 MB QSPI flash section but 64 MB, only. Fixed.
- RTT: Wrong pointer type in function SEGGER_RTT_HasDataUp. Fixed.
GMT+8, 2025-5-12 18:39 , Processed in 0.204167 second(s), 27 queries .
