查看: 4038|回复: 2
[μCOS-II] CPU_INIT这个函数作用是什么?
发表于 2018-6-27 14:21:29 | 显示全部楼层 |阅读模式
注释掉也能编译通过:
static void AppTaskStart(void *p_arg)
    /* 仅用于避免编译器告警,编译器不会产生任何目标代码 */
    (void)p_arg;
        /* BSP 初始化。 BSP = Board Support Package 板级支持包,可以理解为底层驱动。*/
        bsp_Init();
// CPU_Init();
        BSP_Tick_Init();
发表于 2018-6-28 01:20:53 | 显示全部楼层
三个作用
(a) Initialize CPU timestamps
(b) Initialize CPU interrupts disabled time measurements
(c) Initialize CPU host name
  1. /*
  3. *                                             CPU_Init()
  4. *
  5. * Description : (1) Initialize CPU module :
  6. *
  7. *                   (a) Initialize CPU timestamps
  8. *                   (b) Initialize CPU interrupts disabled time measurements
  9. *                   (c) Initialize CPU host name
  10. *
  11. *
  12. * Argument(s) : none.
  13. *
  14. * Return(s)   : none.
  15. *
  16. * Caller(s)   : Your Product's Application.
  17. *
  18. *               This function is a CPU initialization function & MAY be called by application/
  19. *               initialization function(s).
  20. *
  21. * Note(s)     : (2) CPU_Init() MUST be called ... :
  22. *
  23. *                   (a) ONLY ONCE from a product's application; ...
  24. *                   (b) BEFORE product's application calls any core CPU module function(s)
  25. *
  26. *               (3) The following initialization functions MUST be sequenced as follows :
  27. *
  28. *                   (a) CPU_TS_Init()           SHOULD precede ALL calls to other CPU timestamp functions
  29. *
  30. *                   (b) CPU_IntDisMeasInit()    SHOULD precede ALL calls to CPU_CRITICAL_ENTER()/CPU_CRITICAL_EXIT()
  31. *                                                   & other CPU interrupts disabled time measurement functions
  32. *********************************************************************************************************
  33. */
  34. void  CPU_Init (void)
  35. {
  36.        /* --------------------- INIT TS ---------------------- */
  37. #if ((CPU_CFG_TS_EN     == DEF_ENABLED) || \
  38.      (CPU_CFG_TS_TMR_EN == DEF_ENABLED))
  39.     CPU_TS_Init();                                              /* See Note #3a.                                        */
  40. #endif
  41.        /* -------------- INIT INT DIS TIME MEAS -------------- */
  42. #ifdef  CPU_CFG_INT_DIS_MEAS_EN
  43.     CPU_IntDisMeasInit();                                       /* See Note #3b.                                        */
  44. #endif
  45.        /* ------------------ INIT CPU NAME ------------------- */
  46. #if (CPU_CFG_NAME_EN == DEF_ENABLED)
  47.      CPU_NameInit();
  48. #endif
  49. #if (CPU_CFG_CACHE_MGMT_EN == DEF_ENABLED)
  50.      CPU_Cache_Init();
  51. #endif
  52. }
 楼主| 发表于 2018-6-28 11:17:37 | 显示全部楼层
eric2013 发表于 2018-6-28 01:20
三个作用
(b) Initialize CPU interrupts disabled time measurements ...
好的谢谢啊。为什么不用也不影响代码呢
GMT+8, 2025-5-17 06:40 , Processed in 0.255175 second(s), 24 queries .
