查看: 5841|回复: 4
[有问必答] FreeRTOS堆栈设置导致任务不执行切换
发表于 2018-7-9 08:30:16 | 显示全部楼层 |阅读模式
我使用的STM32F103VE运行的STM32CubeMX生成的freertos工程。
一共有两个任务,TSAK1和TASK2都是翻转LED,TASK1的堆栈设置64,两个任务切换、运行正常。但是TASK1任务堆栈更改为128的话,就不执行任务切换,只有TASK1的任务在运行
代码如下
  1. #define START_TASK_PRIO 1
  2. #define START_STK_SIZE  128
  3. TaskHandle_t StartTask_Handle;
  4. #define TASK1_TASK_PRIO 2
  5. #define TASK1_STK_SIZE  64
  6. TaskHandle_t Task1Task_Handle;
  7. #define TASK2_TASK_PRIO 3
  8. #define TASK2_STK_SIZE  64
  9. TaskHandle_t Task2Task_Handle;
  1. void start_task(void *pvParameters)
  2. {
  3.   taskENTER_CRITICAL();
  4.
  5. /*
  6.         xTaskCreate( (TaskFunction_t) key_task,
  7.               (const char *  ) "key task",
  8.               (const uint16_t) KEY_STK_SIZE,
  9.               (void *        ) NULL,
  10.               (UBaseType_t   ) KEY_TASK_PRIO,
  11.               (TaskHandle_t *) &KEYTask_Handle );
  12. */
  13.
  14.   xTaskCreate( (TaskFunction_t) task1_task,
  15.               (const char *  ) "task1 task",
  16.               (const uint16_t) TASK1_STK_SIZE,
  17.               (void *        ) NULL,
  18.               (UBaseType_t   ) TASK1_TASK_PRIO,
  19.               (TaskHandle_t *) &Task1Task_Handle );
  20.
  21.   xTaskCreate( (TaskFunction_t) task2_task,
  22.               (const char *  ) "task2 task",
  23.               (const uint16_t) TASK2_STK_SIZE,
  24.               (void *        ) NULL,
  25.               (UBaseType_t   ) TASK2_TASK_PRIO,
  26.               (TaskHandle_t *) &Task2Task_Handle );
  27.
  28.   vTaskDelete(StartTask_Handle);
  29.
  30.   taskEXIT_CRITICAL();
  31. }
  32. void task1_task(void *pvParameters)
  33. {
  34.   while(1)
  35.   {
  36.     HAL_GPIO_TogglePin(GPIOD,LED2_Pin);
  37.     osDelay(200);
  38.   }
  39. }
  40. void task2_task(void *pvParameters)
  41. {
  42.   while(1)
  43.   {
  44.     HAL_GPIO_TogglePin(GPIOD,LED1_Pin);
  45.     osDelay(200);
  46.   }
  47. }
  1. int main(void)
  2. {
  3.   HAL_Init();
  4.   SystemClock_Config();
  5.   MX_GPIO_Init();
  6.   MX_FREERTOS_Init();
  7.         xTaskCreate( (TaskFunction_t) start_task,
  8.               (const char *  ) "start task",
  9.               (const uint16_t) START_STK_SIZE,
  10.               (void *        ) NULL,
  11.               (UBaseType_t   ) START_TASK_PRIO,
  12.               (TaskHandle_t *) &StartTask_Handle );
  13.   /* Start scheduler */
  14.   osKernelStart();
  15.   while (1)
  16.   {
  17.   }
  18. }
发表于 2018-7-9 09:01:47 | 显示全部楼层
特别注意CubeMX 使用的FreeRTOS是强制开启了CMSIS-RTOS V1封装层的,加上这个封装层的话,默认情况下main函数也是一个任务。
API的时候不要再使用FreeRTOS自己的了,要使用CMSIS-RTOS的,详情看你CMSIS-RTOS V1封装层的help文档学习。这个V1封装层,我自己基本不用,不太熟悉,所以你看文档研究下
 楼主| 发表于 2018-7-10 08:10:21 | 显示全部楼层
eric2013 发表于 2018-7-9 09:01
特别注意CubeMX 使用的FreeRTOS是强制开启了CMSIS-RTOS V1封装层的,加上这个封装层的话,默认情况下main函 ...
大神就是牛,果然是这样的
发表于 2018-8-26 10:34:22 | 显示全部楼层
我觉得是FreeRTOS堆设置的太少了,TASK2就不够堆来创建,故TASK2根本就没有创建 成功。
FreeRTOS的任务创建时填写的堆大小是4倍字节的。
发表于 2018-8-27 09:50:13 | 显示全部楼层
FreeRTOS的任务创 ...
我表示我在不同的栈中并没有发生问题
GMT+8, 2025-7-6 17:37 , Processed in 0.221703 second(s), 24 queries .
