我补充下对应的API
[C] 纯文本查看 复制代码 /**
* @brief To Enable optimize the I/O speed when the product voltage is low.
* @note This bit is active only if PRODUCT_BELOW_25V user option bit is set. It must be
* used only if the product supply voltage is below 2.5 V. Setting this bit when VDD is
* higher than 2.5 V might be destructive.
* @retval None
void HAL_SYSCFG_EnableIOSpeedOptimize(void)
#if defined(SYSCFG_CCCSR_HSLV)
SET_BIT(SYSCFG->CCCSR, SYSCFG_CCCSR_HSLV);
#else
SET_BIT(SYSCFG->CCCSR, (SYSCFG_CCCSR_HSLV0| SYSCFG_CCCSR_HSLV1 | SYSCFG_CCCSR_HSLV2 | SYSCFG_CCCSR_HSLV3));
#endif /* SYSCFG_CCCSR_HSLV */
