查看: 4773|回复: 0
[HAL学习笔记] HAL库源文件stm32h7xx_hal_conf.h学习笔记,专门用于HAL库配置(2018-07-26 V1.0)
发表于 2018-7-26 16:16:28 | 显示全部楼层 |阅读模式
说明:
这个文件是HAL库专用的配置文件,如同FreeRTOS的FreeRTOSConfig.h文件。
当前使用这个文件最主要是外部晶振的配置,一定要保证这里HSE_VALUE的大小跟外部晶振的实际大小匹配。
其它的配置暂时还用不到,另外为了方便此文件的修改,将其也添加到工程里面:
  1. /**
  2.   ******************************************************************************
  3.   * @file    stm32h7xx_hal_conf_template.h
  4.   * @author  MCD Application Team
  5.   * @version V1.2.0
  6.   * @date    29-December-2017
  7.   * @brief   HAL configuration template file.
  8.   *          This file should be copied to the application folder and renamed
  9.   *          to stm32h7xx_hal_conf.h.
  10.   ******************************************************************************
  11.   * @attention
  12.   *
  13.   * <h2><center>&#169; COPYRIGHT(c) 2017 STMicroelectronics</center></h2>
  14.   *
  15.   * Redistribution and use in source and binary forms, with or without modification,
  16.   * are permitted provided that the following conditions are met:
  17.   *   1. Redistributions of source code must retain the above copyright notice,
  18.   *      this list of conditions and the following disclaimer.
  19.   *   2. Redistributions in binary form must reproduce the above copyright notice,
  20.   *      this list of conditions and the following disclaimer in the documentation
  21.   *      and/or other materials provided with the distribution.
  22.   *   3. Neither the name of STMicroelectronics nor the names of its contributors
  23.   *      may be used to endorse or promote products derived from this software
  24.   *      without specific prior written permission.
  25.   *
  26.   * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  27.   * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  28.   * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  29.   * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  30.   * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  31.   * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  32.   * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  33.   * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  34.   * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  35.   * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
  36.   *
  37.   ******************************************************************************
  38.   */
  39. /* Define to prevent recursive inclusion -------------------------------------*/
  40. #ifndef __STM32H7xx_HAL_CONF_H
  41. #define __STM32H7xx_HAL_CONF_H
  42. #ifdef __cplusplus
  43. extern "C" {
  44. #endif
  45. /* Exported types ------------------------------------------------------------*/
  46. /* Exported constants --------------------------------------------------------*/
  47. /* ########################## Module Selection ############################## */
  48. /**
  49.   * @brief This is the list of modules to be used in the HAL driver
  50.   */
  51. #define HAL_MODULE_ENABLED
  52. #define HAL_ADC_MODULE_ENABLED
  53. #define HAL_CEC_MODULE_ENABLED
  54. #define HAL_COMP_MODULE_ENABLED
  55. #define HAL_CORTEX_MODULE_ENABLED
  56. #define HAL_CRC_MODULE_ENABLED
  57. #define HAL_CRYP_MODULE_ENABLED
  58. #define HAL_DAC_MODULE_ENABLED
  59. #define HAL_DCMI_MODULE_ENABLED
  60. #define HAL_DFSDM_MODULE_ENABLED
  61. #define HAL_DMA_MODULE_ENABLED
  62. #define HAL_DMA2D_MODULE_ENABLED
  63. #define HAL_ETH_MODULE_ENABLED
  64. #define HAL_FDCAN_MODULE_ENABLED
  65. #define HAL_FLASH_MODULE_ENABLED
  66. #define HAL_GPIO_MODULE_ENABLED
  67. #define HAL_HASH_MODULE_ENABLED
  68. #define HAL_HCD_MODULE_ENABLED
  69. #define HAL_HRTIM_MODULE_ENABLED
  70. #define HAL_HSEM_MODULE_ENABLED
  71. #define HAL_I2C_MODULE_ENABLED
  72. #define HAL_I2S_MODULE_ENABLED
  73. #define HAL_IRDA_MODULE_ENABLED
  74. #define HAL_IWDG_MODULE_ENABLED
  75. #define HAL_JPEG_MODULE_ENABLED
  76. #define HAL_LPTIM_MODULE_ENABLED
  77. #define HAL_LTDC_MODULE_ENABLED
  78. #define HAL_MDIOS_MODULE_ENABLED
  79. #define HAL_MDMA_MODULE_ENABLED
  80. #define HAL_MMC_MODULE_ENABLED
  81. #define HAL_NAND_MODULE_ENABLED
  82. #define HAL_NOR_MODULE_ENABLED
  83. #define HAL_OPAMP_MODULE_ENABLED
  84. #define HAL_PCD_MODULE_ENABLED
  85. #define HAL_PWR_MODULE_ENABLED
  86. #define HAL_QSPI_MODULE_ENABLED
  87. #define HAL_RCC_MODULE_ENABLED
  88. #define HAL_RNG_MODULE_ENABLED
  89. #define HAL_RTC_MODULE_ENABLED
  90. #define HAL_SAI_MODULE_ENABLED
  91. #define HAL_SD_MODULE_ENABLED
  92. #define HAL_SDRAM_MODULE_ENABLED
  93. #define HAL_SMARTCARD_MODULE_ENABLED
  94. #define HAL_SMBUS_MODULE_ENABLED
  95. #define HAL_SPDIFRX_MODULE_ENABLED
  96. #define HAL_SPI_MODULE_ENABLED
  97. #define HAL_SRAM_MODULE_ENABLED
  98. #define HAL_SWPMI_MODULE_ENABLED
  99. #define HAL_TIM_MODULE_ENABLED
  100. #define HAL_UART_MODULE_ENABLED
  101. #define HAL_USART_MODULE_ENABLED
  102. #define HAL_WWDG_MODULE_ENABLED
  103. /* ########################## Oscillator Values adaptation ####################*/
  104. /**
  105.   * @brief Adjust the value of External High Speed oscillator (HSE) used in your application.
  106.   *        This value is used by the RCC HAL module to compute the system frequency
  107.   *        (when HSE is used as system clock source, directly or through the PLL).
  108.   */
  109. #if !defined  (HSE_VALUE)
  110. #define HSE_VALUE    ((uint32_t)8000000) /*!< Value of the External oscillator in Hz */
  111. #endif /* HSE_VALUE */
  112. #if !defined  (HSE_STARTUP_TIMEOUT)
  113.   #define HSE_STARTUP_TIMEOUT    ((uint32_t)5000)   /*!< Time out for HSE start up, in ms */
  114. #endif /* HSE_STARTUP_TIMEOUT */
  115. /**
  116.   * @brief Internal  oscillator (CSI) default value.
  117.   *        This value is the default CSI value after Reset.
  118.   */
  119. #if !defined  (CSI_VALUE)
  120.   #define CSI_VALUE    ((uint32_t)4000000) /*!< Value of the Internal oscillator in Hz*/
  121. #endif /* CSI_VALUE */
  122.
  123. /**
  124.   * @brief Internal High Speed oscillator (HSI) value.
  125.   *        This value is used by the RCC HAL module to compute the system frequency
  126.   *        (when HSI is used as system clock source, directly or through the PLL).
  127.   */
  128. #if !defined  (HSI_VALUE)
  129.   #define HSI_VALUE    ((uint32_t)64000000) /*!< Value of the Internal oscillator in Hz*/
  130. #endif /* HSI_VALUE */
  131. /**
  132.   * @brief External Low Speed oscillator (LSE) value.
  133.   *        This value is used by the UART, RTC HAL module to compute the system frequency
  134.   */
  135. #if !defined  (LSE_VALUE)
  136.   #define LSE_VALUE    ((uint32_t)32768) /*!< Value of the External oscillator in Hz*/
  137. #endif /* LSE_VALUE */
  138.
  139. #if !defined  (LSE_STARTUP_TIMEOUT)
  140.   #define LSE_STARTUP_TIMEOUT    ((uint32_t)5000)   /*!< Time out for LSE start up, in ms */
  141. #endif /* LSE_STARTUP_TIMEOUT */
  142. /**
  143.   * @brief External clock source for I2S peripheral
  144.   *        This value is used by the I2S HAL module to compute the I2S clock source
  145.   *        frequency, this source is inserted directly through I2S_CKIN pad.
  146.   */
  147. #if !defined  (EXTERNAL_CLOCK_VALUE)
  148.   #define EXTERNAL_CLOCK_VALUE    12288000U /*!< Value of the External clock in Hz*/
  149. #endif /* EXTERNAL_CLOCK_VALUE */
  150. /* Tip: To avoid modifying this file each time you need to use different HSE,
  151.    ===  you can define the HSE value in your toolchain compiler preprocessor. */
  152. /* ########################### System Configuration ######################### */
  153. /**
  154.   * @brief This is the HAL system configuration section
  155.   */
  156. #define  VDD_VALUE                    ((uint32_t)3300) /*!< Value of VDD in mv */
  157. #define  TICK_INT_PRIORITY            ((uint32_t)0x0F) /*!< tick interrupt priority */
  158. #define  USE_RTOS                     0
  159. /* #define  USE_SD_TRANSCEIVER           1U   */            /*!< use uSD Transceiver */
  160. /* ########################### Ethernet Configuration ######################### */
  161. #define ETH_TX_DESC_CNT         4  /* number of Ethernet Tx DMA descriptors */
  162. #define ETH_RX_DESC_CNT         4  /* number of Ethernet Rx DMA descriptors */
  163. #define ETH_MAC_ADDR0    ((uint8_t)0x02)
  164. #define ETH_MAC_ADDR1    ((uint8_t)0x00)
  165. #define ETH_MAC_ADDR2    ((uint8_t)0x00)
  166. #define ETH_MAC_ADDR3    ((uint8_t)0x00)
  167. #define ETH_MAC_ADDR4    ((uint8_t)0x00)
  168. #define ETH_MAC_ADDR5    ((uint8_t)0x00)
  169. /* ########################## Assert Selection ############################## */
  170. /**
  171.   * @brief Uncomment the line below to expanse the "assert_param" macro in the
  172.   *        HAL drivers code
  173.   */
  174. /* #define USE_FULL_ASSERT    1 */
  175. /* ################## SPI peripheral configuration ########################## */
  176. /**
  177.   * @brief Used to activate CRC feature inside HAL SPI Driver
  178.   *        Activated   (1U): CRC code is compiled within HAL SPI driver
  179.   *        Deactivated (0U): CRC code excluded from HAL SPI driver
  180.   */
  181. #define USE_SPI_CRC                   1U
  182. /* Includes ------------------------------------------------------------------*/
  183. /**
  184.   * @brief Include module's header file
  185.   */
  186. #ifdef HAL_RCC_MODULE_ENABLED
  187.   #include "stm32h7xx_hal_rcc.h"
  188. #endif /* HAL_RCC_MODULE_ENABLED */
  189. #ifdef HAL_GPIO_MODULE_ENABLED
  190.   #include "stm32h7xx_hal_gpio.h"
  191. #endif /* HAL_GPIO_MODULE_ENABLED */
  192. #ifdef HAL_DMA_MODULE_ENABLED
  193.   #include "stm32h7xx_hal_dma.h"
  194. #endif /* HAL_DMA_MODULE_ENABLED */
  195. #ifdef HAL_HASH_MODULE_ENABLED
  196.   #include "stm32h7xx_hal_hash.h"
  197. #endif /* HAL_HASH_MODULE_ENABLED */
  198. #ifdef HAL_DCMI_MODULE_ENABLED
  199.   #include "stm32h7xx_hal_dcmi.h"
  200. #endif /* HAL_DCMI_MODULE_ENABLED */
  201. #ifdef HAL_DMA2D_MODULE_ENABLED
  202.   #include "stm32h7xx_hal_dma2d.h"
  203. #endif /* HAL_DMA2D_MODULE_ENABLED */
  204. #ifdef HAL_DFSDM_MODULE_ENABLED
  205.   #include "stm32h7xx_hal_dfsdm.h"
  206. #endif /* HAL_DFSDM_MODULE_ENABLED */
  207. #ifdef HAL_ETH_MODULE_ENABLED
  208.   #include "stm32h7xx_hal_eth.h"
  209. #endif /* HAL_ETH_MODULE_ENABLED */
  210. #ifdef HAL_CORTEX_MODULE_ENABLED
  211.   #include "stm32h7xx_hal_cortex.h"
  212. #endif /* HAL_CORTEX_MODULE_ENABLED */
  213. #ifdef HAL_ADC_MODULE_ENABLED
  214.   #include "stm32h7xx_hal_adc.h"
  215. #endif /* HAL_ADC_MODULE_ENABLED */
  216. #ifdef HAL_FDCAN_MODULE_ENABLED
  217.   #include "stm32h7xx_hal_fdcan.h"
  218. #endif /* HAL_FDCAN_MODULE_ENABLED */
  219. #ifdef HAL_CEC_MODULE_ENABLED
  220.   #include "stm32h7xx_hal_cec.h"
  221. #endif /* HAL_CEC_MODULE_ENABLED */
  222. #ifdef HAL_COMP_MODULE_ENABLED
  223.   #include "stm32h7xx_hal_comp.h"
  224. #endif /* HAL_COMP_MODULE_ENABLED */
  225. #ifdef HAL_CRC_MODULE_ENABLED
  226.   #include "stm32h7xx_hal_crc.h"
  227. #endif /* HAL_CRC_MODULE_ENABLED */
  228. #ifdef HAL_CRYP_MODULE_ENABLED
  229.   #include "stm32h7xx_hal_cryp.h"
  230. #endif /* HAL_CRYP_MODULE_ENABLED */
  231. #ifdef HAL_DAC_MODULE_ENABLED
  232.   #include "stm32h7xx_hal_dac.h"
  233. #endif /* HAL_DAC_MODULE_ENABLED */
  234. #ifdef HAL_FLASH_MODULE_ENABLED
  235.   #include "stm32h7xx_hal_flash.h"
  236. #endif /* HAL_FLASH_MODULE_ENABLED */
  237. #ifdef HAL_HRTIM_MODULE_ENABLED
  238.   #include "stm32h7xx_hal_hrtim.h"
  239. #endif /* HAL_HRTIM_MODULE_ENABLED */
  240. #ifdef HAL_HSEM_MODULE_ENABLED
  241.   #include "stm32h7xx_hal_hsem.h"
  242. #endif /* HAL_HSEM_MODULE_ENABLED */
  243. #ifdef HAL_SRAM_MODULE_ENABLED
  244.   #include "stm32h7xx_hal_sram.h"
  245. #endif /* HAL_SRAM_MODULE_ENABLED */
  246. #ifdef HAL_NOR_MODULE_ENABLED
  247.   #include "stm32h7xx_hal_nor.h"
  248. #endif /* HAL_NOR_MODULE_ENABLED */
  249. #ifdef HAL_NAND_MODULE_ENABLED
  250.   #include "stm32h7xx_hal_nand.h"
  251. #endif /* HAL_NAND_MODULE_ENABLED */
  252.
  253. #ifdef HAL_I2C_MODULE_ENABLED
  254. #include "stm32h7xx_hal_i2c.h"
  255. #endif /* HAL_I2C_MODULE_ENABLED */
  256. #ifdef HAL_I2S_MODULE_ENABLED
  257. #include "stm32h7xx_hal_i2s.h"
  258. #endif /* HAL_I2S_MODULE_ENABLED */
  259. #ifdef HAL_IWDG_MODULE_ENABLED
  260. #include "stm32h7xx_hal_iwdg.h"
  261. #endif /* HAL_IWDG_MODULE_ENABLED */
  262. #ifdef HAL_JPEG_MODULE_ENABLED
  263. #include "stm32h7xx_hal_jpeg.h"
  264. #endif /* HAL_JPEG_MODULE_ENABLED */
  265. #ifdef HAL_MDIOS_MODULE_ENABLED
  266. #include "stm32h7xx_hal_mdios.h"
  267. #endif /* HAL_MDIOS_MODULE_ENABLED */
  268. #ifdef HAL_MDMA_MODULE_ENABLED
  269. #include "stm32h7xx_hal_mdma.h"
  270. #endif /* HAL_MDMA_MODULE_ENABLED */
  271. #ifdef HAL_MMC_MODULE_ENABLED
  272. #include "stm32h7xx_hal_mmc.h"
  273. #endif /* HAL_MMC_MODULE_ENABLED */
  274.
  275. #ifdef HAL_LPTIM_MODULE_ENABLED
  276. #include "stm32h7xx_hal_lptim.h"
  277. #endif /* HAL_LPTIM_MODULE_ENABLED */
  278. #ifdef HAL_LTDC_MODULE_ENABLED
  279. #include "stm32h7xx_hal_ltdc.h"
  280. #endif /* HAL_LTDC_MODULE_ENABLED */
  281. #ifdef HAL_OPAMP_MODULE_ENABLED
  282. #include "stm32h7xx_hal_opamp.h"
  283. #endif /* HAL_OPAMP_MODULE_ENABLED */
  284.
  285. #ifdef HAL_PWR_MODULE_ENABLED
  286. #include "stm32h7xx_hal_pwr.h"
  287. #endif /* HAL_PWR_MODULE_ENABLED */
  288. #ifdef HAL_QSPI_MODULE_ENABLED
  289. #include "stm32h7xx_hal_qspi.h"
  290. #endif /* HAL_QSPI_MODULE_ENABLED */
  291.
  292. #ifdef HAL_RNG_MODULE_ENABLED
  293. #include "stm32h7xx_hal_rng.h"
  294. #endif /* HAL_RNG_MODULE_ENABLED */
  295. #ifdef HAL_RTC_MODULE_ENABLED
  296. #include "stm32h7xx_hal_rtc.h"
  297. #endif /* HAL_RTC_MODULE_ENABLED */
  298. #ifdef HAL_SAI_MODULE_ENABLED
  299. #include "stm32h7xx_hal_sai.h"
  300. #endif /* HAL_SAI_MODULE_ENABLED */
  301. #ifdef HAL_SD_MODULE_ENABLED
  302. #include "stm32h7xx_hal_sd.h"
  303. #endif /* HAL_SD_MODULE_ENABLED */
  304. #ifdef HAL_SDRAM_MODULE_ENABLED
  305. #include "stm32h7xx_hal_sdram.h"
  306. #endif /* HAL_SDRAM_MODULE_ENABLED */
  307.
  308. #ifdef HAL_SPI_MODULE_ENABLED
  309. #include "stm32h7xx_hal_spi.h"
  310. #endif /* HAL_SPI_MODULE_ENABLED */
  311. #ifdef HAL_SPDIFRX_MODULE_ENABLED
  312. #include "stm32h7xx_hal_spdifrx.h"
  313. #endif /* HAL_SPDIFRX_MODULE_ENABLED */
  314. #ifdef HAL_SWPMI_MODULE_ENABLED
  315. #include "stm32h7xx_hal_swpmi.h"
  316. #endif /* HAL_SWPMI_MODULE_ENABLED */
  317. #ifdef HAL_TIM_MODULE_ENABLED
  318. #include "stm32h7xx_hal_tim.h"
  319. #endif /* HAL_TIM_MODULE_ENABLED */
  320. #ifdef HAL_UART_MODULE_ENABLED
  321. #include "stm32h7xx_hal_uart.h"
  322. #endif /* HAL_UART_MODULE_ENABLED */
  323. #ifdef HAL_USART_MODULE_ENABLED
  324. #include "stm32h7xx_hal_usart.h"
  325. #endif /* HAL_USART_MODULE_ENABLED */
  326. #ifdef HAL_IRDA_MODULE_ENABLED
  327. #include "stm32h7xx_hal_irda.h"
  328. #endif /* HAL_IRDA_MODULE_ENABLED */
  329. #ifdef HAL_SMARTCARD_MODULE_ENABLED
  330. #include "stm32h7xx_hal_smartcard.h"
  331. #endif /* HAL_SMARTCARD_MODULE_ENABLED */
  332. #ifdef HAL_SMBUS_MODULE_ENABLED
  333. #include "stm32h7xx_hal_smbus.h"
  334. #endif /* HAL_SMBUS_MODULE_ENABLED */
  335. #ifdef HAL_WWDG_MODULE_ENABLED
  336. #include "stm32h7xx_hal_wwdg.h"
  337. #endif /* HAL_WWDG_MODULE_ENABLED */
  338.
  339. #ifdef HAL_PCD_MODULE_ENABLED
  340. #include "stm32h7xx_hal_pcd.h"
  341. #endif /* HAL_PCD_MODULE_ENABLED */
  342. #ifdef HAL_HCD_MODULE_ENABLED
  343. #include "stm32h7xx_hal_hcd.h"
  344. #endif /* HAL_HCD_MODULE_ENABLED */
  345.
  346. /* Exported macro ------------------------------------------------------------*/
  347. #ifdef  USE_FULL_ASSERT
  348. /**
  349.   * @brief  The assert_param macro is used for function's parameters check.
  350.   * @param  expr: If expr is false, it calls assert_failed function
  351.   *         which reports the name of the source file and the source
  352.   *         line number of the call that failed.
  353.   *         If expr is true, it returns no value.
  354.   * @retval None
  355.   */
  356.   #define assert_param(expr) ((expr) ? (void)0 : assert_failed((uint8_t *)__FILE__, __LINE__))
  357. /* Exported functions ------------------------------------------------------- */
  358.   void assert_failed(uint8_t* file, uint32_t line);
  359. #else
  360.   #define assert_param(expr) ((void)0)
  361. #endif /* USE_FULL_ASSERT */
  362. #ifdef __cplusplus
  363. }
  364. #endif
  365. #endif /* __STM32H7xx_HAL_CONF_H */
  366. /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
GMT+8, 2024-5-19 05:49 , Processed in 0.152779 second(s), 28 queries .
