楼主 |
发表于 2018-8-16 04:18:07
显示全部楼层
这是我的sdram初始化过程
/* SDRAM device configuration */
hsdram1.Instance = FMC_SDRAM_DEVICE;
/* FMC Configuration -------------------------------------------------------*/
/* FMC SDRAM Bank configuration */
/* Timing configuration for 72 Mhz of SD clock frequency (144Mhz/2) */
/* TMRD: 2 Clock cycles */
SdramTiming.LoadToActiveDelay = 2;
/* TXSR: min=70ns (7x13.9ns) */
SdramTiming.ExitSelfRefreshDelay = 7;
/* TRAS: min=37ns (4x13.9ns) max=120k (ns) */
SdramTiming.SelfRefreshTime = 4;
/* TRC: min=70 (7x13.9ns) */
SdramTiming.RowCycleDelay = 7;
/* TWR: min=1+ 7ns (1+1x13.9ns) */
SdramTiming.WriteRecoveryTime = 2;
/* TRP: 20ns => 2x13.9ns*/
SdramTiming.RPDelay = 2;
/* TRCD: 20ns => 2x13.9ns */
SdramTiming.RCDDelay = 2;
/* FMC SDRAM control configuration */
hsdram1.Init.SDBank = FMC_SDRAM_BANK1;
/* Row addressing: [8:0] */
hsdram1.Init.ColumnBitsNumber = FMC_SDRAM_COLUMN_BITS_NUM_9;
/* Column addressing: [12:0] */
hsdram1.Init.RowBitsNumber = FMC_SDRAM_ROW_BITS_NUM_13;
hsdram1.Init.MemoryDataWidth = FMC_SDRAM_MEM_BUS_WIDTH_16;
hsdram1.Init.InternalBankNumber = FMC_SDRAM_INTERN_BANKS_NUM_4;
hsdram1.Init.CASLatency = FMC_SDRAM_CAS_LATENCY_2;
hsdram1.Init.WriteProtection = FMC_SDRAM_WRITE_PROTECTION_DISABLE;
hsdram1.Init.SDClockPeriod = FMC_SDRAM_CLOCK_PERIOD_2;
hsdram1.Init.ReadBurst = FMC_SDRAM_RBURST_DISABLE;
hsdram1.Init.ReadPipeDelay = FMC_SDRAM_RPIPE_DELAY_1;
/* SDRAM controller initialization */
if(HAL_SDRAM_Init(&hsdram1, &SdramTiming) != HAL_OK)
_Error_Handler(__FILE__, __LINE__);
/* SDRAM initialization sequence */
BSP_SDRAM_Initialization_sequence(570);
void BSP_SDRAM_Initialization_sequence(uint32_t RefreshCount)
__IO uint32_t tmpmrd =0,timeout;
FMC_SDRAM_CommandTypeDef Command;
uint16_t i;
/* Step 1: Configure a clock configuration enable command */
Command.CommandMode = FMC_SDRAM_CMD_CLK_ENABLE;
Command.CommandTarget = FMC_SDRAM_CMD_TARGET_BANK1;
Command.AutoRefreshNumber = 1;
Command.ModeRegisterDefinition = 0;
/* Send the command */
HAL_SDRAM_SendCommand(&hsdram1, &Command, SDRAM_TIMEOUT);
/* Step 2: Insert 100 us minimum delay */
/* Inserted delay is equal to 1 ms due to systick time base unit (ms) */
HAL_Delay(100);
/* Step 3: Configure a PALL (precharge all) command */
Command.CommandMode = FMC_SDRAM_CMD_PALL;
timeout = SDRAM_TIMEOUT;
HAL_Delay(100);
/* Step 4: Configure an Auto Refresh command */
Command.CommandMode = FMC_SDRAM_CMD_AUTOREFRESH_MODE;
Command.AutoRefreshNumber = 8;
HAL_Delay(100);
/* Step 5: Program the external memory mode register */
tmpmrd = (uint32_t)SDRAM_MODEREG_BURST_LENGTH_2 |
SDRAM_MODEREG_BURST_TYPE_SEQUENTIAL |
SDRAM_MODEREG_CAS_LATENCY_2 |
SDRAM_MODEREG_OPERATING_MODE_STANDARD |
SDRAM_MODEREG_WRITEBURST_MODE_SINGLE;
Command.CommandMode = FMC_SDRAM_CMD_LOAD_MODE;
Command.ModeRegisterDefinition = tmpmrd;
HAL_Delay(100);
Command.CommandMode = FMC_SDRAM_CMD_NORMAL_MODE;
HAL_Delay(100);
/* Step 6: Set the refresh rate counter */
/* Set the device refresh rate */
HAL_SDRAM_ProgramRefreshRate(&hsdram1, RefreshCount);
