查看: 11950|回复: 31
[Cache] STM32H7使用函数SCB_InvalidateDCache_by_Addr,SCB_CleanDCache_by_Addr等函数注意事项
发表于 2018-11-3 02:08:00 | 显示全部楼层 |阅读模式
特别注意下面这三个函数的形参addr和dsize:
addr : 操作的地址一定要是32字节对齐的。
dsize :一定要是32字节的整数倍
  1. /**
  2.   \brief   D-Cache Invalidate by address
  3.   \details Invalidates D-Cache for the given address
  4.   \param[in]   addr    address (aligned to 32-byte boundary)
  5.   \param[in]   dsize   size of memory block (in number of bytes)
  6. */
  7. __STATIC_INLINE void SCB_InvalidateDCache_by_Addr (uint32_t *addr, int32_t dsize)
  8. {
  9.   #if defined (__DCACHE_PRESENT) && (__DCACHE_PRESENT == 1U)
  10.      int32_t op_size = dsize;
  11.     uint32_t op_addr = (uint32_t)addr;
  12.      int32_t linesize = 32;                /* in Cortex-M7 size of cache line is fixed to 8 words (32 bytes) */
  13.     __DSB();
  14.     while (op_size > 0) {
  15.       SCB->DCIMVAC = op_addr;
  16.       op_addr += (uint32_t)linesize;
  17.       op_size -=           linesize;
  18.     }
  19.     __DSB();
  20.     __ISB();
  21.   #endif
  22. }
  23. /**
  24.   \brief   D-Cache Clean by address
  25.   \details Cleans D-Cache for the given address
  26.   \param[in]   addr    address (aligned to 32-byte boundary)
  27.   \param[in]   dsize   size of memory block (in number of bytes)
  28. */
  29. __STATIC_INLINE void SCB_CleanDCache_by_Addr (uint32_t *addr, int32_t dsize)
  30. {
  31.   #if defined (__DCACHE_PRESENT) && (__DCACHE_PRESENT == 1U)
  32.      int32_t op_size = dsize;
  33.     uint32_t op_addr = (uint32_t) addr;
  34.      int32_t linesize = 32;                /* in Cortex-M7 size of cache line is fixed to 8 words (32 bytes) */
  35.     __DSB();
  36.     while (op_size > 0) {
  37.       SCB->DCCMVAC = op_addr;
  38.       op_addr += (uint32_t)linesize;
  39.       op_size -=           linesize;
  40.     }
  41.     __DSB();
  42.     __ISB();
  43.   #endif
  44. }
  45. /**
  46.   \brief   D-Cache Clean and Invalidate by address
  47.   \details Cleans and invalidates D_Cache for the given address
  48.   \param[in]   addr    address (aligned to 32-byte boundary)
  49.   \param[in]   dsize   size of memory block (in number of bytes)
  50. */
  51. __STATIC_INLINE void SCB_CleanInvalidateDCache_by_Addr (uint32_t *addr, int32_t dsize)
  52. {
  53.   #if defined (__DCACHE_PRESENT) && (__DCACHE_PRESENT == 1U)
  54.      int32_t op_size = dsize;
  55.     uint32_t op_addr = (uint32_t) addr;
  56.      int32_t linesize = 32;                /* in Cortex-M7 size of cache line is fixed to 8 words (32 bytes) */
  57.     __DSB();
  58.     while (op_size > 0) {
  59.       SCB->DCCIMVAC = op_addr;
  60.       op_addr += (uint32_t)linesize;
  61.       op_size -=           linesize;
  62.     }
  63.     __DSB();
  64.     __ISB();
  65.   #endif
  66. }
参与人数 1金币 +20 收起 理由
yunqi + 20 赞一个!
发表于 2018-11-3 09:45:00 | 显示全部楼层
dsize :一定要是32字节的整数倍
这条要求,貌似从来没有注意过,现在是不管什么大小都往里面填
发表于 2018-11-3 09:52:50 | 显示全部楼层
文档里写了cache是32字节对齐的,之前确实有时候用有时候没用,偶尔就会出点问题
发表于 2018-11-3 11:10:32 | 显示全部楼层
研究越来越透彻了啊,之前只主要地址是 32对齐,数据大小还没有怎么注意过啊,看来以后也得多多注意才行
 楼主| 发表于 2018-11-10 01:27:00 | 显示全部楼层
这个问题要特别引起注意。
发表于 2020-9-3 14:32:19 | 显示全部楼层
Solution example 3: Use Cache maintenance functions
Transmitting data:
  1. #define TX_LENGTH  (16)
  2. uint8_t tx_buffer[TX_LENGTH];
  3. /* Write data */
  4. tx_buffer[0] = 0x0;
  5. tx_buffer[1] = 0x1;
  6. /* Clean D-cache */
  7. /* Make sure the address is 32-byte aligned and add 32-bytes to length, in case it overlaps cacheline */
  8. SCB_CleanDCache_by_Addr((uint32_t*)(((uint32_t)tx_buffer) & ~(uint32_t)0x1F), TX_LENGTH+32);
  9. /* Start DMA transfer */
  10. HAL_UART_Transmit_DMA(&huart1, tx_buffer, TX_LENGTH);
Receiving data:
  1. #define RX_LENGTH  (16)
  2. uint8_t rx_buffer[RX_LENGTH];
  3. /* Invalidate D-cache before reception */
  4. /* Make sure the address is 32-byte aligned and add 32-bytes to length, in case it overlaps cacheline */
  5. SCB_InvalidateDCache_by_Addr((uint32_t*)(((uint32_t)rx_buffer) & ~(uint32_t)0x1F), RX_LENGTH+32);
  6. /* Start DMA transfer */
  7. HAL_UART_Receive_DMA(&huart1, rx_buffer, RX_LENGTH);
  8. /* No access to rx_buffer should be made before DMA transfer is completed */
Please note that in case of reception there can be problem if rx_buffer is not aligned to the size of cache-line (32-bytes), because during the invalidate operation another data sharing the same cache-line(s)  with rx_buffer can be lost.
参考文献:
https://community.st.com/s/article/FAQ-DMA-is-not-working-on-STM32H7-devices
 楼主| 发表于 2020-9-3 15:26:27 | 显示全部楼层
la9998372 发表于 2020-9-3 14:32
Solution example 3: Use Cache maintenance functionsTransmitting data:Receiving datalease note that ...
除了你帖的这个,还要注意H7的串口DMA有个硬件bug,务必要使用最新的HAL库
  1.     /* Work around for Errata 2.22: UART/USART- DMA transfer lock: DMA stream could be
  2.                                     lock when transfering data to/from USART/UART */
  3. #if (STM32H7_DEV_ID == 0x450UL)
  4.     if((DBGMCU->IDCODE & 0xFFFF0000U) >= 0x20000000U)
  5.     {
  6. #endif /* STM32H7_DEV_ID == 0x450UL */
  7.       if(IS_DMA_UART_USART_REQUEST(hdma->Init.Request) != 0U)
  8.       {
  9.         registerValue |= DMA_SxCR_TRBUFF;
  10.       }
  11. #if (STM32H7_DEV_ID == 0x450UL)
  12.     }
  13. #endif /* STM32H7_DEV_ID == 0x450UL */
 楼主| 发表于 2020-9-3 15:28:54 | 显示全部楼层
另外他这个接收数据回复有问题,应该是DMA接收后做无效化而不是DMA接收前作无效化。他们这个文章这部分有问题,应该给他们提出下。
发表于 2020-9-6 21:34:02 | 显示全部楼层
eric2013 发表于 2020-9-3 15:28
另外他这个接收数据回复有问题,应该是DMA接收后做无效化而不是DMA接收前作无效化。他们这个文章这部分有 ...
是不是就是说,DMA接收完一帧数据之后,需要进行数据解析之前,进行Cache无效话处理?
 楼主| 发表于 2020-9-7 03:25:19 | 显示全部楼层
对,一般是这样的。
发表于 2021-12-14 15:53:06 | 显示全部楼层
E:\123.pngV5.1.1版core_cm7.h文件好像已经对dsize做了字节对齐操作
 楼主| 发表于 2021-12-14 16:19:23 | 显示全部楼层
修改了好,更规范了。
发表于 2021-12-16 11:39:04 | 显示全部楼层
eric2013 发表于 2021-12-14 16:19
修改了好,更规范了。
搞不清楚为啥既然采用do..while形式对dsize做了32字节对齐,但是op_addr地址32字节对齐却注释掉了?
发表于 2021-12-16 11:54:16 | 显示全部楼层
修改了好,更规范了。
这句话是不是说SCB->DCCIMVAC寄存器仅31-5位是有效的,本身已经强制32位对齐了,那以后是不是可以直接传入地址和数据了,不需要再对地址和数据进行32位对齐了,我在编程手册上也没找到对DCCIMVAC寄存器的详细描述
发表于 2021-12-21 13:17:22 | 显示全部楼层
谁知道 这个 SCB_InvalidateDCache_by_Addr  和 SCB_CleanInvalidateDCache_by_Addr    这个两个的区别是什么
 楼主| 发表于 2021-12-22 09:17:51 | 显示全部楼层
zhoudn 发表于 2021-12-16 11:54
这句话是不是说SCB->DCCIMVAC寄存器仅31-5位是有效的,本身已经强制32位对齐了,那以后是不是可以直接传 ...
他这个的设置来的,还不够全面,最好按照楼主位的再设置下。
 楼主| 发表于 2021-12-22 09:20:38 | 显示全部楼层
dghwjh 发表于 2021-12-21 13:17
谁知道 这个 SCB_InvalidateDCache_by_Addr  和 SCB_CleanInvalidateDCache_by_Addr    这个两个的区别是什 ...
SCB_CleanInvalidateDCache_by_Add比SCB_InvalidateDCache_by_Addr多了Clean操作,Clean操作的含义是将Cache里面的新内容刷到实际存储器中。
发表于 2024-1-30 18:46:08 | 显示全部楼层
如果dsize没有32字节对齐,是不是会出现将变量前面或者后面的数据也刷掉,改变前后变量的值
发表于 2024-1-30 18:46:53 | 显示全部楼层
addr:我看到STM32代码好像也是有自动向前对齐这个操作,哎。。。。
发表于 2024-1-30 18:54:07 | 显示全部楼层
eric2013 发表于 2018-11-10 01:27
这个问题要特别引起注意。
我们HAL库版本不一样?实际使用发现这玩意有bug,感谢向前偏移会导致数据刷新错误
 楼主| 发表于 2024-1-31 00:43:03 | 显示全部楼层
如果不能保证整数倍和对齐,不要使用这个函数控制。
发表于 2024-1-31 09:39:17 | 显示全部楼层
求教一下哪使用什么函数比较好
 楼主| 发表于 2024-1-31 10:23:34 | 显示全部楼层
嵌入式菜鸟^_^ 发表于 2024-1-31 09:39
求教一下哪使用什么函数比较好
函数SCB_InvalidateDCache或者SCB_CleanInvalidateDCache
发表于 2024-7-12 16:29:57 来自手机 | 显示全部楼层
帮我删了吧,怎么今天下午回复的好多都是乱码,还跳转成手机UA
 楼主| 发表于 2024-7-13 08:38:54 | 显示全部楼层
好的,另一个帖子里面的乱码已经帮你处理了。
发表于 2024-12-13 19:20:02 | 显示全部楼层
op_addr应该还是要手动对齐到32字节。
考虑一种情况,op_addr没有对齐到32字节,但是dsize对齐到32字节了。
那么cache操作时,地址自动往前对齐(忽略bit0~bit4),会导致清cache的数据dsize尾部残留数据没有被无效化,那么这部分数据将是错误的。
发表于 2025-4-3 17:22:06 | 显示全部楼层
没开cache,LWIP中执行到这个,SCB_InvalidateDCache_by_Addr,会有概率进硬件错误中断。
 楼主| 发表于 2025-4-4 11:07:51 | 显示全部楼层
调用SCB_CleanInvalidateDCache
发表于 2025-5-9 02:40:22 | 显示全部楼层
测试了一下,发现先Invalidate再开启DMA接收可以正常使用。我认为Invalidate用于声明Cache中的数据已被外部更新,至下次CPU读数据时,Cache才将SRAM的数据重新导入;而非将Cache内已有数据,立即自SRAM更新。楼主看看有没有道理?
 楼主| 发表于 2025-5-10 10:09:21 | 显示全部楼层
Penguins 发表于 2025-5-9 02:40
测试了一下,发现先Invalidate再开启DMA接收可以正常使用。我认为Invalidate用于声明Cache中的数据已被外 ...
理解有误,执行无效化就是立即将Cache中的数据同步为和SRAM中数据一致。
发表于 2025-5-10 21:55:19 | 显示全部楼层
那如果对不在cache内的地址块调用SCB_InvalidateDCache_by_Addr,会立即加载至cache还是等待下次cpu需要读该地址块时加载至cache?没找到相关的官方文档
 楼主| 发表于 2025-5-11 09:46:47 | 显示全部楼层
Penguins 发表于 2025-5-10 21:55
那如果对不在cache内的地址块调用SCB_InvalidateDCache_by_Addr,会立即加载至cache还是等待下次cpu需要 ...
是立即加载。
GMT+8, 2025-6-10 12:04 , Processed in 0.488993 second(s), 28 queries .
