查看: 2549|回复: 7
[emWin] emWin5.50迟迟不升级,距离上个版本已经半年多了
发表于 2019-1-29 02:06:46 | 显示全部楼层 |阅读模式
https://www.segger.com/products/user-interface/emwin/
Version 5.48k
  • Core:
    • Under certain circumstances GUI_EnableAlpha() with drawing text does not work right and leads into using wrong colors. Problem solved.
Version 5.48j
  • Core:
    • Arabic text: Under certain circumstances a wrong representation form is shown. Problem solved.
Version 5.48i
  • Widget:
    • Under certain circumstances a set user draw function does not work properly. Fixed.
Version 5.48h
  • Widget:
    • GRAPH widget does not take width of scrollbar into account. Fixed.
Version 5.48g
  • Widget/Window Manager:
    • Issues fixed when defining WM_SUPPORT_TRANSPARENCY to 0.
    • EDIT widget has a timer for blinking cursor only when it is focused.
Version 5.48f
  • Core:
    • Unicode characters from a range above 0xFFFF where treated as non existing characters (e.g. Emojis). Now they will get processed but still can not be displayed.
Version 5.48d
  • Bitmap Converter:
    • 16 bit color formats are not saved correctly. Problem solved.
Version 5.48c
  • Simulation:
    • Copy to clipboard does not work properly if using 16bpp color conversion. Problem solved.
Version 5.48b
  • Core:
    • GUI_DispFloatFix() displays numbers which exceed the given range. Problem solved.
  • Memory Devices:
    • Blurring takes too long. Problem solved by replacing the blurring function by a much faster version.
Version 5.48a
  • Antialiasing:
    • GUI_AA_DrawCircle() is not displayed properly with a pen size set. Problem solved.
  • Display driver:
    • Renamed internal function, due to conflicts.
 楼主| 发表于 2019-1-29 02:07:51 | 显示全部楼层
发表于 2019-1-29 09:21:58 | 显示全部楼层
学不完的软件知识,改不完的BUG。
定位不准确,有可能会饿死。
发表于 2019-1-29 09:23:09 | 显示全部楼层
有些决定确实无奈
发表于 2019-1-29 22:42:06 | 显示全部楼层
难道要憋大招了? 华硕那个guibuilder真的太难用了。赶不上20年前的visual5.0
发表于 2019-1-29 23:06:08 | 显示全部楼层
5.48a b c d e f g h i j k,看每一个小版本的升级记录,都是解决一个小BUG,根本没有大动作,5.48这个版本目前应该是很稳定了
发表于 2019-1-31 09:00:41 | 显示全部楼层
是不是以后重点发展TouchGFX了?不然干嘛收购TouchGFX
发表于 2019-1-31 09:04:31 来自手机 | 显示全部楼层
这是SEGGER
GMT+8, 2025-5-18 00:45 , Processed in 0.260260 second(s), 27 queries .
