查看: 2629|回复: 4
[emWin] emWin最新版V5.50一直不发布了,准备V7直接上最新版
发表于 2019-3-14 02:20:50 | 显示全部楼层 |阅读模式
小更新有点多
Version 5.48q
  • Display driver:
    • GUIDRV_SLinEPD: Switching between partial- and full update does not work right. Problem solved.
Version 5.48p
  • Core:
    • Wrapping does not work with Shift-JIS. Problem solved.
Version 5.48o
  • Common:
    • Compiler warnings eliminated.
Version 5.48k
  • Core:
    • Under certain circumstances GUI_EnableAlpha() with drawing text does not work right and leads into using wrong colors. Problem solved.
Version 5.48j
  • Core:
    • Arabic text: Under certain circumstances a wrong representation form is shown. Problem solved.
Version 5.48i
  • Widget:
    • Under certain circumstances a set user draw function does not work properly. Fixed.
Version 5.48h
  • Widget:
    • GRAPH widget does not take width of scrollbar into account. Fixed.
Version 5.48g
  • Widget/Window Manager:
    • Issues fixed when defining WM_SUPPORT_TRANSPARENCY to 0.
    • EDIT widget has a timer for blinking cursor only when it is focused.
Version 5.48f
  • Core:
    • Unicode characters from a range above 0xFFFF where treated as non existing characters (e.g. Emojis). Now they will get processed but still can not be displayed.
Version 5.48d
  • Bitmap Converter:
    • 16 bit color formats are not saved correctly. Problem solved.
Version 5.48c
  • Simulation:
    • Copy to clipboard does not work properly if using 16bpp color conversion. Problem solved.
Version 5.48b
  • Core:
    • GUI_DispFloatFix() displays numbers which exceed the given range. Problem solved.
  • Memory Devices:
    • Blurring takes too long. Problem solved by replacing the blurring function by a much faster version.
Version 5.48a
  • Antialiasing:
    • GUI_AA_DrawCircle() is not displayed properly with a pen size set. Problem solved.
  • Display driver:
    • Renamed internal function, due to conflicts.
Version 5.48
  • Core:
    • Animation:
      - Doesn't behave correctly when GUI_Exit() is called. Fixed.
    • PNG:
      - If GUI_USE_ARGB is enabled, a PNG without transparency wasn't draw. Fixed.
    • BMP:
      - BMPs with a palette are not displayed properly. Fixed.
  • Widgets:
    • TREEVIEW:
      - Widget does not send WM_NOTIFICATION_SEL_CHANGED if selection changed by mouse click. Fixed.
    • SWIPELIST:
      - SWIPELIST_GetBkColor and SWIPELIST_SetBkColor didn't unlocked emWin. Fixed.
    • TEXT:
      - TEXT_GetNumLines() returns wrong number of lines due to wrong font set. Now uses the the font set for the TEXT widget.
发表于 2019-3-14 11:44:48 | 显示全部楼层
有MCU使用的库文件吗?
发表于 2019-3-14 12:03:38 | 显示全部楼层
爱恋之燕 发表于 2019-3-14 11:44
有MCU使用的库文件吗?
估计寄希望于MDK了,MDK跟SEGGER的同步性较强。
 楼主| 发表于 2019-3-14 14:25:10 | 显示全部楼层
是的
 楼主| 发表于 2019-3-14 14:25:53 | 显示全部楼层
有MCU使用的库文件吗?
下个月MDK5.27正式版发布,希望是最新版本的了,当前MDK5.26里面的是5.46
GMT+8, 2025-5-17 22:32 , Processed in 0.249132 second(s), 24 queries .
