查看: 1865|回复: 5
STM32F469驅動ili9806E
发表于 2019-4-19 16:24:43 | 显示全部楼层 |阅读模式
目前使用STM32F469 MIPI接口驅動ili9806E,發現只能直屏顯示,不能橫頻顯示
我的暫存器設定值如下
{REGFLAG_DELAY,150,{0x00}},
{0xFF,5,{0xFF,0x98,0x06,0x04,0x01}},
{0x08,1,{0x10}},
{0x20,1,{0x00}},
{0x21,1,{0x01}},
{0x30,1,{0x02}},
{0x31,1,{0x02}},
{0x60,1,{0x07}},
{0x61,1,{0x06}},
{0x62,1,{0x06}},
{0x63,1,{0x04}},
{0x40,1,{0x18}},
{0x41,1,{0x33}},
{0x42,1,{0x11}},//0x12
{0x43,1,{0x09}},//0x89
{0x44,1,{0x0C}},//0x86
{0x46,1,{0x55}},
{0x47,1,{0x55}},
{0x45,1,{0x14}},
{0x50,1,{0x50}},
{0x51,1,{0x50}},
{0x52,1,{0x00}},
{0x53,1,{0x38}},
{0xA0,1,{0x00}},// p gama
{0xA1,1,{0x09}},
{0xA2,1,{0x0C}},
{0xA3,1,{0x0F}},
{0xA4,1,{0x06}},
{0xA5,1,{0x09}},
{0xA6,1,{0x07}},
{0xA7,1,{0x16}},
{0xA8,1,{0x06}},
{0xA9,1,{0x09}},
{0xAA,1,{0x11}},
{0xAB,1,{0x06}},
{0xAC,1,{0x0E}},
{0xAD,1,{0x19}},
{0xAE,1,{0x0E}},
{0xAF,1,{0x00}},
{0xC0,1,{0x00}},//n gama
{0xC1,1,{0x09}},
{0xC2,1,{0x0C}},
{0xC3,1,{0x0F}},
{0xC4,1,{0x06}},
{0xC5,1,{0x09}},
{0xC6,1,{0x07}},
{0xC7,1,{0x16}},
{0xC8,1,{0x06}},
{0xC9,1,{0x09}},
{0xCA,1,{0x11}},
{0xCB,1,{0x06}},
{0xCC,1,{0x0E}},
{0xCD,1,{0x19}},
{0xCE,1,{0x0E}},
{0xCF,1,{0x00}},
{0xFF,5,{0xFF,0x98,0x06,0x04,0x06}},
{0x00,1,{0xA0}},
{0x01,1,{0x05}},
{0x02,1,{0x00}},
{0x03,1,{0x00}},
{0x04,1,{0x01}},
{0x05,1,{0x01}},
{0x06,1,{0x88}},
{0x07,1,{0x04}},
{0x08,1,{0x01}},
{0x09,1,{0x90}},
{0x0A,1,{0x04}},
{0x0B,1,{0x01}},
{0x0C,1,{0x01}},
{0x0D,1,{0x01}},
{0x0E,1,{0x00}},
{0x0F,1,{0x00}},
{0x10,1,{0x55}},
{0x11,1,{0x50}},
{0x12,1,{0x01}},
{0x13,1,{0x85}},
{0x14,1,{0x85}},
{0x15,1,{0xC0}},
{0x16,1,{0x0B}},
{0x17,1,{0x00}},
{0x18,1,{0x00}},
{0x19,1,{0x00}},
{0x1A,1,{0x00}},
{0x1B,1,{0x00}},
{0x1C,1,{0x00}},
{0x1D,1,{0x00}},
{0x20,1,{0x01}},
{0x21,1,{0x23}},
{0x22,1,{0x45}},
{0x23,1,{0x67}},
{0x24,1,{0x01}},
{0x25,1,{0x23}},
{0x26,1,{0x45}},
{0x27,1,{0x67}},
{0x30,1,{0x02}},
{0x31,1,{0x22}},
{0x32,1,{0x11}},
{0x33,1,{0xAA}},
{0x34,1,{0xBB}},
{0x35,1,{0x66}},
{0x36,1,{0x00}},
{0x37,1,{0x22}},
{0x38,1,{0x22}},
{0x39,1,{0x22}},
{0x3A,1,{0x22}},
{0x3B,1,{0x22}},
{0x3C,1,{0x22}},
{0x3D,1,{0x22}},
{0x3E,1,{0x22}},
{0x3F,1,{0x22}},
{0x40,1,{0x22}},
{0x52,1,{0x12}},
{0x53,1,{0x12}},
{0xFF,5,{0xFF,0x98,0x06,0x04,0x07}},
{0x17,1,{0x32}},
{0x02,1,{0x17}},
{0x18,1,{0x1D}},
{0xE1,1,{0x79}},
{0xFF,5,{0xFF,0x98,0x06,0x04,0x00}},
{0x3A,1,{0x70}},//0x50
{0x11,0,{}},
{0x29,0,{}},
想請問如何變成橫屏呢
发表于 2019-4-20 10:57:57 | 显示全部楼层
MIPI接口的横竖屏,需要设置显存的横竖显示。
 楼主| 发表于 2019-4-22 08:41:28 | 显示全部楼层
設置顯存的橫豎顯示,如果我設定為854*480時,我將所有pixel ON
會有一區塊沒辦法顯示,如果設定480*854時,可以顯示滿屏
但是我顯示圖片時,卻是直屏的,所以不知如何修改成橫屏顯示
发表于 2019-4-23 00:08:37 | 显示全部楼层
會有一區塊沒辦法顯示,如果設定480*854時, ...
是不是你的API函数没做支持,你的API函数也要做相应的调整。
或者这个显示屏有其它的寄存器可以专门配置这个。
尝试绘制一条854长度的直线是否正常。
发表于 2019-6-19 17:18:49 | 显示全部楼层
這個問題,我也折騰過幾天,後來我請問過工廠,要面板(FW)支持才行,否則就要靠軟體旋轉。
发表于 2019-6-19 19:16:48 | 显示全部楼层
这位兄弟不是大陆这边的吧,这“字”我的瞅半天
GMT+8, 2025-5-14 01:25 , Processed in 0.272874 second(s), 24 queries .
