查看: 2214|回复: 4
函数offsetof,简单实用,求结构体中一个成员在该结构体中的偏移量
发表于 2019-4-22 15:34:20 | 显示全部楼层 |阅读模式
结构体:
  1. /// OS Runtime Information structure
  2. typedef struct {
  3.   const char                   *os_id;  ///< OS Identification
  4.   uint32_t                    version;  ///< OS Version
  5.   struct {                              ///< Kernel Info
  6.     uint8_t                     state;  ///< State
  7.     volatile uint8_t          blocked;  ///< Blocked
  8.     uint8_t                    pendSV;  ///< Pending SV
  9.     uint8_t                  reserved;
  10.     uint32_t                     tick;  ///< Tick counter
  11.   } kernel;
  12.   int32_t                   tick_irqn;  ///< Tick Timer IRQ Number
  13.   struct {                              ///< Thread Info
  14.     struct {                            ///< Thread Run Info
  15.       osRtxThread_t             *curr;  ///< Current running Thread
  16.       osRtxThread_t             *next;  ///< Next Thread to Run
  17.     } run;
  18.     osRtxObject_t               ready;  ///< Ready List Object
  19.     osRtxThread_t               *idle;  ///< Idle Thread
  20.     osRtxThread_t         *delay_list;  ///< Delay List
  21.     osRtxThread_t          *wait_list;  ///< Wait List (no Timeout)
  22.     osRtxThread_t     *terminate_list;  ///< Terminate Thread List
  23.     struct {                            ///< Thread Round Robin Info
  24.       osRtxThread_t           *thread;  ///< Round Robin Thread
  25.       uint32_t                   tick;  ///< Round Robin Time Tick
  26.       uint32_t                timeout;  ///< Round Robin Timeout
  27.     } robin;
  28.   } thread;
  29.   struct {                              ///< Timer Info
  30.     osRtxTimer_t                *list;  ///< Active Timer List
  31.     osRtxThread_t             *thread;  ///< Timer Thread
  32.     osRtxMessageQueue_t           *mq;  ///< Timer Message Queue
  33.     void                (*tick)(void);  ///< Timer Tick Function
  34.   } timer;
  35.   struct {                              ///< ISR Post Processing Queue
  36.     uint16_t                      max;  ///< Maximum Items
  37.     uint16_t                      cnt;  ///< Item Count
  38.     uint16_t                       in;  ///< Incoming Item Index
  39.     uint16_t                      out;  ///< Outgoing Item Index
  40.     void                       **data;  ///< Queue Data
  41.   } isr_queue;
  42.   struct {                                      ///< ISR Post Processing functions
  43.     void          (*thread)(osRtxThread_t*);    ///< Thread Post Processing function
  44.     void (*event_flags)(osRtxEventFlags_t*);    ///< Event Flags Post Processing function
  45.     void    (*semaphore)(osRtxSemaphore_t*);    ///< Semaphore Post Processing function
  46.     void (*memory_pool)(osRtxMemoryPool_t*);    ///< Memory Pool Post Processing function
  47.     void        (*message)(osRtxMessage_t*);    ///< Message Post Processing function
  48.   } post_process;
  49.   struct {                              ///< Memory Pools (Variable Block Size)
  50.     void                       *stack;  ///< Stack Memory
  51.     void                     *mp_data;  ///< Memory Pool Data Memory
  52.     void                     *mq_data;  ///< Message Queue Data Memory
  53.     void                      *common;  ///< Common Memory
  54.   } mem;
  55.   struct {                              ///< Memory Pools (Fixed Block Size)
  56.     osRtxMpInfo_t              *stack;  ///< Stack for Threads
  57.     osRtxMpInfo_t             *thread;  ///< Thread Control Blocks
  58.     osRtxMpInfo_t              *timer;  ///< Timer Control Blocks
  59.     osRtxMpInfo_t        *event_flags;  ///< Event Flags Control Blocks
  60.     osRtxMpInfo_t              *mutex;  ///< Mutex Control Blocks
  61.     osRtxMpInfo_t          *semaphore;  ///< Semaphore Control Blocks
  62.     osRtxMpInfo_t        *memory_pool;  ///< Memory Pool Control Blocks
  63.     osRtxMpInfo_t      *message_queue;  ///< Message Queue Control Blocks
  64.   } mpi;
  65. } osRtxInfo_t;
使用举例:
memset(&osRtxInfo.kernel, 0, sizeof(osRtxInfo) - offsetof(osRtxInfo_t, kernel));
原始定义:
  1. #ifdef __clang__
  2.   #define offsetof(t, d) __builtin_offsetof(t, d)
  3. #else
  4.   /* EDG uses __INTADDR__ to avoid errors when strict */
  5.   #define offsetof(t, memb) ((__CLIBNS size_t)__INTADDR__(&(((t *)0)->memb)))
  6. #endif
发表于 2019-4-22 16:26:09 | 显示全部楼层
将kernel及后面的变量清零,学习了
发表于 2019-4-23 00:01:33 | 显示全部楼层
offestof 和 containof
发表于 2019-4-23 10:40:45 | 显示全部楼层
迄今为止,没使用过这个函数
发表于 2019-6-19 16:13:04 | 显示全部楼层
太深奥了,表示
发表于 2019-12-19 20:07:36
上面的结构体是干嘛的,弄这么大来演示这个offset功能吗
GMT+8, 2024-5-16 07:45 , Processed in 0.163298 second(s), 25 queries .
