楼主 |
发表于 2019-5-3 00:47:35
显示全部楼层
uCOS:
; HANDLE PendSV EXCEPTION
; void OS_CPU_PendSVHandler(void)
; Note(s) : 1) PendSV is used to cause a context switch. This is a recommended method for performing
; context switches with Cortex-M. This is because the Cortex-M auto-saves half of the
; processor context on any exception, and restores same on return from exception. So only
; saving of R4-R11 & R14 is required and fixing up the stack pointers. Using the PendSV exception
; this way means that context saving and restoring is identical whether it is initiated from
; a thread or occurs due to an interrupt or exception.
; 2) Pseudo-code is:
; a) Get the process SP
; b) Save remaining regs r4-r11 & r14 on process stack;
; c) Save the process SP in its TCB, OSTCBCurPtr->OSTCBStkPtr = SP;
; d) Call OSTaskSwHook();
; e) Get current high priority, OSPrioCur = OSPrioHighRdy;
; f) Get current ready thread TCB, OSTCBCurPtr = OSTCBHighRdyPtr;
; g) Get new process SP from TCB, SP = OSTCBHighRdyPtr->OSTCBStkPtr;
; h) Restore R4-R11 and R14 from new process stack;
; i) Perform exception return which will restore remaining context.
; 3) On entry into PendSV handler:
; a) The following have been saved on the process stack (by processor):
; xPSR, PC, LR, R12, R0-R3
; b) Processor mode is switched to Handler mode (from Thread mode)
; c) Stack is Main stack (switched from Process stack)
; d) OSTCBCurPtr points to the OS_TCB of the task to suspend
; OSTCBHighRdyPtr points to the OS_TCB of the task to resume
; 4) Since PendSV is set to lowest priority in the system (by OSStartHighRdy() above), we
; know that it will only be run when no other exception or interrupt is active, and
; therefore safe to assume that context being switched out was using the process stack (PSP).
; 5) Increasing priority using a write to BASEPRI does not take effect immediately.
; (a) IMPLICATION This erratum means that the instruction after an MSR to boost BASEPRI
; might incorrectly be preempted by an insufficient high priority exception.
; (b) WORKAROUND The MSR to boost BASEPRI can be replaced by the following code sequence:
; CPSID i
; MSR to BASEPRI
; DSB
; ISB
; CPSIE i
CPSID I ; Cortex-M7 errata notice. See Note #5
MOV32 R2, OS_KA_BASEPRI_Boundary ; Set BASEPRI priority level required for exception preemption
LDR R1, [R2]
MSR BASEPRI, R1
DSB
ISB
CPSIE I
