查看: 3376|回复: 7
[emWin] STemWin的按钮图片从SD卡读取,显示在按钮的顶层,怎么实现?
发表于 2019-6-28 11:17:44 | 显示全部楼层 |阅读模式
最近做一个界面菜单,要将按钮上绣上App小图标,之前使用流位图实现了,但是按钮多图片多占据较大内存!
现在case WM_PAINT:里面能将图片从SD卡读取出来显示,但是在按钮底层,想问一下如何将图片置顶,置于按钮上层?
发表于 2019-6-28 12:25:11 | 显示全部楼层
按钮自定义回调的WM_PAINT ??
WM_PAINT会频繁的调用的,别在这个里面读取,最好申请动态内存提前搞好,不用时,释放掉比较合理。
代码不规范,亲人两行泪!
 楼主| 发表于 2019-6-28 13:35:35 | 显示全部楼层
#define ID_WINDOW_0 (GUI_ID_USER + 0x00)
#define ID_BUTTON_0 (GUI_ID_USER + 0x05)
#define ID_BUTTON_1 (GUI_ID_USER + 0x06)
  { WINDOW_CreateIndirect, "Window", ID_WINDOW_0, 0, 0, 800, 480, 0, 0x0, 0 },
  { BUTTON_CreateIndirect, "Button", ID_BUTTON_0, 80,  50, 56, 56, 0, 0x0, 0 },
        { BUTTON_CreateIndirect, "Button", ID_BUTTON_1, 80, 100, 56, 56, 0, 0x0, 0 },
FIL picture_bmp_fsrc_temp;
static int BUTTON_DrawSkin(const WIDGET_ITEM_DRAW_INFO *pDrawItemInfo)
    char  s[20];
    GUI_HMEM hMem;
    GUI_HMEM hMem1;
    u32 bw=0;
    char *_acBuffer;
    GUI_BITMAP * bitMap;
    GUI_LOGPALETTE  palette;
    switch(pDrawItemInfo->Cmd)
        case WIDGET_ITEM_DRAW_TEXT:
            BUTTON_GetText(pDrawItemInfo->hWin,s,20);
            hMem=GUI_ALLOC_AllocZero(5*1024);
            _acBuffer=GUI_ALLOC_h2p(hMem);
            hMem1=GUI_ALLOC_AllocZero(5*1024);
            bitMap=GUI_ALLOC_h2p(hMem1);
            f_open(&picture_bmp_fsrc_temp,s,FA_OPEN_EXISTING | FA_READ | FA_OPEN_ALWAYS);
            f_read(&picture_bmp_fsrc_temp,_acBuffer,picture_bmp_fsrc_temp.fsize,&bw);
            GUI_CreateBitmapFromStream(bitMap,&palette,_acBuffer);
            GUI_DrawBitmap(bitMap,0,0);
            f_close(&picture_bmp_fsrc_temp);
            GUI_ALLOC_Free(hMem);
            GUI_ALLOC_Free(hMem1);
        case WIDGET_ITEM_CREATE:
        default:
            return BUTTON_DrawSkinFlex(pDrawItemInfo);
    return 0;
        WM_HWIN hItem;
        WM_HWIN hWin = pMsg->hWin;
  int NCode;
  int Id;
switch (pMsg->MsgId) {
        case WM_PAINT:
                        GUI_SetBkColor(GUI_RED);//ÉèÖõ±Ç°±³¾°É«
                        GUI_SetColor(GUI_RED);
//            GUI_SetFont(&GUI_FontHZ16);
        case WM_INIT_DIALOG:
                        hItem = pMsg->hWin;
//          bmpdisplay_demo();
//                GUI_BMP_DrawEx("0:/PICTURE_bmp/app_110.bmp",0,50,        10);
                  GUI_UC_SetEncodeUTF8();//ÆôÓÃUTF8
      hItem = WM_GetDialogItem(pMsg->hWin, ID_BUTTON_0);
      BUTTON_SetText(hItem,"0:/bmp1/1.dta");
      BUTTON_SetSkin(hItem,BUTTON_DrawSkin);
            hItem = WM_GetDialogItem(pMsg->hWin, ID_BUTTON_1);
      BUTTON_SetText(hItem,"exit");
//      BUTTON_SetSkin(hItem,BUTTON_DrawSkin);
  case WM_NOTIFY_PARENT:
    NCode = pMsg->Data.v;
    switch(Id) {
    case ID_BUTTON_0:
      switch(NCode) {
      case WM_NOTIFICATION_CLICKED:
                                LED1 =~ LED1;
                                BEEP =~ BEEP;
    case ID_BUTTON_1:
      switch(NCode) {
                                GUI_EndDialog(hWin, 0);
                                demo_desktop();
  default:
    WM_DefaultProc(pMsg);
void bmp_play_why(void)
        WM_HWIN hWin;
 楼主| 发表于 2019-6-28 13:37:00 | 显示全部楼层
missfox 发表于 2019-6-28 12:25
按钮自定义回调的WM_PAINT ??
WM_PAINT会频繁的调用的,别在这个里面读取,最好申请动态内存提前搞好,不 ...
实现了,如上:
发表于 2019-6-28 15:03:11 | 显示全部楼层
#define ID_BUTTO ...
强烈建议老铁把读出方式改了,先加载好,再放在回调里面绘制。
代码不规范,亲人两行泪!
 楼主| 发表于 2019-6-28 15:32:45 | 显示全部楼层
内存不够啊,这样先加载会不会影响内存
 楼主| 发表于 2019-6-28 17:09:51 | 显示全部楼层
老铁,这个读出加载好是把它先读出来放SRAM吗?
发表于 2019-6-29 00:49:35 | 显示全部楼层
使用emwin的动态内存
代码不规范,亲人两行泪!
GMT+8, 2025-5-18 07:46 , Processed in 0.834355 second(s), 23 queries .
