查看: 1507|回复: 0
[μCOS-III] Micrium发布的STM32L4R9I的uCOS-II和III程序模板
发表于 2019-7-8 07:33:08 | 显示全部楼层 |阅读模式
Micrium_STM32L4R9I-EVAL_Blinky.zip (5.41 MB, 下载次数: 92)
BLINKY EXAMPLE FOR THE ST STM32L4R9I-EVAL
This example project demonstrates how to create a kernel task which blinks an LED.
MICRIUM PRODUCT VERSIONS
- uC/OS-II  v2.92.16
- uC/OS-III v3.07.03
- uC/CPU    v1.31.04
- uC/LIB    v1.38.03
IDE/COMPILER VERSIONS
- IAR/EWARM      v8.32.1
- TrueSTUDIO/GNU v9.0.0
HARDWARE SETUP
- Connect USB Mini-B cable to ST-LINK port.
WORKSPACE LOCATIONS
- ST/STM32L4R9I-EVAL/Blinky/<OS2|OS3>/IAR/Blinky.eww
- ST/STM32L4R9I-EVAL/Blinky/<OS2|OS3>/TrueSTUDIO/
USAGE INSTRUCTIONS
IAR
- Open the workspace in IAR.
- Press F7 to build the project and Ctrl+D to start the debug session.
- Once the debug session has started, press F5 to run the example.
- The project creates a task which blinks an LED every 1 second.
- Now modify the call to OSTimeDlyHMSM() in StartupTask() to increase or decrease the frequency at which the LED blinks.
- Build and run again to see the change.
TrueSTUDIO
- Import the workspace in TrueSTUDIO and make sure the "Copy projects into workspace" Options box is UNCHECKED.
- Press 'CTRL + B' to build the project and create a Debug session by selecting the Blinky workspace and pressing F11.
- Once the debug session has started, press F8 to run/resume the example.
Please feel free to post questions or comments related to this example project at Micrium's forum page:
https://www.micrium.com/forums/topic/st-stm32l4r9i-eval-blinky/
GMT+8, 2025-5-18 12:21 , Processed in 0.228202 second(s), 27 queries .
