查看: 3318|回复: 2
[emWin] 创建对话框GUI_CreateDialogBox占用很大RO-data
发表于 2019-7-26 11:55:32 | 显示全部楼层 |阅读模式
F429IG的flash只有1M
//创建对话框
hDkWin = GUI_CreateDialogBox(_aDialogCreateDk4Windows,                                 //窗体内部窗体指针
                                                GUI_COUNTOF(_aDialogCreateDk4Windows),         //窗体内部窗体个数
                                                 _cbCallbackDkWindows,                                         //cb
                                                 id,        //父窗口的ID
                                                 0,        //父窗口的位置
                                                 GUI_CONTROL_Y);                                                        //父窗口的位置
//里面9个按钮
static const GUI_WIDGET_CREATE_INFO _aDialogCreateDk4Windows[] =
                { WINDOW_CreateIndirect,  "",   0,                                           0,          0, 640,        480,        0},//窗体
                { BUTTON_CreateIndirect, "", DK_BTN_1, GUI_BTN_INDEX_X_0, GUI_BTN_INDEX_Y_0, GUI_BTN_XSIZE, GUI_BTN_YSIZE, 0, 0x0, 0 },
                { BUTTON_CreateIndirect, "", DK_BTN_2, GUI_BTN_INDEX_X_1, GUI_BTN_INDEX_Y_0, GUI_BTN_XSIZE, GUI_BTN_YSIZE, 0, 0x0, 0 },
                { BUTTON_CreateIndirect, "", DK_BTN_3, GUI_BTN_INDEX_X_2, GUI_BTN_INDEX_Y_0, GUI_BTN_XSIZE, GUI_BTN_YSIZE, 0, 0x0, 0 },
                { BUTTON_CreateIndirect, "", DK_BTN_4, GUI_BTN_INDEX_X_3, GUI_BTN_INDEX_Y_0, GUI_BTN_XSIZE, GUI_BTN_YSIZE, 0, 0x0, 0 },
                { BUTTON_CreateIndirect, "", DK_BTN_5, GUI_BTN_INDEX_X_0, GUI_BTN_INDEX_Y_1, GUI_BTN_XSIZE, GUI_BTN_YSIZE, 0, 0x0, 0 },
                { BUTTON_CreateIndirect, "", DK_BTN_6, GUI_BTN_INDEX_X_1, GUI_BTN_INDEX_Y_1, GUI_BTN_XSIZE, GUI_BTN_YSIZE, 0, 0x0, 0 },
                { BUTTON_CreateIndirect, "", DK_BTN_7, GUI_BTN_INDEX_X_2, GUI_BTN_INDEX_Y_1, GUI_BTN_XSIZE, GUI_BTN_YSIZE, 0, 0x0, 0 },
                { BUTTON_CreateIndirect, "", DK_BTN_8, GUI_BTN_INDEX_X_3, GUI_BTN_INDEX_Y_1, GUI_BTN_XSIZE, GUI_BTN_YSIZE, 0, 0x0, 0 },
                { BUTTON_CreateIndirect, "", DK_BTN_BK, GUI_BK_X, GUI_BK_Y, GUI_BK_XSIZE, GUI_BK_YSIZE, 0, 0x0, 0 },
编译结果
Program Size: Code=103844 RO-data=242408 RW-data=1612 ZI-data=4260980
240K有点夸张了。
没编译这个窗体,占用才9k
各位大哥占用也这么大吗?
发表于 2019-7-27 09:48:20 | 显示全部楼层
我这里没这么大,可以看下你的map文件,那个占用了很大空间。
发表于 2019-7-27 14:11:27 | 显示全部楼层
能占用这么大的,要么是字体要么是图片
GMT+8, 2025-5-18 07:45 , Processed in 0.415240 second(s), 28 queries .
