查看: 3102|回复: 15
[RL-TCPnet] RL-TCPnet的BSD Socket API缺少函数
发表于 2019-9-21 11:51:05 | 显示全部楼层 |阅读模式
使用RL-TCPnet作为TCP/IP协议栈发现缺少4个函数
select(),fcntl(),getsockopt(),setsockopt()
怎样补全,有什么建议
发表于 2019-9-21 11:54:30 | 显示全部楼层
需要这些的话,后面使用新版V7.X就行,比较全了
accept — Accept connect request for a listening socket. [thread-safe].
bind — Assign a local address and port to a socket. [thread-safe].
closesocket — Close socket and release socket descriptor. [thread-safe].
connect — Connect a socket to a remote host. [thread-safe].
gethostbyname — Retrieve host IP address from host name. [thread-safe].
getpeername — Retrieve IP address and port number of the endpoint node. [thread-safe].
getsockname — Retrieve local IP address and port number. [thread-safe].
getsockopt — Retrieve options for the socket. [thread-safe].
ioctlsocket — Control IO mode of a socket. [thread-safe].
listen — Set a socket in a listening mode. [thread-safe].
recv — Receive data on already connected socket. [thread-safe].
recvfrom — Receive data from endpoint node. [thread-safe].
recvmsg — Receive a message from a socket. [thread-safe].
select — Check the status of one or more sockets. [thread-safe].
send — Send data on already connected socket. [thread-safe].
sendto — Send data to endpoint node. [thread-safe].
sendmsg — Send a message to endpoint node. [thread-safe].
setsockopt — Manipulate options for the socket. [thread-safe].
socket — Create a communication endpoint called socket. [thread-safe].
inet_addr — Convert from text address to a network address. [thread-safe].
inet_aton — Convert from text address to a network address. [thread-safe].
inet_ntoa — Convert from network address to a text string. [not_thread-safe].
inet_pton — Convert from text address to a binary network address. [thread-safe].
inet_ntop — Convert from binary network address to a text string. [thread-safe].
 楼主| 发表于 2019-9-21 12:37:51 | 显示全部楼层
可惜现在使用的是RTX,新版V7.X还是缺少fcntl函数,LWIP有提供
#if LWIP_POSIX_SOCKETS_IO_NAMES
#define read(a,b,c)           lwip_read(a,b,c)
#define write(a,b,c)          lwip_write(a,b,c)
#define close(s)              lwip_close(s)
#define fcntl(a,b,c)          lwip_fcntl(a,b,c)
#endif /* LWIP_POSIX_SOCKETS_IO_NAMES */
另外新版V7.X还是没发现支持WebSocket
发表于 2019-9-21 13:18:43 | 显示全部楼层
#define ...
1、新版不限制RTX,各种RTOS都支持,用户添加个CMSIS-RTOS封装层即可,当前RTX和FreeRTOS已经原生支持。
2、主要是send,  recv,其他函数函数很少用,或者基本没用过。像老版的那就已经足够用了。
3、 而Websocket还是移植个第3方组件吧
 楼主| 发表于 2019-9-21 15:27:49 | 显示全部楼层
Websocket的第3方组件要求的函数很全,基本上都用到了
发表于 2019-9-21 15:36:16 | 显示全部楼层
那我明白了,你是为了搞WebSocket而搞这些东西。
没问题的,你像emNET,也是好几个BSD Socket没有,但是他们的支持WebSocket,所以依然是好些都用不到。
所以老版本的那几个就足够。
 楼主| 发表于 2019-9-21 15:41:21 | 显示全部楼层
是的,我移植mongoose,要用HTTP server,WebSocket server。缺少select(),fcntl(),getsockopt(),setsockopt()函数。求硬件指点,不行就只能用LWIP了
发表于 2019-9-21 15:46:38 | 显示全部楼层
BSD Socket API
WebSocket API
 楼主| 发表于 2019-9-21 15:51:34 | 显示全部楼层
什么库?
发表于 2019-9-21 15:56:57 | 显示全部楼层
takent 发表于 2019-9-21 15:41
是的,我移植mongoose,要用HTTP server,WebSocket server。缺少select(),fcntl(),getsockopt(),setsock ...
如果你要移植mongoose,那你还是用lwip吧,毕竟你需要的函数都有。
发表于 2019-9-21 15:58:19 | 显示全部楼层
【STM32H743实验例程】实验22:SEGGER为H7配套的embOS及其所有中间件的大综合设计
http://www.armbbs.cn/forum.php?m ... 9010&fromuid=58
 楼主| 发表于 2019-9-21 15:59:20 | 显示全部楼层
好的,谢谢了
 楼主| 发表于 2019-9-21 16:22:17 | 显示全部楼层
如果RTX用新版V7.X有教程吗,我怕LWIP+RTX坑比较多
发表于 2019-9-21 16:32:56 | 显示全部楼层
还没有发布,近期上线模板
 楼主| 发表于 2019-9-23 11:51:30 | 显示全部楼层
我还是想使用新版V7.X,缺少fcntl函数不影响,fcntl函数只是将socket设置为非阻塞模式,而我们使用OS就是非阻塞模式,所以想用V7.X+RTX的组合,求硬汉指点,V7.X在RTX的使用
发表于 2019-9-23 12:37:48 | 显示全部楼层
takent 发表于 2019-9-23 11:51
我还是想使用新版V7.X,缺少fcntl函数不影响,fcntl函数只是将socket设置为非阻塞模式,而我们使用OS就是非 ...
好的,我争取早点分享工程给大家
GMT+8, 2025-7-4 21:02 , Processed in 0.333595 second(s), 27 queries .
