查看: 3803|回复: 3
[emWin] GUI_DrawBitmap和GUI_DrawBitmapMag
发表于 2019-10-22 18:02:10 | 显示全部楼层 |阅读模式
  const void * pData;
  WM_HWIN      hItem;
  U32          FileSize;
  // USER END
  switch (pMsg->MsgId) {
  case WM_INIT_DIALOG:
    // Initialization of 'Image'
    hItem = WM_GetDialogItem(pMsg->hWin, ID_IMAGE_0);
    pData = _GetImageById(ID_IMAGE_0_IMAGE_0, &FileSize);
    IMAGE_SetBMP(hItem, pData, FileSize);
    // USER START (Optionally insert additional code for further widget initialization)
    // USER END
  // USER END
  case WM_PAINT:
          GUI_DrawBitmapMag(&bmstart1, 100, 10, 3, 3);
          GUI_DrawBitmap(&bmstart1, 200, 50);
  default:
    WM_DefaultProc(pMsg);
发现一个奇怪的现象,红色的代码部分,也就是GUI_DrawBitmap不能显示图片,但是用GUI_DrawBitmapMag就可以显示图片这是为什么
并且我试验过不是放大后的图片遮住了,而且GUI_DrawBitmapMag(&bmstart1, 100, 10, 1, 1);只放大一倍也不能显示,最小要放大2倍,感觉好奇怪啊
下面时两个函数相关的代码
*       GUI_DrawBitmap
void GUI_DrawBitmap(const GUI_BITMAP GUI_UNI_PTR * pBitmap, int x0, int y0) {
  #if (GUI_WINSUPPORT)
    GUI_RECT r;
  GUI_LOCK();
    WM_ADDORG(x0,y0);
    r.x1 = (r.x0 = x0) + pBitmap->XSize-1;
    r.y1 = (r.y0 = y0) + pBitmap->YSize-1;
    WM_ITERATE_START(&r) {
  GL_DrawBitmap(pBitmap, x0, y0);
    } WM_ITERATE_END();
  GUI_UNLOCK();
*       GL_DrawBitmap
* Purpose:
*  Translates the external bitmap format into an internal
*  format. This turned out to be necessary as the internal
*  format is easier to create and more flexible for routines
*  that draw text-bitmaps.
void GL_DrawBitmap(const GUI_BITMAP GUI_UNI_PTR * pBitmap, int x0, int y0) {
  GUI_DRAWMODE PrevDraw;
  const GUI_LOGPALETTE GUI_UNI_PTR * pPal;
  pPal = pBitmap->pPal;
  PrevDraw = GUI_SetDrawMode(0);  /* No Get... at this point */
  GUI_SetDrawMode((pPal && pPal->HasTrans) ? (PrevDraw|GUI_DRAWMODE_TRANS) : PrevDraw &(~GUI_DRAWMODE_TRANS));
  if (pBitmap->pMethods) {
    #if GUI_COMPILER_SUPPORTS_FP      /* Do not support this on VERY simple chips and compilers */
      pBitmap->pMethods->pfDraw(x0, y0, pBitmap->XSize ,pBitmap->YSize, (U8 const *)pBitmap->pData, pBitmap->pPal, 1, 1);
  } else {
    const LCD_PIXELINDEX* pTrans;
    pTrans = LCD_GetpPalConvTable(pBitmap->pPal);
    if (!pTrans) {
      pTrans = (pBitmap->BitsPerPixel != 1) ? NULL : &LCD_BKCOLORINDEX;
    LCD_DrawBitmap( x0,y0
                    ,pBitmap->XSize ,pBitmap->YSize
                    ,1,1
                    ,pBitmap->BitsPerPixel
                    ,pBitmap->BytesPerLine
                    ,pBitmap->pData
                    ,pTrans);
  GUI_SetDrawMode(PrevDraw);
*       GUI_DrawBitmapMag
void GUI_DrawBitmapMag(const GUI_BITMAP GUI_UNI_PTR *pBitmap, int x0, int y0, int xMul, int yMul) {
  int xSize, ySize;
  GUI_LOCK();
  xSize = pBitmap->XSize;
  ySize = pBitmap->YSize;
  pTrans = LCD_GetpPalConvTable(pPal);
  if (!pTrans) {
  PrevDraw = GUI_SetDrawMode((pPal && pPal->HasTrans) ? GUI_DRAWMODE_TRANS : 0);
    WM_ADDORG(x0,y0);
      GUI_RECT r;
      r.x0 = x0;
      r.x1 = x0 + xSize * xMul -1;
      r.y0 = y0;
      r.y1 = y0 + ySize * yMul -1;
      WM_ITERATE_START(&r);
      pBitmap->pMethods->pfDraw(x0, y0, pBitmap->XSize ,pBitmap->YSize, (U8 const *)pBitmap->pData, pBitmap->pPal, xMul, yMul);
  } else {
    LCD_DrawBitmap(x0, y0, xSize, ySize, xMul, yMul
                    ,pBitmap->BitsPerPixel, pBitmap->BytesPerLine
                    ,pBitmap->pData, pTrans);
      WM_ITERATE_END();
  GUI_UNLOCK();
 楼主| 发表于 2019-10-22 19:37:01 | 显示全部楼层
1.函数调用过程:
GUI_DrawBitmap( )------>GL_DrawBitmap( )------>LCD_DrawBitmap( )------>
LCDDEV_L0_DrawBitmap( )------>DrawBitLineXpp( )------>SETPIXEL( )
2.说明
   2.1  ucgui经过一层层的参数检查和转换,最终分成一条一条线,然后再将单个像素
    画出来。
  2.2 bitmap定义过程
   先定义个GUI_COLOR 数组,说明palette(调色板)中支持的颜色
  再定下定义一个palette结构体,说明支持的颜色入口及是否透明
  接着定义了一个unsigned char数组,用来存储图片的颜色信息
  最后定义一个GUI_BITMAP,指出图片的入口信息,调色板的入口信息,大小等。
发表于 2019-10-23 08:26:49 | 显示全部楼层
GUI_DrawBitmap属于基本的API,如果这个都无法显示的话,你的程序模板有问题。
 楼主| 发表于 2019-10-23 08:42:00 | 显示全部楼层
原来是这样,我重新找个模板移植一遍试一试,谢谢!
GMT+8, 2025-5-18 15:24 , Processed in 0.298526 second(s), 24 queries .
