查看: 1166|回复: 1
[Qt] qml_dup demo
发表于 2019-12-7 09:26:52 | 显示全部楼层 |阅读模式
来源于网络,亲试可用。
//--------------------MYUDP_H ------------------------------
#ifndef MYUDP_H
#define MYUDP_H
#include <QObject>
#include <QUdpSocket>
class MyUDP : public QObject
    Q_OBJECT
    Q_PROPERTY(QByteArray type READ type WRITE setType NOTIFY typeChanged)
public:
    explicit MyUDP(QObject *parent = 0);
    void SayHello();
    QByteArray type();
    void setType(const QByteArray &t);
signals:
    void typeChanged();
public slots:
    void readyRead();
private:
    QUdpSocket *socket;
    QByteArray _type;
//------------------  MyUDP.cpp------------------------------------
#include "myudp.h"
MyUDP::MyUDP(QObject *parent) : QObject(parent)
socket = new QUdpSocket(this);
socket->bind(QHostAddress:ocalHost, 5824);
connect(socket,SIGNAL(readyRead()),this, SLOT(readyRead()));
// send message in client mode
void MyUDP::SayHello()
    QByteArray Data;
    Data.append("--Test Message UDP");
    socket->writeDatagram(Data,QHostAddress:ocalHost,5824);
    // 192.168.0.100
// ---------------------main.c-----------------------------------
#include <QGuiApplication>
#include <QQmlApplicationEngine>
#include <QCoreApplication>
#include "myudp.h"
int main(int argc, char *argv[])
#if defined(Q_OS_WIN)
    QCoreApplication::setAttribute(Qt::AA_EnableHighDpiScaling);
    QGuiApplication app(argc, argv);
    QQmlApplicationEngine engine;
    qmlRegisterType<MyUDP>("MyUDP", 1,0, "MyUDP");
    engine.load(QUrl(QStringLiteral("qrc:/main.qml")));
    if (engine.rootObjects().isEmpty())
        return -1;
  //     MyUDP client;         //去掉注释 就是   client
   //    client.SayHello();     //去掉注释 就是   client
    return app.exec();
//-------------------main.qml-------------------------------
import QtQuick 2.9
import QtQuick.Window 2.2
import MyUDP 1.0
Window {
    visible: true
  //  color: "black"
    width: 320
    height: 240
    title: qsTr("DUP_Server")
    Text {
        text: qsTr("Hello DUP_Server")
        anchors.centerIn: parent
    MyUDP{
        onTypeChanged: {
            txt.text = "Recived Msg:" + type;
            console.log("recived massage is " + type)
}void MyUDP::readyRead()
    QByteArray Buffer;
    Buffer.resize(socket->pendingDatagramSize());;
    QHostAddress sender;
    quint16 senderPort;
    socket->readDatagram(Buffer.data(),Buffer.size(), &sender, &senderPort);
    qDebug()<< "Message:" << Buffer;
    setType(Buffer);
QByteArray MyUDP::type()
    return _type;
void MyUDP::setType(const QByteArray &t)
    _type = t;
    emit typeChanged();
//---------------------------  Qml_Dup_server.pro  ----------------------------------------
QT += quick   network  core
CONFIG += c++11
# The following define makes your compiler emit warnings if you use
# any feature of Qt which as been marked deprecated (the exact warnings
# depend on your compiler). Please consult the documentation of the
# deprecated API in order to know how to port your code away from it.
DEFINES += QT_DEPRECATED_WARNINGS
# You can also make your code fail to compile if you use deprecated APIs.
# In order to do so, uncomment the following line.
# You can also select to disable deprecated APIs only up to a certain version of Qt.
#DEFINES += QT_DISABLE_DEPRECATED_BEFORE=0x060000    # disables all the APIs deprecated before Qt 6.0.0
SOURCES += main.cpp \
    myudp.cpp
RESOURCES += qml.qrc
# Additional import path used to resolve QML modules in Qt Creator's code model
QML_IMPORT_PATH =
# Additional import path used to resolve QML modules just for Qt Quick Designer
QML_DESIGNER_IMPORT_PATH =
# Default rules for deployment.
qnx: target.path = /tmp/$${TARGET}/bin
else: unix:!android: target.path = /opt/$${TARGET}/bin
!isEmpty(target.path): INSTALLS += target
HEADERS += \
    myudp.h
DISTFILES += \
    android/AndroidManifest.xml \
    android/gradle/wrapper/gradle-wrapper.jar \
    android/gradlew \
    android/res/values/libs.xml \
    android/build.gradle \
    android/gradle/wrapper/gradle-wrapper.properties \
    android/gradlew.bat
ANDROID_PACKAGE_SOURCE_DIR = $$PWD/android
发表于 2019-12-8 12:38:36 | 显示全部楼层
谢谢分享
GMT+8, 2024-5-18 12:55 , Processed in 0.162014 second(s), 25 queries .
