发表于 2022-2-14 11:19:34
显示全部楼层
代码部分:
hsram1.Instance = FMC_NORSRAM_DEVICE;
hsram1.Extended = FMC_NORSRAM_EXTENDED_DEVICE;
/* hsram1.Init */
hsram1.Init.NSBank = FMC_NORSRAM_BANK1;
hsram1.Init.DataAddressMux = FMC_DATA_ADDRESS_MUX_ENABLE;
hsram1.Init.MemoryType = FMC_MEMORY_TYPE_PSRAM;
hsram1.Init.MemoryDataWidth = FMC_NORSRAM_MEM_BUS_WIDTH_16;
hsram1.Init.BurstAccessMode = FMC_BURST_ACCESS_MODE_DISABLE;
hsram1.Init.WaitSignalPolarity = FMC_WAIT_SIGNAL_POLARITY_HIGH;
hsram1.Init.WaitSignalActive = FMC_WAIT_TIMING_BEFORE_WS;
hsram1.Init.WriteOperation = FMC_WRITE_OPERATION_ENABLE;
hsram1.Init.WaitSignal = FMC_WAIT_SIGNAL_DISABLE;
hsram1.Init.ExtendedMode = FMC_EXTENDED_MODE_DISABLE;
hsram1.Init.AsynchronousWait = FMC_ASYNCHRONOUS_WAIT_ENABLE;
hsram1.Init.WriteBurst = FMC_WRITE_BURST_DISABLE;
hsram1.Init.ContinuousClock = FMC_CONTINUOUS_CLOCK_SYNC_ONLY;
hsram1.Init.WriteFifo = FMC_WRITE_FIFO_DISABLE;
hsram1.Init.NBLSetupTime = 0;
hsram1.Init.PageSize = FMC_PAGE_SIZE_NONE;
/* Timing */
Timing.AddressSetupTime = 1;
Timing.AddressHoldTime = 1;
Timing.DataSetupTime = 3;
Timing.DataHoldTime = 0;
Timing.BusTurnAroundDuration = 7;
Timing.CLKDivision = 16;
Timing.DataLatency = 17;
Timing.AccessMode = FMC_ACCESS_MODE_A;
/* ExtTiming */
if (HAL_SRAM_Init(&hsram1, &Timing, NULL) != HAL_OK)
Error_Handler( );
/* USER CODE BEGIN FMC_Init 2 */
LOG_I("HAL_SRAM_Init");
uint16_t ASP_RCR = 0,ASP_DIDR = 0,ASP_BCR = 0;
// HAL_SRAM_Read_16b(&hsram1, (uint32_t*)SRAM_ADDR, &ASP_RCR, 1);
// HAL_SRAM_Read_16b(&hsram1, (uint32_t*)(SRAM_ADDR | APS_BCR_ADDR), &ASP_BCR, 1);
// HAL_SRAM_Read_16b(&hsram1, (uint32_t*)(SRAM_ADDR | APS_DIDR_ADDR), &ASP_DIDR, 1);
ASP_RCR = *(__IO uint16_t*)(SRAM_ADDR);
ASP_DIDR = *(__IO uint16_t*)(SRAM_ADDR | APS_DIDR_ADDR);
ASP_BCR = *(__IO uint16_t *)(SRAM_ADDR | APS_BCR_ADDR);
LOG_I("ASP_RCR: %4X", ASP_RCR);
LOG_I("ASP_DIDR: %4X", ASP_DIDR);
LOG_I("ASP_BCR: %4X", ASP_BCR);
*(__IO uint16_t*)(SRAM_ADDR | APS_DIDR_ADDR) = 0x9D1F;
