楼主 |
发表于 2020-4-9 18:02:31
显示全部楼层
使用的是正点原子的F4阿波罗,这个代码是我设置的上层界面的代码- /*********************************************************************
- * SEGGER Microcontroller GmbH & Co. KG *
- * Solutions for real time microcontroller applications *
- * C-file generated by: *
- * GUI_Builder for emWin version 5.44 *
- * Compiled Nov 10 2017, 08:53:57 *
- * (c) 2017 Segger Microcontroller GmbH & Co. KG *
- * Internet: www.segger.com Support: support@segger.com *
- // USER START (Optionally insert additional includes)
- // USER END
- #include "DIALOG.h"
- #include "RealTime_Graph.h"
- * Defines
- #define ID_TYPESELECT_WINDOW (GUI_ID_USER + 0x00)
- #define ID_TYPESELECT_TEXT (GUI_ID_USER + 0x01)
- #define ID_APPLY_BUTTON (GUI_ID_USER + 0x02)
- #define ID_CANCEL_BUTTON (GUI_ID_USER + 0x03)
- #define ID_V_CHECKBOX (GUI_ID_USER + 0x04)
- #define ID_MV_CHECKBOX (GUI_ID_USER + 0x05)
- #define ID_MA_CHECKBOX (GUI_ID_USER + 0x06)
- #define ID_C_DEGREE_CHECKBOX (GUI_ID_USER + 0x07)
- #define ID_F_DEGREE_CHECKBOX (GUI_ID_USER + 0x08)
- #define ID_PPM_CHECKBOX (GUI_ID_USER + 0x09)
- #define ID_HZ_CHECKBOX (GUI_ID_USER + 0x0A)
- #define ID_PULSE_CHECKBOX (GUI_ID_USER + 0x0B)
- unsigned short RTTypeCheckState = 0;
- unsigned short TypeButtonHandle[2] = { 0 };
- int _Alpha_0 = 105; //重绘操作的alpha值
- int _Alpha_1 = 255; //
- BUTTON_SKINFLEX_PROPS Button_SkinFlex_Props;
- * Static data
- // USER START (Optionally insert additional static data)
- // USER END
- * _aDialogCreate
- static const GUI_WIDGET_CREATE_INFO _a_RTType_DialogCreate[] = {
- { WINDOW_CreateIndirect, "", ID_TYPESELECT_WINDOW, 0, 0, 800, 480, 0, 0x0, 0 },
- { TEXT_CreateIndirect, "", ID_TYPESELECT_TEXT, 95, 74, 51, 22, WM_CF_SHOW | TEXT_CF_HCENTER | TEXT_CF_VCENTER, 0x0, 0 },
- { BUTTON_CreateIndirect, "", ID_APPLY_BUTTON, 210, 362, 140, 50, 0, 0x0, 0 },
- { BUTTON_CreateIndirect, "", ID_CANCEL_BUTTON, 450, 362, 140, 50, 0, 0x0, 0 },
- { CHECKBOX_CreateIndirect, "", ID_V_CHECKBOX, 95, 128, 80, 23, 0, 0x0, 0 },
- { CHECKBOX_CreateIndirect, "", ID_MV_CHECKBOX, 256, 129, 80, 23, 0, 0x0, 0 },
- { CHECKBOX_CreateIndirect, "", ID_MA_CHECKBOX, 419, 128, 80, 23, 0, 0x0, 0 },
- { CHECKBOX_CreateIndirect, "", ID_C_DEGREE_CHECKBOX, 581, 128, 80, 23, 0, 0x0, 0 },
- { CHECKBOX_CreateIndirect, "", ID_F_DEGREE_CHECKBOX, 95, 190, 80, 23, 0, 0x0, 0 },
- { CHECKBOX_CreateIndirect, "", ID_PPM_CHECKBOX, 256, 190, 80, 23, 0, 0x0, 0 },
- { CHECKBOX_CreateIndirect, "", ID_HZ_CHECKBOX, 419, 190, 80, 23, 0, 0x0, 0 },
- { CHECKBOX_CreateIndirect, "", ID_PULSE_CHECKBOX, 581, 190, 80, 23, 0, 0x0, 0 },
- // USER START (Optionally insert additional widgets)
- // USER END
- * Static code
- //按键换肤函数
- int _DrawSkin_TypeSelect_Button(const WIDGET_ITEM_DRAW_INFO* pDrawItemInfo)
- switch (pDrawItemInfo->Cmd)
- //case WIDGET_ITEM_CREATE:
- //BUTTON_SetTextAlign(pDrawItemInfo->hWin, TEXT_CF_HCENTER | TEXT_CF_VCENTER);
- //break;
- case WIDGET_ITEM_DRAW_BACKGROUND:
- switch (BUTTON_IsPressed(pDrawItemInfo->hWin))
- case 0:
- if (TypeButtonHandle[0] == pDrawItemInfo->hWin)
- GUI_SetColor(0x007AFF);
- GUI_AA_FillRoundedRect(pDrawItemInfo->x0, pDrawItemInfo->y0, pDrawItemInfo->x1, pDrawItemInfo->y1, 6);
- else if (TypeButtonHandle[1] == pDrawItemInfo->hWin)
- GUI_SetColor(0xFF453A);
- break;
- case 1:
- GUI_SetColor(0x0060FF);
- GUI_SetColor(0xF30E00);
- break;
- default:
- break;
- //if (ButtonHandle[0] == pDrawItemInfo->hWin)
- // if (BUTTON_IsPressed(pDrawItemInfo->hWin))
- // //if (RT_BUTTON_STATE == 0)
- // GUI_SetColor(0xFF7A00);
- // GUI_AA_FillRoundedRect(pDrawItemInfo->x0, pDrawItemInfo->y0, pDrawItemInfo->x1, pDrawItemInfo->y1, 6);
- // else
- //else if (ButtonHandle[1] == pDrawItemInfo->hWin)
- // GUI_SetColor(0x3A45FF);
- // else
- break;
- default:
- BUTTON_DrawSkinFlex(pDrawItemInfo);
- break;
- int _One_num(WM_MESSAGE* pMsg ,unsigned short state)
- int i = 0, num = 0;
- for (i = 0; i < 8; i++)
- if (state & (1 << i))
- num++;
- if (num >= 2)
- break;
- if ((state & (1 << i)) == 0)
- if (num >= 2)
- WM_DisableWindow(WM_GetDialogItem(pMsg->hWin, ID_V_CHECKBOX + i));
- CHECKBOX_SetTextColor(WM_GetDialogItem(pMsg->hWin, ID_V_CHECKBOX + i), 0xE6E6E6);
- else
- CHECKBOX_SetTextColor(WM_GetDialogItem(pMsg->hWin, ID_V_CHECKBOX + i), GUI_BLACK);
- WM_EnableWindow(WM_GetDialogItem(pMsg->hWin, ID_V_CHECKBOX + i));
- return num;
- unsigned short CheckBoxState = 0;
- * _cbDialog
- static void _cb_RTType_Dialog(WM_MESSAGE * pMsg) {
- WM_HWIN hItem;
- int NCode;
- int Id;
- int i = 0;
- switch (pMsg->MsgId) {
- case WM_INIT_DIALOG:
- CheckBoxState = RTTypeCheckState;
- hItem = WM_GetDialogItem(pMsg->hWin, ID_TYPESELECT_TEXT);
- TEXT_SetFont(hItem, &GUI_FontYaHei28);
- TEXT_SetText(hItem, "Type");
- // Button_SkinFlex_Props.aColorFrame[0]=0x007AFF;
- // Button_SkinFlex_Props.aColorFrame[1]=0x007AFF;
- // Button_SkinFlex_Props.aColorFrame[2]=0x007AFF;
- // Button_SkinFlex_Props.aColorLower[0]=0x007AFF;
- // Button_SkinFlex_Props.aColorLower[1]=0x007AFF;
- // Button_SkinFlex_Props.aColorUpper[0]=0x007AFF;
- // Button_SkinFlex_Props.aColorUpper[1]=0x007AFF;
- // Button_SkinFlex_Props.Radius=6;
- // BUTTON_SetSkinFlexProps(&Button_SkinFlex_Props,BUTTON_SKINFLEX_PI_FOCUSSED);
- // BUTTON_SetSkinFlexProps(&Button_SkinFlex_Props,BUTTON_SKINFLEX_PI_ENABLED);
- // Button_SkinFlex_Props.aColorFrame[0]=0x0060FF;
- // Button_SkinFlex_Props.aColorFrame[1]=0x0060FF;
- // Button_SkinFlex_Props.aColorFrame[2]=0x0060FF;
- // Button_SkinFlex_Props.aColorLower[0]=0x0060FF;
- // Button_SkinFlex_Props.aColorLower[1]=0x0060FF;
- // Button_SkinFlex_Props.aColorUpper[0]=0x0060FF;
- // Button_SkinFlex_Props.aColorUpper[1]=0x0060FF;
- // BUTTON_SetSkinFlexProps(&Button_SkinFlex_Props,BUTTON_SKINFLEX_PI_PRESSED);
- hItem = WM_GetDialogItem(pMsg->hWin, ID_APPLY_BUTTON);
- BUTTON_SetFont(hItem, &GUI_FontYaHei24);
- //BUTTON_SetTextColor(hItem, BUTTON_SKINFLEX_PI_ENABLED, GUI_WHITE);
- BUTTON_SetTextColor(hItem, BUTTON_SKINFLEX_PI_PRESSED, GUI_WHITE);
- BUTTON_SetTextColor(hItem, BUTTON_SKINFLEX_PI_FOCUSSED, GUI_WHITE);
- BUTTON_SetText(hItem, "Apply");
- //ButtonHandle = 0;
- TypeButtonHandle[0] = hItem;
- BUTTON_SetSkin(hItem, _DrawSkin_TypeSelect_Button); //换肤回调函数
- hItem = WM_GetDialogItem(pMsg->hWin, ID_CANCEL_BUTTON);
- BUTTON_SetText(hItem, "Cancel");
- //ButtonHandle = 1;
- TypeButtonHandle[1] = hItem;
- //CHECKBOX_SetDefaultSpacing(10);
- //CHECKBOX_SetDefaultFont(&GUI_FontYaHei20);
- CheckBox_Skinflex_Props.aColorFrame[0] = GUI_LIGHTGRAY;
- CheckBox_Skinflex_Props.aColorFrame[1] = GUI_WHITE;
- CheckBox_Skinflex_Props.aColorFrame[2] = GUI_WHITE;
- CheckBox_Skinflex_Props.aColorInner[0] = GUI_WHITE;
- CheckBox_Skinflex_Props.aColorInner[1] = GUI_WHITE;
- CheckBox_Skinflex_Props.ColorCheck = 0x00007AFF; //GUI_CYAN;
- CHECKBOX_SetSkinFlexProps(&CheckBox_Skinflex_Props, CHECKBOX_SKINFLEX_PI_ENABLED);
- CheckBox_Skinflex_Props.aColorFrame[0] = 0xE6E6E6;
- CHECKBOX_SetSkinFlexProps(&CheckBox_Skinflex_Props, CHECKBOX_SKINFLEX_PI_DISABLED);
- // Initialization of 'Checkbox'
- hItem = WM_GetDialogItem(pMsg->hWin, ID_V_CHECKBOX);
- CHECKBOX_SetFocusColor(hItem, GUI_WHITE);
- CHECKBOX_SetFont(hItem, &GUI_FontYaHei24);
- CHECKBOX_SetText(hItem, "V");
- CHECKBOX_SetSpacing(hItem, 10);
- CHECKBOX_SetSkinFlexButtonSize(hItem, 22);
- hItem = WM_GetDialogItem(pMsg->hWin, ID_MV_CHECKBOX);
- CHECKBOX_SetText(hItem, "mV");
- hItem = WM_GetDialogItem(pMsg->hWin, ID_MA_CHECKBOX);
- CHECKBOX_SetText(hItem, "mA");
- hItem = WM_GetDialogItem(pMsg->hWin, ID_C_DEGREE_CHECKBOX);
- CHECKBOX_SetText(hItem, "℃啊");
- hItem = WM_GetDialogItem(pMsg->hWin, ID_F_DEGREE_CHECKBOX);
- CHECKBOX_SetText(hItem, "℉啊");
- hItem = WM_GetDialogItem(pMsg->hWin, ID_PPM_CHECKBOX);
- CHECKBOX_SetText(hItem, "ppm");
- hItem = WM_GetDialogItem(pMsg->hWin, ID_HZ_CHECKBOX);
- CHECKBOX_SetText(hItem, "Hz");
- hItem = WM_GetDialogItem(pMsg->hWin, ID_PULSE_CHECKBOX);
- CHECKBOX_SetText(hItem, "Pulse");
- CHECKBOX_SetSpacing(hItem,10);
- hItem = WM_GetDialogItem(pMsg->hWin, ID_V_CHECKBOX + i);
- CHECKBOX_SetState(hItem, ((RTTypeCheckState >> i) & 0x0001));
- break;
- case WM_PAINT:
- GUI_SetAlpha(_Alpha_0); // Set alpha value for drawing operations
- //GUI_SetBkColor(GUI_MAKE_COLOR(0xAAAAAA)); // Draw gray background...
- //GUI_SetBkColor(GUI_MAKE_COLOR(0x000000)); // Draw black background...
- GUI_SetBkColor(GUI_BLACK); // Draw gray background...
- GUI_Clear(); // ...with alpha blending
- GUI_SetAlpha((GUI_MAKE_COLOR(0) >> 24)); // Set alpha value to default
- GUI_SetColor(GUI_WHITE);
- GUI_FillRect(65, 52, 735, 428);
- TEXT_SetText(WM_GetDialogItem(pMsg->hWin,ID_TYPESELECT_TEXT), "Type");
- //_One_num(pMsg, CheckBoxState);
- _One_num(pMsg, RTTypeCheckState);
- break;
- case WM_NOTIFY_PARENT:
- Id = WM_GetId(pMsg->hWinSrc);
- NCode = pMsg->Data.v;
- switch(Id) {
- case ID_APPLY_BUTTON: // Notifications sent by 'Button'
- switch (NCode) {
- case WM_NOTIFICATION_CLICKED:
- //_DeleteRTTypeSelectWindow(pMsg);
- break;
- case WM_NOTIFICATION_RELEASED:
- _DeleteRTTypeSelectWindow(pMsg);
- break;
- break;
- case ID_CANCEL_BUTTON: // Notifications sent by 'Button'
- switch (NCode) {
- break;
- RTTypeCheckState = CheckBoxState;
- break;
- break;
- case ID_V_CHECKBOX: // Notifications sent by 'Checkbox'
- switch(NCode) {
- //CheckBoxState ^= (1 << 0);
- RTTypeCheckState ^= (1 << 0);
- WM_InvalidateWindow(pMsg->hWin);
- break;
- break;
- case WM_NOTIFICATION_VALUE_CHANGED:
- break;
- break;
- case ID_MV_CHECKBOX: // Notifications sent by 'Checkbox'
- switch(NCode) {
- //CheckBoxState ^= (1 << 1);
- RTTypeCheckState ^= (1 << 1);
- break;
- break;
- // RTTypeCheckState ^= (1 << 1);
- break;
- break;
- case ID_MA_CHECKBOX: // Notifications sent by 'Checkbox'
- switch(NCode) {
- //CheckBoxState ^= (1 << 2);
- RTTypeCheckState ^= (1 << 2); WM_InvalidateWindow(pMsg->hWin);
- break;
- break;
- // RTTypeCheckState ^= (1 << 2);
- break;
- break;
- case ID_C_DEGREE_CHECKBOX: // Notifications sent by 'Checkbox'
- switch(NCode) {
- //CheckBoxState ^= (1 << 3);
- RTTypeCheckState ^= (1 << 3); WM_InvalidateWindow(pMsg->hWin);
- break;
- break;
- // RTTypeCheckState ^= (1 << 3);
- break;
- break;
- case ID_F_DEGREE_CHECKBOX: // Notifications sent by 'Checkbox'
- switch(NCode) {
- //CheckBoxState ^= (1 << 4);
- RTTypeCheckState ^= (1 << 4); WM_InvalidateWindow(pMsg->hWin);
- break;
- break;
- // RTTypeCheckState ^= (1 << 4);
- break;
- break;
- case ID_PPM_CHECKBOX: // Notifications sent by 'Checkbox'
- switch(NCode) {
- //CheckBoxState ^= (1 << 5);
- RTTypeCheckState ^= (1 << 5); WM_InvalidateWindow(pMsg->hWin);
- break;
- break;
- // RTTypeCheckState ^= (1 << 5);
- break;
- break;
- case ID_HZ_CHECKBOX: // Notifications sent by 'Checkbox'
- switch(NCode) {
- //CheckBoxState ^= (1 << 6);
- RTTypeCheckState ^= (1 << 6); WM_InvalidateWindow(pMsg->hWin);
- break;
- break;
- // RTTypeCheckState ^= (1 << 6);
- break;
- break;
- case ID_PULSE_CHECKBOX: // Notifications sent by 'Checkbox'
- switch(NCode) {
- //CheckBoxState ^= (1 << 7);
- RTTypeCheckState ^= (1 << 7); WM_InvalidateWindow(pMsg->hWin);
- break;
- break;
- // RTTypeCheckState ^= (1 << 7);
- break;
- break;
- break;
- default:
- WM_DefaultProc(pMsg);
- break;
- * Public code
- void _Alpha_cbWindow(WM_MESSAGE* pMsg) {
- case WM_PAINT:
- GUI_SetAlpha(_Alpha_1);
- //GUI_SetBkColor(GUI_MAKE_COLOR(GUI_WHITE));
- //GUI_Clear();
- break;
- WINDOW_Callback(pMsg);
- //FRAMEWIN_Callback(pMsg);
- //GUI_SetAlpha(0);
- * CreateWindow
- WM_HWIN _CreateRTTypeSelectWindow(void) {
- WM_HWIN hWin;
- GUI_UC_SetEncodeUTF8();
- hWin = GUI_CreateDialogBox(_a_RTType_DialogCreate, GUI_COUNTOF(_a_RTType_DialogCreate), _cb_RTType_Dialog, WM_HBKWIN, 0, 0);
- WM_SetHasTrans(hWin); // Set transparency 设置有透明性标记(可无)
- WM_SetCallback(hWin, _Alpha_cbWindow); // Overwrite callback 回调设置透明度
- return hWin;
- void _DeleteRTTypeSelectWindow(WM_MESSAGE* pMsg)
- GUI_EndDialog(pMsg->hWin,0);
- /*************************** End of file ****************************/
复制代码 |
