楼主 |
发表于 2020-5-11 21:55:31
显示全部楼层
- * LOCAL INCLUDES
- #include "stm32f4xx_hal.h"
- #include "stm32f429i_discovery.h"
- #include "os.h"
- * LOCAL DEFINES
- /* Task Stack Size */
- #define APP_TASK_START_STK_SIZE 128u
- #define LED3_TASK_STK_SIZE 128u
- #define LED4_TASK_STK_SIZE 128u
- /* Task Priority */
- #define APP_TASK_START_PRIO 1u
- #define LED3_TASK_PRIO 2u
- #define LED4_TASK_PRIO 12u
- * LOCAL GLOBAL VARIABLES
- /* Task Control Block */
- static OS_TCB AppTaskStartTCB;
- static OS_TCB LED3TaskTCB;
- static OS_TCB LED4TaskTCB;
- /* Task Stack */
- static CPU_STK AppTaskStartStk[APP_TASK_START_STK_SIZE];
- static CPU_STK LED3TaskStk[LED3_TASK_STK_SIZE];
- static CPU_STK LED4TaskStk[LED4_TASK_STK_SIZE];
- * FUNCTION PROTOTYPES
- static void AppTaskStart(void *p_arg);
- static void LED3Task(void *p_arg);
- static void LED4Task(void *p_arg);
- * MAIN
- int main(void)
- OS_ERR err;
- OSInit(&err);
- OSTaskCreate((OS_TCB *)&AppTaskStartTCB,
- (CPU_CHAR *)"App Task Start",
- (OS_TASK_PTR)AppTaskStart,
- (void *)0,
- (OS_PRIO)APP_TASK_START_PRIO,
- (CPU_STK *)&AppTaskStartStk[0],
- (CPU_STK_SIZE)APP_TASK_START_STK_SIZE / 10,
- (CPU_STK_SIZE)APP_TASK_START_STK_SIZE,
- (OS_MSG_QTY)5u,
- (OS_TICK)0u,
- (void *)0,
- (OS_OPT)(OS_OPT_TASK_STK_CHK | OS_OPT_TASK_STK_CLR),
- (OS_ERR *)&err);
- OSStart(&err);
- * STARTUP TASK
- OS_ERR err;
- HAL_Init();
- BSP_LED_Init(LED3);
- BSP_LED_Init(LED4);
- OSTaskCreate((OS_TCB *)&LED3TaskTCB,
- (CPU_CHAR *)"LED3 TASK",
- (OS_TASK_PTR)LED3Task,
- (void *)0,
- (OS_PRIO)LED3_TASK_PRIO,
- (CPU_STK *)&LED3TaskStk[0],
- (CPU_STK_SIZE)LED3_TASK_STK_SIZE / 10,
- (CPU_STK_SIZE)LED3_TASK_STK_SIZE,
- (OS_MSG_QTY)5u,
- (OS_TICK)0u,
- (void *)0,
- (OS_ERR *)&err);
- OSTaskCreate((OS_TCB *)&LED4TaskTCB,
- (CPU_CHAR *)"LED4 TASK",
- (OS_TASK_PTR)LED4Task,
- (void *)0,
- (OS_PRIO)LED4_TASK_PRIO,
- (CPU_STK *)&LED4TaskStk[0],
- (CPU_STK_SIZE)LED4_TASK_STK_SIZE / 10,
- (CPU_STK_SIZE)LED4_TASK_STK_SIZE,
- (OS_MSG_QTY)5u,
- (OS_TICK)0u,
- (void *)0,
- (OS_ERR *)&err);
- * TASKS
- OS_ERR err;
- while (DEF_TRUE)
- BSP_LED_Toggle(LED3);
- OSTimeDlyHMSM((CPU_INT16U)0,
- (CPU_INT16U)0,
- (CPU_INT16U)1u,
- (CPU_INT32U)0,
- (OS_OPT)OS_OPT_TIME_HMSM_STRICT,
- (OS_ERR *)&err);
- OS_ERR err;
- while (DEF_TRUE)
- BSP_LED_Toggle(LED4);
- (CPU_INT16U)0,
- (CPU_INT16U)1u,
- (CPU_INT32U)0,
- (OS_ERR *)&err);
复制代码 |
