查看: 4206|回复: 2
[ThreadX全家桶] ThreadX支持的中断API列表
发表于 2020-6-4 15:18:01 | 显示全部楼层 |阅读模式
像RTX4,FreeRTOS都是区分中断里面调用的API和任务里面调用的API。
而uCOS-II/III,RTX5是不区分这个,ThreadX也是这样的。
支持中断里面调用的API如下:
tx_block_allocate
tx_block_pool_info_get
tx_block_pool_prioritize
tx_block_pool_performance_info_get
tx_block_pool_performance_system_info_get
tx_block_release
tx_byte_pool_info_get
tx_byte_pool_performance_info_get
tx_byte_pool_performance_system_info_get
tx_byte_pool_prioritize
tx_event_flags_info_get
tx_event_flags_get
tx_event_flags_set
tx_event_flags_performance_info_get
tx_event_flags_performance_system_info_get
tx_event_flags_set_notify
tx_interrupt_control
tx_mutex_performance_info_get
tx_mutex_performance_system_info_get
tx_queue_front_send
tx_queue_info_get
tx_queue_performance_info_get
tx_queue_performance_system_info_get
tx_queue_prioritize
tx_queue_receive
tx_queue_send
tx_semaphore_get
tx_queue_send_notify
tx_semaphore_ceiling_put
tx_semaphore_info_get
tx_semaphore_performance_info_get
tx_semaphore_performance_system_info_get
tx_semaphore_prioritize
tx_semaphore_put
tx_thread_identify
tx_semaphore_put_notify
tx_thread_entry_exit_notify
tx_thread_info_get
tx_thread_resume
tx_thread_performance_info_get
tx_thread_performance_system_info_get
tx_thread_stack_error_notify
tx_thread_wait_abort
tx_time_get
tx_time_set
tx_timer_activate
tx_timer_change
tx_timer_deactivate
tx_timer_info_get
tx_timer_performance_info_get
tx_timer_performance_system_info_get
Pend挂起类API在中断里面调用必须设置为TX_NO_WAIT。
发表于 2020-6-4 15:55:37 | 显示全部楼层
沙发
发表于 2020-6-4 16:38:31 | 显示全部楼层
NICE
GMT+8, 2025-5-19 05:10 , Processed in 0.232109 second(s), 24 queries .
