查看: 2850|回复: 6
[ThreadX全家桶] ThreadX GUIX常用宏定义,有必要逐一了解每个宏定义的含义
发表于 2020-6-13 09:22:06 | 显示全部楼层 |阅读模式
这些宏定义都比较重要,需要逐一了解:
GX_DISABLE_THREADX_BINDING
- Default: Undefined
- Description: This conditional can be used to disable the
  default ThreadX RTOS binding. If you want to run GUIX
  with an RTOS other than ThreadX, you should #define
  GX_DISABLE_THREADX_BINDING and provide your
  own RTOS binding services
GX_SYSTEM_TIMER_MS
- Default: 20
- Description: This value defines the desired GUIX timer
  interval or precision.
TX_TIMER_TICKS_PER_SECOND
- Default: 100
- Descrption: This value defines the number of TX timer
  interrupt frequence. Since the default ThreadX interval
  timer is usually 10ms, this value defaults to a 100 Hz
  frequency.
GX_SYSTEM_TIMER_TICKS
- Default: ((GX_SYSTEM_TIMER_MS * TX_TIMER_TICKS_PER_SECOND) / 1000)
- Description: This value defines the number of underlying
  RTOS timer ticks per GUIX timer tick. The default value is
  2, meaning the GUIX timer interval is 2 ThreadX timer
  interrupt intervals, or 20 ms by defaut
GX_DISABLE_MULTITHREAD_SUPPORT
- Default: Not defined
- Description: This compile-time conditional can be used to
disable the GUIX API support for multiple threads invoking
the GUIX API concurrently. If only one application thread
will ever utilize the GUIX API, you should define this flag to
reduce the system overhead associated with protecting
critical code sections.
GX_DISABLE_UTF8_SUPPORT
- Default: Not Defined.
remove the GUIX internal support for UTF8 format string
encoding. If you are using only character values M- 0xff in
your application, turning on this #define will reduce the
code size and overhead associated with supporting UTF8
format string encoding.
GX_DISABLE_ARC_DRAWING_SUPPORT
- Default: Not defined.
- Description: This conditional can be used to reduce the
GUIX library code size and GX_DISPLAY structure size by
removing support for the arc-drawing functions circle, arc,
pie, and ellipse. These functions are not required by the
default GUIX widget set
GX_DISABLE_SOFTWARE_DECODER_SUPPORT
- Description: This conditional can be defined to remove the
GUIX library runtime jpeg and png software decoder
support. If your application does not require runtime
decode of jpg or png files, meaning your application does
not use RAW format pixelmaps produced by Studio and
does not read image files from an external filesystem, you
can turn on this #define to reduce the GUIX library
footprint
GX_DISABLE_BINARY_RESOURCE_SUPPORT
- Description: This conditional can be used to remove the
GUIX library support for loading binary resource data.
Binary resources can be used to do runtime binding of
resource data with your GUIX application. If you are using
only C source code format resource files, you can define
this conditional to reduce your GUIX library footprint
GX_DISABLE_BRUSH_ALPHA_SUPPORT
Description: When running at 16 bpp and higher color
depths, GUIX optionally supports drawing non-arc
graphics, pixelmaps, and fonts with an alpha value defined
by the drawing context brush. Supporting this drawing
mode introduces a small runtime overhead and library
footprint increase, which can be eliminated by defining this
flag if you do not require alpha-blending drawing support.
Note that pixelmaps with alpha channel, anti-aliased fonts,
and other anti-aliasing drawing modes are still supported
regardless of this conditional setting
GX_REPEAT_BUTTON_INITIAL_TICS
Default: 10.
Description: If a button has style
GX_STYLE_BUTTON_REPEAT, this value defines how
long the button waits before beginning to send repeated
GX_EVENT_CLICKED events.
GX_MAX_QUEUE_EVENTS
Default: 48.
Description: Defines the size of the GUIX event queue in
units of event structure entries. If the event queue
overflows, events being pushed into the queue are
discarded and GX_SYSTEM_ERROR is returned by the
gx_system_event_send() function.
GX_MAX_DIRTY_AREAS
Default: 64.
Description: Defines the maximum number of unique dirty
list entries that can be maintained by one canvas. When
the dirty list overflows, GUIX will default to marking the
canvas root window as dirty, which is less efficient than
drawing individual child widgets.
GX_MAX_CONTEXT_NESTING
Default: 8.
Description: Defines the maximum nesting of the drawing
context stack. This is equivalent to the maximum nesting
of parent/child/child/child widgets within the UI definition.
GX_MAX_INPUT_CAPTURE_NESTING
Default: 4.
Description: Defines the size of the stack used to maintain
the list of widgets that have captures the user input
(mouse and keyboard).
GX_SYSTEM_THREAD_PRIORITY
Default: 16.
Description: Defines the priority of the GUIX thread
created during gx_system_initialize().
GX_SYSTEM_THREAD_TIMESLICE
Default: 10.
Description: Defines the GUIX thread timeslice in terms of
RTOS timer ticks. If other threads are defined with the
same priority as the GUIX thread, this value determines
how often those competing threads are granted CPU
control.
GX_CURSOR_BLINK_INTERVAL
Default: 20.
Description: Defines the rate at which the input cursor
blinks for text input widgets. This value is in terms of GUIX
timer ticks, which by default is defines as 50ms, so a value
of 20 indicates that the input cursor blinks once per
second.
GX_MULTI_LINE_INDEX_CACHE_SIZE
Default: 32.
Description: Defines the size of the list-start index cache
maintained by the multi-line text view and multi-line text
input widgets. This cache is used to accomplish fast
vertical scrolling of multi line text widgets. For best
performance, the cache size should be set greater than
the number of visible rows of the largest multi line text
widget defined by the application. For example, if the most
visible rows for any text widget is 20 rows, the application
might define a cache size of 32 (the default), which allows
GUIX to scroll vertically without re-calculating all line start
indexes.
GX_MULTI_LINE_TEXT_BUTTON_MAX_LINES
Default: 4.
Description: The multi-line text button control block
maintains a pointer to each line of text to be displayed by
the button. This value determines the number of text
pointers needed by the worst case multi-line text button.
GX_POLYGON_MAX_EDGE_NUM
Default: 10.
Description: This value determines the most complex
polygon that can be drawn by GUIX. The polygon drawing
algorithm determines the lines needed to define the
polygon edges, and this definition defines the maximum
number of edges that can be supported.
GX_NUMERIC_SCROLL_WHEEL_STRING_BUFFER_SIZE
Default: 16.
Description: For a number scroll wheel, the scroll wheel
widget converts integer values to ascii strings. This value
determines the maximum length of the string required to
display the assigned integer values.
GX_DEFAULT_CIRCULAR_GAUGE_ANIMATION_DELAY
Default: 5.
Description: Defines the number of GUIX timer ticks
(50ms) between updates of a circular gauge configured to
animate the needle movement between last and current
angular position.
GX_NUMERIC_PROMPT_BUFFER_SIZE
Default: 16
Description: A numeric prompt allocates a buffer to convert
an integer value assigned to the prompt to an ascii string.
This definition defines the size of this character buffer.
GX_ANIMATION_POOL_SIZE
Default: 6.
Description: GUIX defines an animation pool from which
animation information structures can be dynamically
allocated and returned, using gx_system_animation_get
and gx_system_animation_free() APIs. This definition
defines the size of this animation control block pool.
GX_MOUSE_SUPPORT
Description: This definition enables support for mouse
input. Software mouse requires that the display driver
draw and track the mouse cursor, which adds extra
overhead to the display driver. This definition should only
be defined when a mouse (not a touch screen) must be
supported.
GX_HARDWARE_MOUSE_SUPPORT
Description: When this definition is defined, the GUIX
display driver utilizes hardware mouse cursor drawing
support. This reduces the memory required to capture the
canvas memory beneath the mouse cursor and improves
system performance for those hardware targets support a
mouse overlay graphics layer.
GX_FONT_KERNING_SUPPORT
Description: This definition can be defined to enable font
kerning support. Font kerning improves glyph spacing for
certain glyph combinations. This support adds a small
amount of overhead to the runtime string drawing
functions, and also adds a small amount of size to the font
data structures.
GX_WIDGET_USER_DATA
Description: If defined, this adds a user-defined data field
to the GX_WIDGET control block. This data field can be
assigned using the properties view within GUIX Studio.
This data field is ignored by GUIX internally, but can be
used by application software for many purposes.
GUIX_5_4_0_COMPATIBILITY
Description: Certain GUI APIs were modified after release
5.4.0 to add support for disabled text colors and to
improve the accuracy of certain math functions by using
fixed point match parameters. These changes make GUIX
library releases after 5.4.0 incompatible with previous
releases. However, by turning on this #define, the library
can be built such that the APIs fully compatible with
releases <= 5.4.0, meaning that no changes are needed in
existing applications to compile with the latest GUIX library
release.
GX_MAX_STRING_LENGTH
Default: 102400
Description: Defines the maximum length of a string, which
is used to test invalid strings. If the input string is
exceeding the maximum string length, it will be regard as
invalid
 楼主| 发表于 2020-6-13 09:33:49 | 显示全部楼层
宏定太多了,感觉每个都比较重要。
发表于 2020-6-13 09:46:40 | 显示全部楼层
这,,,有点多,,,,
代码不规范,亲人两行泪!
发表于 2020-6-15 15:24:49 | 显示全部楼层
eric2013 发表于 2020-6-13 09:33
宏定太多了,感觉每个都比较重要。
刚入手只要用系统默认值就可以了。 以后可以一个一个调。
 楼主| 发表于 2020-6-16 10:18:53 | 显示全部楼层
是这样的。
发表于 2022-7-13 23:47:53 | 显示全部楼层
API为啥也用宏定义
 楼主| 发表于 2022-7-14 10:44:54 | 显示全部楼层
这些是配置宏定义。
GMT+8, 2025-5-24 01:11 , Processed in 0.451685 second(s), 24 queries .
