查看: 1707|回复: 0
RL-USB V6.X自定义描述符
发表于 2020-6-16 01:59:42 | 显示全部楼层 |阅读模式
原始定义:
/* USB Device 0 Endpoint 0 Descriptor */
extern const uint8_t usbd0_ep0_descriptor[];
__WEAK const uint8_t usbd0_ep0_descriptor[] __ALIGNED(4) = { USBD_EP0(0) };
/* USB Device 0 Standard Descriptor */
extern const uint8_t usbd0_device_descriptor[];
__WEAK const uint8_t usbd0_device_descriptor[] __ALIGNED(4) = {
  USB_DEVICE_DESC_SIZE,                 /* bLength */
  USB_DEVICE_DESCRIPTOR_TYPE,           /* bDescriptorType */
  WBVAL(USBD0_BDC_USB),                 /* bcdUSB */
#if (USBD0_USE_IAD)
  USB_DEVICE_CLASS_MISCELLANEOUS,       /* bDeviceClass    (use from Interface Association Descriptors) */
  0x02,                                 /* bDeviceSubClass (use from Interface Association Descriptors) */
  0x01,                                 /* bDeviceProtocol (use from Interface Association Descriptors) */
#elif (((USBD0_CDC_CNT == 1U) && (USBD0_CDC_ACM_CNT == 1U)) || \
       ((USBD0_CDC_CNT == 1U) && (USBD0_CDC_NCM_CNT == 1U)))
  CDC_COMMUNICATION_INTERFACE_CLASS,    /* bDeviceClass */
  0x00,                                 /* bDeviceSubClass */
  0x00,                                 /* bDeviceProtocol */
#else
  0x00,                                 /* bDeviceClass    (use from Interface Descriptors) */
  0x00,                                 /* bDeviceSubClass (use from Interface Descriptors) */
  0x00,                                 /* bDeviceProtocol (use from Interface Descriptors) */
  USBD0_MAX_PACKET0,                    /* bMaxPacketSize0 */
  WBVAL(USBD0_DEV_DESC_IDVENDOR),       /* idVendor */
  WBVAL(USBD0_DEV_DESC_IDPRODUCT),      /* idProduct */
  WBVAL(USBD0_DEV_DESC_BCDDEVICE),      /* bcdDevice */
  0x01,                                 /* iManufacturer */
  0x02,                                 /* iProduct */
  0x03*USBD0_STR_DESC_SER_EN,           /* iSerialNumber */
  0x01                                  /* bNumConfigurations: one possible configuration */
自定义:
        0x12,                 /* bLength */
        0x01,
        0x10,
        0x01,
        0xef,
        0x02,
        0x01,
        0x08,
        0x51,
        0xC2,
        0x05,
        0x35,
        0x00,
        0x01,
        0x01,
        0x02,
        0x03,
        0x01
GMT+8, 2024-5-27 20:23 , Processed in 0.135913 second(s), 25 queries .
