查看: 3859|回复: 5
[ThreadX全家桶] ThreadX内核及其所有中间件发布的时间
发表于 2020-7-28 08:10:04 | 显示全部楼层 |阅读模式
搜索了几天的资料,发现官网还没有Wiki百科上的介绍多。
ThreadX was first introduced in 1997. ThreadX 4 was introduced in 2001. ThreadX 5 was introduced in 2005, and is the latest version as of 2020.
FileX – the embedded file system for ThreadX was introduced in 1999.
NetX – the embedded TCP/IP networking stack for ThreadX was introduced in 2002.
USBX – the embedded USB support for ThreadX was introduced in 2004.
ThreadX SMP for SMP multi-core environments was introduced in 2009.
ThreadX Modules was introduced in 2011.
ThreadX achieved safety certifications for: TüV IEC 61508 in 2013, and UL 60730 in 2014.
GUIX – the embedded UI for ThreadX was introduced in 2014.
Express Logic was purchased for an undisclosed sum by Microsoft on April 18, 2019.
发表于 2020-7-28 08:15:57 | 显示全部楼层
97年就有了,为什么最近才火呢,是因为之前收费吗?还是不完善?还是什么原因
 楼主| 发表于 2020-7-28 09:07:02 | 显示全部楼层
ThreadX是小型RTOS的巅峰之作,全球装机量62亿设备,不是盖的。之前不是不火,而是我们没有机会接触到。源代码也是不开放的。
现在开源了,可以面向普罗大众了,我们也有机会接触到了。
发表于 2020-7-28 09:07:43 | 显示全部楼层
97年那时候估计不是商用的
 楼主| 发表于 2020-7-28 09:19:42 | 显示全部楼层
lhaoyue 发表于 2020-7-28 09:07
97年那时候估计不是商用的
是商用的,最早的是1990的Nucleus
八卦点有意思的,Nucleus和ThreadX的作者是一个人,都是William E. Lamie
http://www.armbbs.cn/forum.php?m ... 8030&fromuid=58
发表于 2020-7-28 15:32:51 | 显示全部楼层
万能的WIKI
百度介绍有点过时 https://baike.baidu.com/item/ThreadX/7507199
GMT+8, 2025-5-19 07:30 , Processed in 0.279094 second(s), 24 queries .
