都已经更新20年了。
- Version control for emWin/GSC
- 000804 V1.32 a) various changes implemented
- 000403 V1.30f a) LCD.h V1.30 used
- 000327 V1.30e a) LCD.h V1.06a used
- 000323 V1.30d a) GUIArcFloat.c included
- 000323 V1.30c a) LCD.h V1.06 used
- 000229 V1.30b a) Improved Unicode support in GUIChar.c
- 000217 V1.30a a) LCD_Color update to V1.16 (grayscale support in 8666 mode)
- 000211 V1.30 a) 2 new info functions for fonts implemented
- b) Unicode string support added
- 991210 V1.28d a) GUIChar.C: GUI_DispStringHCenter added
- b) Compile Warnings eliminated
- 991210 V1.28c a) GUI2DGL.C splitted
- 991204 V1.28b a) GUI_Context.AWin init modified
- 991203 V1.28a a) GUI2DGL init now initializes GUI_Context.AWin
- 991203 V1.28 a) LCDColor updated (support for 3bpp)
- 991129 V1.26d a) GUIChar.C update (1.20c)
- 991129 V1.26c a) GUI2DGL.C update (reg. LCD_Init)
- 991110 V1.26b a) GUIChar.h update
- 991110 V1.26a a) GUI.H: System defines (Keys etc) added
- 991109 V1.26 a) GUI2DCL.C eliminated
- 991018 V1.24 a) All value display routines rewritten in order to
- support writing into a string (which is helpful
- for other modules, like Progbar etc.)
- b) Type cast added in GUI_GetCharDistX in order to
- make sure characters above 128 are properly handled
- 991018 V1.22b a) LCDChar.c 1.20.02 used
- 991018 V1.22a a) LCDColor V1.12a used
- 991018 V1.22 a) Support for 8666 mode (LCDColor V1.12 used)
- 991015 V1.21.10 a) LCDColor.c update V1.10f
- 991014 V1.21.09 a) GUI2DGL.C update 1.02.05
- 991014 V1.21.08 a) GUI.h: Define for GUI_LIGHTBLUE changed
- 991012 V1.21.07 a) LCDColor.c: Color translation in 8bpp mode with fixed table as default added
- 991011 V1.21.06 a) LCDCOLOR.C V1.10.04 used
- 991009 V1.21.05 a) new GUI2DGL.C used
- 990927 V1.21.04 a) LCDColor.C: LCD_Color2Color15: Blue and red in return value swapped
- 990926 V1.21.03 a) Clipping on entire region for cursor
- 990921 V1.21.02 a) Add. locking support for thread safety
- 990918 V1.21.00 a) New file GUITASK.C added for thread safety
- 990909 V1.20.05 GUI2DCL.c: clean up
- 990901 V1.20.04 Config sample changed
- 990831 V1.20.02 GUIChar V1.10.01 in order to avoid compiler warnings
- 990821 V1.20.01 GUI: Small changes to avoid compiler warnings
- 990821 V1.20.00 Files reorganized, GUIX, GUIFONT, GUIFONTX directories
- created
- 990821 V1.14.01 WMID.H eliminated
- 990820 V1.14.00 LCDMEM4.C added
- LCDChar.C: GUI_DispStringCenterAt added
- 990810 V1.12.03 GUI.H cleanup, Sample\GUIConf.h cleaned up
- 990809 V1.12.02 GUIColor changed in order to ensure proper function
- with 16-bit CPUs
- 990804 v1.12.01 Some compiler warnings generated by the IAR compiler
- eliminated, code cleaned up
- 990802 V1.12.00 Font files now in seperate directory
- LCDWIN.C --> LCDWIN.CPP, now exports a routine
- to display the BITMAP under Windows
- 990725 v1.10.00 Dynamic fonts are supported (Fontkonverter compatible)
- 990720 v1.04.01 New version LCD135X.C
- 990713 v1.04.00 LCD135X.C: V1.10
- LCDColor.C: V1.10
- 990712 V1.03.05 LCD15XX.C: V1.31.01
- 990709 V1.03.04 LCD15XX.C: V1.30.03
- 990709 V1.03.03 LCD15XX.C: V1.30.01
- 990708 V1.03.02 LCD15XX.C: V1.21.02
- 990615 V1.03.01 GL_DrawArc now works with degrees
- 990615 V1.03 Drawarc implemented
- 990615 V1.02 New Version LCD15XX.C: 1.21
- 990614 V1.01 New version of LCD15XX.C with support for Segment
- COM lookup tables
- 990610 V1.00 ** Initial version for version control purpose
