static void LCD429_ConfigLTDC(void)
LTDC_InitTypeDef LTDC_InitStruct;
LTDC_Layer_TypeDef LTDC_Layerx;
uint16_t Width, Height, HSYNC_W, HBP, HFP, VSYNC_W, VBP, VFP;
/* Enable the LTDC Clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_LTDC, ENABLE);
/* Enable the DMA2D Clock */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2D, ENABLE);
/* Configure the LCD Control pins */
LCD429_AF_GPIOConfig();
/* Configure the FMC Parallel interface : SDRAM is used as Frame Buffer for LCD */
//SDRAM_Init();
bsp_InitExtSDRAM();
做了一个板子,因为只是简单的数值显示,又不跑emwin,就不想用SRAM,但是把SRAM初始化屏蔽了显示屏就显示不了了,是必须用SRAM吗?还是需要在哪里设置一下?
